Old 02-10-2009, 09:17 AM
GAR64 GAR64 is offline
Default 8-Lug Wheel Question
I just bought some BF Goodrich Redline Tires for my 1964 Catalina. The car has 8-lug wheels on it, and my question is how do you balance the tires? Do you use the rear drums and mount each rim and tire and hope for the best, or do you use a bubble balancer?
Old 02-10-2009, 01:38 PM
There's actually a plate that mounts to the rim and allows it to me mounted to the balancer.
If you search this forum there'll be a picture of one.
Probably the best way to balance them is on the car.
Mike
former." --Albert Einstein
- Winston Churchill
Old 02-10-2009, 02:14 PM
Stuart's Avatar
Stuart Stuart is offline
Those balancing plates show up on eBay every so often, someone is remanufacturing them. The other choices are to use one of the rear drums to mount the wheel on the balancing machine, or as Mike mentioned find a shop that can balance the wheel on the car. It'll probably have to be an old time shop for them to have the right equipment, I don't think your Discount Tire employee will know what you're talking about.
Old 02-10-2009, 02:53 PM
wheelspin's Avatar
Thumbs up Use a rear drum...........
I don't recommend the lightweight plates that are sold, as they are more appropiately used as a spare tire mounting plate. Shops that still have a working on-car balancer are few and far between: use one of the rear drums to balance all 5 wheel units off the car on an electronic balancer.
Les
Les Iden
Old 02-10-2009, 03:01 PM
Keith Seymore's Avatar
Are you sure, Les?
I thought I saw a CNC version from Fabcraft or somewhere that was heavy enough for mounting/dismounting as well as balancing (which I agree the spare tire plate is not heavy enough for). I bid on it on ebay but did not win it.
K
'63 LeMans Convertible
'63 Grand Prix
Old 02-10-2009, 03:25 PM
Stuart's Avatar
The balancing plates and the spare tire hold down plates are two different animals.
Old 02-10-2009, 05:14 PM
Carl A Carl A is offline
This plate.
ID:	157669   Click image for larger version
Old 02-10-2009, 05:20 PM
Originally Posted by Carl A View Post
This plate.
Ah - very nice.
http://mainelycustombydesign.com/index.html
Do you suppose that's heavy enough to use for tire mounting as well?
K
'63 Grand Prix
Phyllis1965's Avatar
Phyllis1965 Phyllis1965 is offline
That is correct, and my balancer plate is a heavy duty thick gauge steel………
I am back! Not much progress……………… but I’m back.
Old 02-10-2009, 06:30 PM
wheelspin's Avatar
Arrow More info..................
The plate that I am referring to is the one manuf. & sold by the gentleman that makes the custom offset/width/diameter 8 lug rims. This is the most common piece that I have seen for sale @ Norwalk and various POCI National Conventions. It's nominally 3/8" thick aluminum w/ 8 short wheel studs pressed into the perimeter and a 4" hole in the center. It looks like a lighter duty version of the above pictured Mainely unit.
The spare tire hold down plate is a black-painted stamped steel disc, w/ a notched perimeter to fit around the wheel's stud positions, and is available from our Host for $39.
The Mainely unit in post #7 appears stout enuf to do the job, but why not use the existing drums for balancing and save the extra expense since all modern tire machines clamp the lower bead of the wheel rim to anchor the rim for tire changing?
Les
Les Iden
Old 02-11-2009, 12:44 AM
cheese country GP's Avatar
cheese country GP cheese country GP is offline
Smile 8 lug balancing
The 8 lug balancing plate was originally produced by Roger Reihl of 8 lug rebuild fame. He passed away several year's ago. When he was doing the hub relining, he came up with a plate that was about 3/8" thick to use for spin balancing on the newer balance machine's. Those plate's had just four lug bolt's to attach the wheel's instead of the newer one's with eight. They were also steel & not aluminum so a little bit heavyer.
According to Roger in conversation's we had, the original thinner spare tire hold down plate was used for bubble balancing since there was no way to balance the wheel without it. So it actually served two purposes, the spare tire hold down & a bubble balance adapter.
