Old 04-10-2009, 10:32 AM
roundportponchos's Avatar
Wink thanks
i have a 70 nuys setup, & my 71 TA, had something close...., no dates on VN setups, that i could see. That "shark tooth" 71 set up is just a Norwood only setup..
thank you so much
Originally Posted by 68bird400HO View Post
The '71 VN jack would be the same as the '70 VN jack. It is just the supplier that Van Nuys used. I have seen the same jack in Fremont built A-bodies. Below are pictures of the three jacks side by side, the three bases side by side, and some close ups of the mechanisms. From left to right I bring you - the '70 Norwood jack, the '71-'72 Norwood "Y" style jack, and the '70-'71 Van Nuys jack. The '70 Norwood base is stamped U70 and you can see the date code on the Norwood '70 mechanism on the rivit. These are in their original paint and rust. Hope this helps.
Old 04-10-2009, 11:07 AM
68bird400HO's Avatar
thank you so much
I haven't found a date on my VN jack either. The "Y" style jack has a date code stamped in the mechanism near the up/down lever.
