Old 07-10-2009, 02:35 PM
73LeMans's Avatar
73LeMans 73LeMans is offline
Originally Posted by 428PHIL View Post
Seen a number of post on Zaino that say it's hard to use, or time consuming. I've been using on my black 66 since it was painted 3 years ago. In the spring I use Z5 Show Car Polish and then Z6 Gloss Enhancer over it. It takes about an hour to do both. After that I only use the Enhancer takes about twenty minutes. The car is covered and garaged, only put about 1K a year on it, never use soap, only clear water out of a bucket.
With dry times in the approximate 30 minute range in ideal conditions, applying a coat of Z5, Z6 and then Z2 (my standard set after washing) at least adds another 90 minutes to the 30 minute process of washing and drying the car. I can see some folk thinking that might be a bit much, considering most waxes go on and off in 30 minutes. But for those that want a car that stands out in the crowd of many, to me, its the only way to go.
Phil as a recommendation, I would consider using the Zaino car wash with the water in the bucket. Wont dry the paint, and it softens up the water some. Just my $.02
~Mark
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....and 2023....and 2024.....and 2025.....who am I kidding? there will be no 9s with this engine!
>>My 73 Build thread
Old 07-10-2009, 11:10 PM
Mr W72's Avatar
Mr W72 Mr W72 is offline
I use a combination of Adams products and Zymol Destiny. Together they have produced a outstanding look and shine on my 32 year old lacquer. Both product are not cheap, Zymol Destiny runs around $650.00 for 8oz jar
ID:	174421   Click image for larger version
John Witzke
POCI Tech Advisor
1977-79 W72 Performance Package Historian
