#841
Old 03-03-2009, 08:12 PM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
i thought the 3.73 rear was with 4 speed only?the rad support is interesting,got the right fenders,so wonder why they replaced it?
FREEDOM ISN'T FREE
BUT WORTH FIGHTING FOR
  #842
Old 03-03-2009, 08:27 PM
goathead455 goathead455 is offline
Would the PHS show Performance Axle for the 3.73 gear ?
  #843
Old 03-03-2009, 09:10 PM
2manyT/A'S's Avatar
According to my 1971 Pontiac Accessorizer (dated Jan 4/71) G92 Performance Axle was a chargeable option @ $10.53.
Does it show up on your 70's PHS?
As I understand it,ALL non A/C HO's got 3:42's
  #844
Old 03-03-2009, 11:58 PM
Yes it does with a charge of $7.80
  #845
Old 03-04-2009, 07:20 PM
1971455HO's Avatar
1971455HO 1971455HO is offline
Pretty sure mines 3.42 and she has air. Looked at the axle code about twenty years ago. I would have remembered. Can't verify it right now. It's away from home.
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
  #846
Old 03-04-2009, 08:09 PM
70RAlll 70RAlll is offline
a/c cars came with a 3.08 gear
  #847
Old 03-04-2009, 08:19 PM
74 SD455 Formula 74 SD455 Formula is offline
HO A/C cars came standard with 308's,but was'nt a 331 ( GTO 12 bolt ) Optional or was it a 323's ?
For the record my 72 T/A with A/C had a standard 308 posi.
  #848
Old 03-04-2009, 08:26 PM
TA455HO's Avatar
TA455HO TA455HO is offline
Didn't 71 4-speed (which that car isn't) A/C come stock with 3.42? Automatics had the 3.08 gearing standard? I think my Van Nuys is 3.42.
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant
http://www.ford-trucks.com/forums/12...al-ranger.html
1966 Ford F250 4x4 Red/White 4-speed - San Jose plant
1966 Ford F250 4x4 White 4-speed - San Jose plant
http://www.ford-trucks.com/forums/11...-f250-4x4.html
1971 Trans Am White/Blue 4-speed limited options - Norwood plant
http://forums.maxperformanceinc.com/...d.php?t=757496
  #849
Old 03-04-2009, 08:34 PM
necdb3's Avatar
necdb3 necdb3 is offline
ta455ho,
You are correct. 4 spd HO cars were 3.42 even w/ AC, automatics had standard 3.08
  #850
Old 03-04-2009, 10:44 PM
1971455HO's Avatar
This is good info fellas. Are rear axles, or rather, were rear axles stamped or otherwise identified with partial VIN's just like the trans tags? Can you verify whether you still have your original rear axle or not? Just wondering.
Ol' man Smith
Son video'd this...
  #851
Old 03-04-2009, 11:36 PM
TA455HO's Avatar
I don't believe there is a partial VIN on the differential, but on the passengers side tube on the front surface is a three digit code that signifies the ratio. I think there are other identifying features, too.
  #852
Old 03-05-2009, 07:19 AM
2manyT/A'S's Avatar
NO 12 bolt OR 3:31's in 1971,that was 70 1/2 W66 & WS4 only.
I'll check my 71 order guide.
The power train charts will confirm the A/C standard ratio for T/A's & HO's
I had a heavily optioned 71 T/A (auto) with A/C about 25 years ago & it definately had 3:08's
  #853
Old 03-05-2009, 07:32 AM
everyone is correct. the 3:31 gearing was a 12 bolt A/C gear set, the 3.08 was the auto 10 bolt and I guess the manual in 1971 got the larger gear.. I had always summised Pontiac mandated the lower (numerically) gears on a/c cars for 2 reasons. help keep the belt from flipping at highway speeds, plus the compressor probably had limits to how fast it could reliably turn.and the lower gears obviously helped...there is a chart in the assembly manual...
  #854
Old 03-05-2009, 07:01 PM
OVERULD's Avatar
OVERULD OVERULD is offline
My 71 GTO, HO/RA/M22/AC/12-Bolt came with and still has the 3.31 gear set.
