Old 05-31-2009, 11:13 PM
lkt1954's Avatar
lkt1954 lkt1954 is offline
Thats what I thought to begin with, I had a set of belts from our host and had the same problem, so I got a belt from the local auto supply- same result. I will try a new belt from either our host or another supplier (any suggestions??). Does anyone happen to have the correct belt number? Fluid is ok- that the first thing I check everytime I drive the car. Thanks for the help & I will try a different belt. Just a thought could it be a wrong pulley????
Thanks again
Larry
Get in-Sit Down- Shut Up - Hold On
Old 06-01-2009, 06:26 AM
Maybe it's the wrong pulley?
In other words, maybe the right belt is wrong for the part you used since you were kind of piecing it together.
Old 06-01-2009, 11:35 AM
toddmoll's Avatar
toddmoll toddmoll is offline
Larry, is the steering box a stock ratio box? And is the flow control valve in the pump the correct (low pressure) one for the box? I changed my 66 to a quick ratio box and with the required high pressure control valve in my pump I get a chirping squeal when the box hits the locks at full travel. I put the low pressure valve back in as a test just to see what would happen and could hold the wheel on the lock at full travel with no squeal. This is normal for the high pressure so I learned to live with the noise on those occasions where I need to make tight turns.
Todd.
