Old 01-28-2009, 02:42 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Originally Posted by Mr. P-Body View Post
The multi-valve relief pistons may "fit" but they are a poor choice if a quality build is what you're after. We use the L2262F (std.) and "dish" it with a simple dish of 16 CCs (3.25" x .100").
Larry has obviously not used the XE cams in lower compression applications. They hardly "suck". We use XE262H as a "replacement" cam for any application where 10:1 or higher and an 068/744 cam would have been used, once static compression has been reduced to below 9.5:1. Our 600 HP (93 octane) street packages use XE solid rollers.
Jim
Jim,
You are right on me not running one.. but I don't discount on a 7.6:1 smog-era Pontiac that it wouldnt make good power. we are talking about a 10:1 389.. and I think it only fair to say that letting someone know all there options to make there own choice is right.
Apparently , a "quality" rebuild by some implies that you have to have a custom , expensive "pro" engine builder "do it right". So all the cast/hyper pistoned 9:51 engines in the world built by very long established national rebuilders and OEM ..lack quality ?
I see half the world split between "Brand name " ,"espensive is better" cheerleaders and the rest of us that sometime's use cast pistons and generic brand cams in our rebuilds lack all the quality according to some...if the guy wants to triple the cost of his engine...go for it.. but I still would not use a 110 LS cam in it..
JMO friends
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
Old 01-28-2009, 06:48 PM
pontiacs-r-us's Avatar
pontiacs-r-us pontiacs-r-us is offline
Thanks guys.Im glade we can all agree to disagree.Also Im thankfull that the Pontiac market is strong enough that we have many choices.I may be ahead to build something else since this is not a #matching block.If I do,I think the dished forged piston is the way to go because of CR.I have dished TRW's in the past to retain orig. heads.I also have used the cast one's in low compression stock rebuilds with good results.(I have friends and customers on low budgets also)I saw where KB has forged pistons now,and they offer a dished(-14cc)forged piston(none for std.400 or 389's)This is good news for us,if quality is good.As for cams I felt that the EX-262H wasnt the best choice because of CR..I have the EX-262 for a 8:1 400 rebuild.Larry,I have a EX-274H in my 455,and like it very much.Thanks Guys.If anyone has this type engine,chime in and tell us about your combo and how it works.As Im shure I will run into this again and have to retain a #matching block.Thanks again,Kenny
