| Non Pontiac Motors in Pontiacs includes factory 403,305,350 Chevy, Buick V6, Also Pontiac Motors in non-Pontiacs! |
.....and more progress.
First thing today I removed the rear bumper and fuel tank, and emptied out the trunk. Both bumpers will need to removed to replace the body mounts. The bumpers bolt to the frame and body needs to move up enough to get the mounts out, so removing the bumpers is a must. While I was under the car I loosened up all of the body mount bolts in preparation for their replacement. Every single one broke free and turned freely without any penetrating oil, there will be no cutting out the floor to remove any rusted-up captured nuts in the floor pans. ![]() Spent some time inside the trunk scrubbing it cleaner than it's ever been since I've owned the car. My full-size spare 18X9" wheel and 245/45-18 tire needs a nice home. ![]() The spare will sit in the stock location on the passenger side. ![]() A look at the driver's side. ![]() The trunk floor still looks pretty good after 13 years, some of the heavier rust has started to bubble up under the silver POR-15. This trunk floor was pretty crusty when I did the POR-15 application, I scrubbed the loose stuff off until I just couldn't scrub any more. ![]() Underneath the trunk floor with the fuel tank removed, you can see where a little silver POR-15 seeped through when I did some patching right in the center. ![]() I cleaned the front trunk wall from underneath and the panel above the rear axle, I scrubbed and cleaned as far as I could reach. You can see some more evidence of rust patching right next to the trunk body plug hole. ![]() ![]() I even scrubbed everything that's usually hidden behind the bumper. ![]() I won't get an armfull of dirt or grease while I'm working on the chassis or brakes. ![]() This car's cherry. Moving forward!