Which method of balancing is better I can't say but you have several alternative's to chose from based on the message's posted here. Good luck.
Old 02-11-2009, 09:07 AM
Heybuck's Avatar
Heybuck Heybuck is offline
I'll chuck in some of my experiance with this matter:
If you don't have a heavy weight balancer plate, use a rear drum by all means but BEFORE you mount the rim to the drum, spin up the drum first. You might be surprised that the bare drum is out of balance.
Next balance a front drum but I couldn't find anyone who could do so with the rim and tyre fitted. So we mounted the front drums using a small Japanese car sized alloy wheel adapter, (take the wheel bearings out), spun them up and noted any balance discrepancy. Mark the drum balance spot using a small piece if masking tape so you know where to align the rim and add any weights required.
Now you know if your drums are out of balance and you can weight the rim accordingly after you spin them up using the rear drums. Carefully add the weights as required.
It's all very time consuming but it was the only way I could finally achieve a good (read great!!), balance on my wheels. Well worth it in the end but I'm not looking forward to when I have to buy new tyres!!! Got to go through all the motions again....
To laugh at men of sense is the privilege of fools.
Old 02-11-2009, 09:49 AM
Engine-Ear's Avatar
I picked up one of those older on-car balancers... It needs a new power cord and a good cleaning and lubrication but it will get the job done.
Having a 'reference drum' that's been zero-balanced on hand for balancing 8-lugs seems like a good tool to have around!
RediRad circuit designs, branding and intellectual property are for sale.
Serious inquiries only.
Old 02-11-2009, 09:53 AM
There ya' go. I'll just go see Matt when I'm ready to have some tires done.
Re: "Reference drum" - might be a good usage for a drum that otherwise is no good, like one where the lining is shot for example.
K
'63 Grand Prix
Old 02-11-2009, 10:22 AM
Stu Norman's Avatar
Stu Norman Stu Norman is offline
K
Seriously, Matt. How much will you be charging to balance a Darksider?
Stu Norman
Msgt. (ret)
Hortonville WI
May the torque be with you.
Old 02-13-2009, 10:36 PM
Pontiac62's Avatar
Pontiac62 Pontiac62 is offline
I went to a local tire shop last summer. It is part of the Tire Factory franchise. It has been in business at least 35 years. Not sure when it opened. I asked them if they knew what Pontiac 8-lug wheels are. He said "yes, and and we have an adapter plate to fit the modern spin balancer" I went back to the shop and he showed it to me. It was a little dusty, but is was the real thing. Very heavy steel plate with four threaded holes for lug bolts.
I had them balance my wheels before my trip to the convention. They also found that I had one bent rim. Still had a vibration, so had my driveshaft checked, and found my driveshaft was also toast. So after having a new shaft made, everything was smooth as glass. Made the trip to Spearfish and back (about 3000 miles) a great experience.
BTW, the name of this shop was Gary's Tire Factory, But I have seen others with other first names using the same franchise logo.
Les
Old 02-14-2009, 12:41 AM
Engine-Ear's Avatar
Um, OK, uh, ZERO.
Just show up and we'll get you wheelin' straight.
Old 02-14-2009, 09:58 AM
joeg joeg is offline
I would drive 125 miles to have my 8 lugs done correctly on my car. I bought new fronts drums from Arrowhead last summer, waiting for the rears, should be any day now. Not looking for any freebies here, seriously if interested let me know what you would charge to do all 4.
Joe
Um, OK, uh, ZERO.
Old 02-14-2009, 10:27 AM
Engine-Ear's Avatar
joeg & the group: Maybe later this year (May, June) we can have a "B or B" (Balanced or Bent?) cookout at my place. Get your 8-lugs balanced and make a donation to a coffee can to cover the cost of wheel weights and/or bratwurst.
I'll do my best to resurrect this idea (or joeg, remind me) in a few months when I get time.
Old 02-14-2009, 10:54 AM
Sounds great! Thanks!!
