Old 08-06-2009, 04:42 PM
Here is the pedal assembly after I put it back together. Since the clutch switch wasn't broken I will wait till I hang the pedals back in the car to install the switch.
Old 08-06-2009, 04:46 PM
I need some help identifying the clutch Z-bar since I'm not sure if this is the correct one for a 70 Pontiac F-body. I would hate to drop the drive train in and find out this was for a Camaro. Can anyone verify it is correct for my car?
Old 08-06-2009, 05:11 PM
Today I'm working on the door hinges. I had an extra set sitting in a box so I ordered a pin kit for them. I took one of the hinges apart and sandblasted the pieces. I then shot them with blue lightning metal prep and installed the new bushings and pin. The metal prep will prevent the metal from rusting till they are painted. When I'm finished with all four hinges I will drop them off at the body shop to be swapped for the ones on the car.
I was a little pissed off when the pin kit came without any instructions, but it was actually so simple that none were necessary.
ID:	177101   Click image for larger version
ID:	177103   Click image for larger version
ID:	177104   Click image for larger version
Old 08-06-2009, 06:19 PM
Chris, my TA is not in a place where I can get a super good look at the Z-bar, but I looked it over as best I could and it looks just like the one in your pic....
Old 08-30-2009, 11:26 AM
I went by the body shop yesterday and snapped some pics of the formula. It has been stripped to bare metal now. The passenger door is full of bondo so I dropped off a replacement. There is a small patch on the lower drivers quarter panel behind the wheel but it looks to have been a good repair and will not need to be redone. There is a weld seam near the rear bumper on the drivers quarter and I have not idea what was done there. The passenger quarter has been replaced and I think it may have been damaged again afterward because the entire quarter appears to have been replaced but there is old damage and bondo in the sail panel area. It also looks like there is a welded seam along the belt line. Again, it does not make sense. However, the car is in fairly solid shape given it's age. The glass is out now and the window channels are in good shape and will not require any repair. My body man will not be patching anything, he said all the metal is good and he will just repair what is on the car.
ID:	179623   Click image for larger version
ID:	179624   Click image for larger version
ID:	179625   Click image for larger version
ID:	179626   Click image for larger version
Old 08-30-2009, 11:28 AM
More body pics
ID:	179631   Click image for larger version
ID:	179633   Click image for larger version
ID:	179634   Click image for larger version
ID:	179635   Click image for larger version