BJ
  #855
Old 03-05-2009, 07:11 PM
BJ
Thats what I was getting at.I made the mistake by not clearifing T/A or GTO.I have a 72 GTO HO/RA/AC/Auto with a 12 open and 308's.I am putting in a 12 bolt posi with 331's and wanted to know if this would have been correct.Thanks for the info and sorry for the confussion....
  #856
Old 03-05-2009, 08:29 PM
please take this comment as my attempt with a bit of wit... but you two GTO guys are on the incorrect forum. This is a Trans Am HO forum, not the GTO side of PY's forum !!!!!!!!!!!!!!!!!! as is always the case, a little truth in every joke... BUT,Trans Ams came with 10 bolts in 1971 not the 12 bolt.. that was sort of the point in the 3.08/3.42 answers...
  #857
Old 03-05-2009, 08:59 PM
Let's see,
The title to this forum is 455 HO Forum.Yes it is in the 70-73 Firebird & T/A Tech section,but an HO is still an HO weather it is in a T/A,Formula,or a GTO.Next you'll be saying that the Super Duty Forum is only for Trans Am's.Can't we all just get along here and injoy what we have and to share info as well as ask questions and hope to get answer's ?
  #858
Old 03-06-2009, 03:30 PM
TA455HO's Avatar
"455 HO FORUM" is just a *thread* in the 70-73 Firebird & T/A Tech Forum. 2Many just used the word FORUM in his thread title which made it look like a new Forum, but it isn't really. Sort of sneaky how he did that.
  #859
Old 03-08-2009, 04:25 PM
giles's Avatar
giles giles is offline
OK, I know this is not specifically a "455HO" topic, but the past 20 or so posts here have dealt with axle ratios.
Decoding the '71 axle chart for TAs and Formulas I find the following...(and I may need new glasses after staring at this fine print!!)
To determine the axle ratio, you should first select the engine and trans, then in some cases there is a "performance axle option"
model Engine trans a/c axle
Formula 350 350 M38 both 2.73 there is a note that this was deleted effective 2/30/70
Formula 350 350 M38 both 3.08 performance axle option
Formula 350 350 M38 both 3.08 standard with altitude option (WT5)
Formula 350 350 M15 both 3.42
Formula 350 350 M20 both 3.42
Formula 400 400 M40 both 3.08
Formula 400 400 M40 both 3.42 performance axle option
Formula 400 400 M40 both 3.42 standard with altitude option (WT5)
Formula 400 400 M15 both 3.42
Formula 400 400 M15 w/o 3.73 performance axle option
Formula 400 400 M20 both 3.42
Formula 400 400 M20 w/o 3.73 performance axle option
Formula 400 400 M22 w/o 3.73
Formula 455 455 M40 with 3.08
Formula 455 455HO M40 with 3.08
Formula 455 455 M40 w/o 3.42
Formula 455 455HO M40 w/o 3.42
Formula 455 455HO M15 both 3.42
Formula 455 455HO M15 w/o 3.73 performance axle option
Formula 455 455HO M22 both 3.42
Formula 455 455HO M22 w/o 3.73 performance axle option
Trans Am 455HO M40 with 3.08
Trans Am 455HO M40 w/o 3.42
Trans Am 455HO M22 both 3.42
Trans Am 455HO M22 w/o 3.73 Performance axle option
All TAs and all 3.73 axles were limited slip. Other Formula axles would come without posi unless it was ordered.
The tab function did not space the columns properly. My note "both" means with and without A/C. "with" means with A/C, "w/o" means no A/C
  #860
Old 03-08-2009, 07:57 PM
Father&Son73T/A Father&Son73T/A is offline
Don't know if will PO anyone off or help but our 73 L-75 TA auto was ordered with a/c and a "performance axle" 3:42.........it's on the PHS..
1973 T/A Buccaneer Red L-75 A3,83k mi. #'s match
1979 T/A Atlantis Blue W-72 WS6 23k mi.survivor#'s match
1999 T/A Navy Blue 60k mi....babied
1968 442-gone but not forgotten
"Oh,you can think about it,.....but don't do it!"
Sheriff Bufford T.Justice
