Old 01-28-2009, 12:28 AM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Default Engine torque strap concept?
Wow, ditching the p/s system sure made a lot more room in there. I was playing around with some hardware and fabbed this up for a torque strap. Assuming it clears the hedders, would this be a effective way to reduce the motor twisting so much?I have brand new stock motor mounts and a poly trans mount. The car has welded in subframe connectors and aluminum mounts.
This particular one is a cheap aluminum one, I would pick up a stronger one for final assembly.
Thanks,
ID:	155987   Click image for larger version
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected]
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1972 LeMans 350 Pontiac H/S Drags project
Old 01-28-2009, 09:09 AM
PONTIAC DUDE's Avatar
Wink
Works great. Ran one exactly like that back in the 80's. But will bend a little. If you drive it a lot you might want to get into a chain with minimaul play.
Old 01-28-2009, 10:39 AM
Scott Stoneburg's Avatar
i use a similar type of strap, mine hooks to a ring that i put through the frame. this way i can leave a little slack so the normal engine movements dont abuse the strap. but its tight enough to limit the movement so the motor mounts dont get over extended
Old 01-28-2009, 10:45 AM
Chris Roach's Avatar
Chris Roach Chris Roach is offline
That looks like an aluminum buckle. I'd swap it out for a steel one.
1969 GTO Judge Ram Air III
1968 Catalina "Darkside" Vert!
Old 01-28-2009, 12:14 PM
punisher#1's Avatar
punisher#1 punisher#1 is offline
i'm not a fan of using the head itself for an anchor point. i usually fab a 1/2 inch thick aluminum plate that bolts onto the end of the head using all three bolts and then anchor to that.
another way is to extend a piece of metal fron the front engine mount bolt and atatch a length of chain to the frame from there. just make sure the bolt going into the block is the proper length
'78 Ford Fairmont 526ci pontiac; true 10.5 tires and stock suspension.
5.14 @140.5 w/nos; 8.86@151 all motor.8.17@172 1/4 mile w/nos
Old 01-28-2009, 01:16 PM
69Goat1's Avatar
69Goat1 69Goat1 is offline
I run this...
1969 GTO, 5.77 @ 121 1/8th mile 3450 lbs...535 with Junk dinosaur Eheads
Faster on nitrous…
Old 01-28-2009, 06:53 PM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
Here's a chain and some brackets that I fabricated into my fathers Tempest.. No problems at all with this setup when running in the nines..
ID:	156046   Click image for larger version
Old 01-29-2009, 01:20 AM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
Here is mine:
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Old 01-29-2009, 09:10 AM
Jagtec1, I can read your block code. how do you get such sharp focus photos?
That Passenger plate worth 10x driver plate in my opinion.
A Rear Passenger Head "plate" of equals would complete the force diagram in my opinion.
Old 01-29-2009, 09:39 AM
BILTIT's Avatar
BILTIT BILTIT is offline
So you figure the compression of the pass. side is a much better idea than the extension of a driv. side plate?
I would think you would want some movement though no?
I can't help but think of the amount of vibration transmitted through those plates.
BTW, im new to this.
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 01-29-2009, 11:17 AM
JoePapa's Avatar
JoePapa JoePapa is offline
Does the use of this tie down strap help 1/4 mile performance or 60' times or is this just a pro-active step to prevent motor mount failure?
'69 Firebird 400
http://firstgenfirebird.org/show/closeup.mv?CarID=734
Old 01-29-2009, 12:34 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
I use a bolt welded sideways on the motor mount, it is the best of both worlds. You have the rubber mount at idle and a solid mount when torque is applied. I think it was Jim Hand that originally had this idea. It might not work as well for the big boys but it works great for me, thanks Jim! -Jim Thompson
Old 01-29-2009, 12:45 PM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
And on a light-hearted note in remembrance of Larry Davis, here's a picture of his. Notice anything special about it?
Mike
Old 02-02-2009, 01:45 PM
Indian Uprising Indian Uprising is offline
Just got mine done this weekend!
ID:	156560   Click image for larger version
ID:	156561   Click image for larger version
Old 02-02-2009, 01:55 PM
bnorris_74's Avatar
bnorris_74 bnorris_74 is offline
"This particular one is a cheap aluminum one, I would pick up a stronger one for final assembly."
You'll need a nut on the RH threaded end to lock it in place.
Old 02-02-2009, 05:07 PM
BILTIT, I'm just guessing. Yet my opinion is to help the Block Main Saddles, not the motor mount. Keep them Mains from splitting, also keep the Dowel pins from tensile stressing the caps. IT's all there under load.
Helpful to think of the Factory motor mounts as fuses that blow-out to save the Block Mains from damage.
Also helpful to figure on the real multiplied TQ generated at the Trans Tail, and how it is manifest at the Block Bellhousing. That another compressive plate placed at the PAss-Head rear would make a mechanically dynamic stable joint, for the block length to deliver TQ out the crank flange.
Then the Driver-side lift can be addressed as a reaction to the Pass-plates.
Old 02-02-2009, 05:26 PM
BILTIT's Avatar
Hmmm, might be something for me to look into.
Derek B.
Old 02-02-2009, 09:07 PM
69Goat1's Avatar
Originally Posted by Jagtec1 View Post
Here is mine:
I like it Darin - How are those plates attached at the frame?
Faster on nitrous…
Old 02-03-2009, 12:22 AM
Jagtec1's Avatar
They are bolted with grade 8 bolts to angle iron that I welded to the frame.
I have stock motor mounts (LS with the Jim Hand mod), and a soft trans mount.
Darin
9.81 @ 136.39MPH
Old 02-03-2009, 12:58 AM
I needed to space my alternator bracket for pulley alignment, so I made the spacer plate double as an attachment point for my torque-limiter chain.
The 3/8" thick aluminum plate is sandwiched between the stock alternator bracket and the head, held on with three 3/8-16 bolts. I tapped the plate for 3/8-24 thread instead of just drilling a thru hole for the chain attachment bolt, makes for a much tighter fit. The Grade 8 chain attachment bolt is tightened up first, then the nut is locked down to make doubly sure it doesn't loosen up.
I drilled a hole through both walls of the frame near the top of the rail, it hasn't started to collapse any even though there's no tube inside the rail for support.
The chain was attached to the spacer plate first and pulled tight, then the lower frame attachment tab was marked for drilling. The tab was also tapped 3/8-24 like the top plate. The chain still has almost zero slack, it hung in there fine for over 10 years of transbraked launches. My car isn't all that powerful or quick (12.0s) but I never had any issues with engine movement or engine mount breakage.
