Old 07-09-2009, 11:52 PM
RST's Avatar
RST RST is offline
67 Firebird 1.45 60' 10.47 @ 127 mph Still new at this racing a car with HP Last car was high 12s.
Old 07-17-2009, 08:53 PM
Brent Flynn's Avatar
Brent Flynn Brent Flynn is offline
1968 Bird.. 3550lbs. 462 trw's 25yr old Engle .503 hyd
stock #62's, '68 q-jet and intake, 8" ATI 4000 converter, 400turbo
4.10 spool(little too much gear and converter for this combo) Hedman huslers 2"
HEI locked...33degree timing, 5400 rpm shifts 11.63@113 1.52 60ft. 9x30 Pheonix's
1962 Catalina...4100plus...462 trw's... .507 Ultradyne hyd.
stock #48's, 800cfm dbl pump holley and performer RPM( not necessarily
the best induction for weight of car) 10" Coan converter(late 80's era),
400 Turbo Coan, 3.90 spool, 3 tube Blackjacks(seriously), MSD Billet and old 6A box, 33 total ignition
timing, 5400 rpm shifts.... 12.23@ 108.77 1.605 60ft. 9x28 1/2 Pheonix's
Last edited by Brent Flynn; 07-17-2009 at 08:57 PM. Reason: forgot some important info
Old 07-18-2009, 07:34 AM
Pontiac guy's Avatar
Pontiac guy Pontiac guy is offline
72' LeMans 3250lb
73' 400 +.030
13 heads don't know the flow numbers
solid lift comp cam
RPM intake elderbrock 850
8" ati 4500 stall
3.73 rear gear
best time 11.49@114mph
Old 11-30-2009, 06:27 PM
PONTIAC DUDE's Avatar
Thumbs up New Best with Less
1976 Pontiac Trans Am. Original 455 4spd car.
3450 lbs stock suspension. Power windows and tilt wheel. stock interior less back seat. console w/full dash
Rear: Ford 9" w/3.90 gears. Landrun springs, CalTracs, 12 way QA-1's.
10.5"X29.5"X15" M/T slicks on 8.5" rims.
Front: Stock arms & steering, Moroso springs and 3 way shocks. Full inner wells.
4 whl disc brakes.
1.80 Powerglide w/PTC converter. transbrake.
Hooker 2" headers w/3.5" dynomax bullit mufflers.
535 cu.in. IA block.
BRC std flat top pistons.
Hydraulic Roller Custom camshaft
*PUMP GAS.* 93 octane Sunoco
10.80-1 compression. N/A.
SD Performance 89cc "342cfm std pushrod location" E-heads.
Victor 4500 series intake
1050 cfm Old style 9375 Holley Dominator carb.
Bradenton, Fl. 2009
First pass right out of the trailer:
60 ft'er.......... 1.45
1/8th ............6.30
mph..............109.75
1/4............... 9.91
mph..............135
Old 12-21-2009, 06:27 AM
Marcel's Avatar
Marcel Marcel is offline
1981 Lemans, full interior including back seat, functional power
windows,door locks,tilt wheel and console with full dash.Car is certified to
8.50.
3920 lbs race weight.
Rear: Non tubbed, Ford 9" 3.73 gears, ladder bars, 28x10.50 Hoosier slicks
on Weld rims, 12 way shocks.
Front: Tubular arms, factory springs meant for the weight of a 6 cylinder
engine, drag shocks. Full inner wheel wells, 4 whl disc brakes.
Turbo 400. 3800 stall. trans brake.
1-7/8" headers that go into a 3-1/2" full length exhaust(including rear tail
pipes) with mufflers.
SD Performance built(thanks Dave!)541 c.u. in. IA II block. N/A. 10.90-1
compression, SD Performance wideport E-heads.
PUMP GAS.
I finally got the engine installed in late September of 2009 or in the words
of my business partner and builder of the motor, Dave Bisschop; We finally
completed Marcel's 541 wideport E-headed engine, or should I say I finally
let him have it after using it for 2 years of R&D testing!! LOL. We got it
to the track on a cold Friday October 9 which was the last test and tune
before the track shut down for the season/winter. We only had time for a few
shake down runs.Track prep was poor, but we did manage to run 6.22 @
110.5mph in 1/8th and close to a full pass laid down a 9.93 @ 136mph
spinning off the line(we got booted off at this point as none of has a Comp
licence and we had been warned after our 1/8th mile pass) The engine dynoed
at 815hp on pump gas @ 6700rpm, 9.70's or quicker won't be a problem in 2010
with a bit of tuning and seat time.
Once we have the car dialed in on the motor, then we are going to try a
little 250- 400 shot of spray(Dave built this as a nitrous motor for me)
I do drive the car on the street(and not just to the corner store and back)
as my kids love going for rides and have had zero problems doing this.
I have attached copies of the time slips(car # J673) and some photo's of the
car. Hopefully, I did the attachment(s) correctly.
Marcel
ID:	191498   Click image for larger version
Name:	interior shot from drivers side.jpg
ID:	191501   Click image for larger version
Name:	full car shot.jpg
ID:	191502   Click image for larger version
Name:	time slips.jpg
Old 12-22-2009, 01:24 AM
badassgoat's Avatar
badassgoat badassgoat is offline
Hey Marcel, on the SD web site I TOLD you Dave would get you bounced from your local drag strip for going faster than your tech. He did it to me last season at Englishtown...several times when I was still racing my 69 goat. That car was almost the same exact weight as your LeMans and I eventually went a 9.80 @ 139 after you guys did my WP's, Victor, and specced a new cam. If I could have left harder on the brake, I'm pretty sure it had a tenth or two left in it. Anyway, congrats on getting your ride to the track finally and laying down some 9 second passes. Happy holidays to you and please pass those wishes on to Dave and Lisa as well.
PS: did Dave get his hands on a set of the new Victors yet?
69 'Blackbird'
535 CID IA II SD Wide Port E-head Pro Systems Dominator
