Old 04-23-2009, 08:25 PM
eric65's Avatar
eric65 eric65 is offline
Thanks Eric. Looks like an April build. Just curious - what plant was the car built at?
kieth the data plate reads
04C 1
23767xxxxx PON 8738
218-B E-1
ET2WGT
5NW
...go git 'em, tiger!
we got kilt again but only by 18 this time. Im trying to play varsity with 7th graders
Marty I got some pix of restored firewall with my convert power wire coming out of grommet and the rally harness
check them out hope you can make heads er tails out of them
Notice my tabs broke off my firewall to fuse block panel ,, I gotta do something about this but dont know what at this time Looking at the resto books for one. But my harnesses arent holding very well
Marty also there are a lot of post here about Rally gauges and how they came and I believe I've seen from Pete Serio that all cars had the same harness from the factory and when rally gauge packs were added they(GM) used the same harness and just installed it at the factory
Look up this post or thread
http://forums.maxperformanceinc.com/...t=rally+gauges
ID:	166453   Click image for larger version
Old 04-23-2009, 09:27 PM
Keith Seymore's Avatar
04C 1
23767xxxxx PON 8738
218-B E-1
ET2WGT
5NW
Ok - thanks
we got kilt again but only by 18 this time...
Well....that's ok....it's supposed to be fun, right?!
'63 LeMans Convertible
'63 Grand Prix
Old 04-23-2009, 09:56 PM
Carl A Carl A is offline
Heres what I have for the wires Dark Blue (to oil sender) brown with fuse holder ( to neg coil) Green (Temp sender Intake) What is the black connector beside fuse holder and what connects to it?
ID:	166459   Click image for larger version
Old 04-23-2009, 10:26 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
I don't think anything connects in there. But mine doesn't have that fuse deal. Any chance you have transistor ignition?
And you are correct, the bundle of wires coming out of the grommet are the wires for the Rally Gauges.
Old 04-23-2009, 10:56 PM
Thanks Jerry--There is a single male connector on it, as for transistor ignition never thought of it I'll have to check more. Sry couple more questions my car is a auto/tri power on one of the harness(PIC #2 for auto kickdown ,Black wire/blower motor-Pink strip to +coil ? ) there is a broken blue wire? On the alternator harness there is a broken green wire. Any hints anyone.
For Keith S. my car is a
11D
23727 KAN1022
217 W-W
W 2WGPR 4F 5NW
ID:	166464   Click image for larger version
ID:	166465   Click image for larger version
