Old 02-03-2009, 08:05 PM
60man's Avatar
60man 60man is offline
Originally Posted by 1qikta View Post
Front and rear driver side mount. I fabbed up some straps using stock frame holes. Seems to help the 60's a lot and better weight transfer. The block bolts (gr 8) completely bottom out in their holes
That's a very neat job. Effectively makes it a soild mount. Your fab skills are good. Can you remove lower bolts for street use? If you check out block bolt location you can how close it is to bottom of the rail. My old demised 462 had cracks behind the DS mount by front bolt and went from rail to bottom of bore on inside....I think fatiauge does in the 50+ year old blocks. Filling the block would help..IMO
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
