Old 05-07-2009, 05:22 PM
Bluethunder1975 Bluethunder1975 is offline
I put TBI on my P350 in my 80 T/A..
Bought a Megasquirt EFI kit, built it (took a weekend).
Scavenged a TBI and sensors from a 90 sumthing chev 1 ton with a 350. Cleaned it up, and put a kit into it. I installed the adapter plate for the TBI to quadrajet so it would bolt up to my intake.
I added a Innovate LC-1 wideband to help tune the beast. Its priceless.
Took another weekend to build a harness for it (I used an underhood fuse block / relay from a mid 90s explorer, so I wouldnt over load the existing fuse block. Just used the diagram provided, and a MS EFI harness that had all the wires pre-labled.
I went a little over board the fuel tank, as I converted the 2nd gen TA tank, to accept a 3rd gen sender and pump.
Currently I'm just doing fuel control, with plans to added a pontiac 81 computer controlled dis later on. (waiting on the shelf)
If your good with electrics, its something that can be done in a few good weekends..
All told, it cost about 600 for everything including the wideband O2.
The build was the ez part. Tuning, on the other hand, is another completely different animal.
Old 05-07-2009, 07:41 PM
Ollie's Avatar
Ollie Ollie is offline
Bluethunder
What is involved in adapting a 3 gen pump and sending unit into a 2nd gen tank. Did you take any photos?
Its ok to giggle and snicker, Dont laugh and point
Old 05-07-2009, 08:45 PM
Tank baffles from an ninety something S-10 from PNP. very little modding required to make it fit!
Starting to weld in the new sender hole, and tin. I cut out the old vent line "bowl". The new sender has a vent built in it.
And with the sender inplace.
