Old 07-14-2009, 07:25 PM
69gtocv 69gtocv is offline
Originally Posted by 69goatboy View Post
Might be the black centers, it seems to cut down on the "large-ness" of some of the other chromed or polished large rims.
I think you hit the nail on the head there. The black is what does it. I agree, too large of shiny wheels just doesn't look proportionate on an A body.
Old 07-15-2009, 09:55 AM
ilo ilo is offline
The tire rim combo look so good on your car you can hardly notice the nasty rusty exhaust
pipe coming out the side.... Better then mine... I have a really nice clean exhaust with a
nasty rusty car above it...
It has the perfect rake to it and the paint is smooth as glass..
The best looking orange 68 I have ever seen... and I've seen a ton of them.
Would love to see more pictures...
James Aiello
1968 GTO H.O. 4spd
Old 07-17-2009, 08:12 PM
Roadbuster's Avatar
Roadbuster Roadbuster is offline
Thanks everyone for the compliments. I'm glad you like the car and humbled by all the praise.
Originally Posted by goatless View Post
Wow! That looks badass! Did you need to modify the wheel wells to fit those wide rears on?
What's the backspace/offset on the wheels? Those specs on the non-OEM wheels would be good to know for the guys looking for aftermarket wheels that'll fit.
Goatless, My front suspension is a custom set up from SC&C and I have a narrow rear axle. Because of this my back space numbers won't help anyone unless they match my setup exactly. There is no room for error on the front. I was off a bit and the wheel hit the control arm at lock until I aligned it. Out back you will have to massage the back of the inner wheel well a tad bit. Make sure your body is centered on the frame. I can help with locations that need to be measured but this has very little clearance and really needs to be measured.
Thanks ilo, I cut about 6 inches of rusty pipe off just leaving a little turn out under the car. Looks much better. Replacing the pipes is on my to-do list. It is still a work in progress.
Jon
1968 GTO with SC&C Suspension
