Old 02-24-2009, 01:17 AM
turbo69bird's Avatar
Default whats your biggest Resto blunder??
Just figured this would be great way for guys not to make the same mistakes others have already made.
Old 02-24-2009, 07:59 AM
Pull the headliner out of a car before you start welding on the roof.
Old 02-24-2009, 08:55 AM
bajagold70's Avatar
bajagold70 bajagold70 is offline
Hanging new quarters and not test fitting the rear window trim before painting the car .
Old 02-24-2009, 11:40 AM
chuckmnv's Avatar
chuckmnv chuckmnv is offline
Oh, that's easy: starting!
cm
If the rules don't say something is illegal, I have to assume it is legal -- Smokey Yunick
Old 02-24-2009, 12:17 PM
rolling money pits's Avatar
rolling money pits rolling money pits is offline
cm
LOL
beat me to it.
and in my case, starting one while you're still in college.
costs too much
Old 02-24-2009, 01:30 PM
3 Chiefs's Avatar
3 Chiefs 3 Chiefs is offline
Wasted $300.00 on cheap junkie sheetmetal. Spend more money and get the good stuff. Lesson learned.
When replacing sheetmetal, measure everything many times.
Paul
I never met an old car that I didn't like.
Old 02-24-2009, 02:01 PM
Actually, my biggest blunder is probably still yet to come..lol
formulapk formulapk is offline
believing what the seller is trying to sell you, if buying from a stranger, i would hope that all of us on this forum are the trustworthy types. check EVERYTHING yourself and know what to look for. be well informed. sad but too many guys looking to make a quick buck off you.
Old 02-24-2009, 02:15 PM
The Boss's Avatar
The Boss The Boss is offline
Getting divorced in the middle of one.
The second mistake was not visiting the shop more often.
And go racin' in the street.
Old 02-24-2009, 02:24 PM
Boxerdog Boxerdog is offline
Default Biggest screw up
Using Killer chrome.
Old 02-24-2009, 02:29 PM
Really? I was really pleased with it once I figured out the proper way to use it.
Old 02-24-2009, 02:33 PM
70 Lemans's Avatar
70 Lemans 70 Lemans is offline
But I always say. You can't finish what you don't start. Need another lifetime though.
cm
69 400 Block, .030 over, KRE eagle stroker kt, KRE,CNC ported e-heads 310 cfm, port match RPM , comp roller 236/[email protected] 586/600 lift 110 LS. 1.5 HS roller rockers, 350 Transmission, Red Neck tight 3500 stall converter, Ford 9” with 3.75’s, Strange center section, Moser 31spline axels, 29”Mt slicks, HRPARTSNSTUff anti roll system, Doug’s Headers 3.5” collectors, 22”Dynomax mufflers w/ H-pipe, Cliffs Q-jet, Fuel cell with sumps, Mallory 140 fuel pump and filter. Denny’s 3.5” drive shaft.
Old 02-24-2009, 03:29 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
The biggest blunder that I can remember at this moment is trying to change the positive battery cable at the starter WIHTOUT disconnecting it from the battery first. Fried both cables. There are others I'm sure.
Old 02-24-2009, 03:41 PM
Barrier Blue's Avatar
Barrier Blue Barrier Blue is offline
One that comes to mind is not test-fitting the rear wheel opening moldings before welding new lower quarters in place.
Another is letting my brother paint the GTO.
When I'm paid, I always follow my job through...you know that.
http://www.youtube.com/watch?v=Al2b-...eature=related
Old 02-24-2009, 06:31 PM
performerrpm's Avatar
performerrpm performerrpm is online now
well, up til now i can say this. dont take your car all apart then decide you need to get married. if you do get married well....try and keep busy so not to end up in the sac with wife to often, you would be amazed how quick a planned year long project can turn into 5-7 years after she starts shootin out kids at a steady pace and you keep having to upgrade the living quarters all the while she is telling you it is the proper thing to do! other than that tho, go for it!!!
Old 02-24-2009, 06:39 PM
kate`s67gto's Avatar
kate`s67gto kate`s67gto is offline
If someone else installed a part double check it after he is not looking. A big dollar lessen learned, also double check your own work.
Scott
If you always do what you always did
You always get what you always got
Old 02-24-2009, 07:09 PM
The Boss's Avatar
That right there - is some funny stuff!
Old 02-24-2009, 07:14 PM
70 Lemans's Avatar
Wow you nailed it. No pun intended.
Old 02-24-2009, 08:37 PM
carcrazy carcrazy is offline
Purchasing a car with more rust than good metal!
Old 02-24-2009, 08:41 PM
78 GHOST 78 GHOST is offline
Letting Alpha Kustom in Willis, TX do the paintwork and not doing it myself.
____________________________________
"I work in high speed aluminum tubing."
