Today, I checked 2 different drums for a 2004 Ranger. They are 9"x1.75 on a 4.5" bolt pattern. But, the inside of the drum where it goes on the axle center is larger than the axle. Drum measures 2.80 ID, axle measures 2.675 OD. This means that the drum will not center on the axle. The lug stud holes in the drum are larger than the axle studs & will move around on the axle quite a bit. The difference between the drum & axle is 1/8 inch!! I have not had a chance to check a front hub to see what diamater it is.
Keith
Keith Collier 61-63 Pontiac Tempest Tech advisor POCI.org |
