#41
I had a 455 short block ready for dynoing the RA-V heads, then I scattered a short block in my SSer and had to use it. Now we are getting another ready. Lynn |
#42
Here are the OEM head pictures with one comparing old and new.
#43
Last thursday we set the record for the fastest time in my 455SD SSer. ;-) Watch us at Indy, we are pretty excited. We are renting IRP for testing next week, that will be fun. (Damn I sound like that extend my unit commercial). Lynn |
#44
I thought this might be helpful to post this email I received with the answers.
Mr. McCarty, you are to be highly commended on your lasting dedication to see this project through, congratulations. the castings look absolutely outstanding, and i'm sure your well thought out changes of them will be rewarding. Thanks! my questions are in regards to application. will they be able to mount factory accessories/brackets and be used in a street capacity? basically, if it fits under a stock hood, runs on pump gas, and is durable with moderate maintenance , it's streetable. * Yes absolutely. We have made several steps to actually make this head more streetable than the original head. o You can run the stock dual plane intake. o intake port reduced for better volumetric efficiency. o reconfigured push rod area to improve carb signal without losing power. o around 75 cc combustion chamber as cast, but we are going to offer a larger and smaller combustion chamber by milling and machining. o standard Pontiac style stud mounted rockers o Stock block bolt on application o All accessory bolt hole locations (same as Edelbrock). o Stock appearance (especially with a can of spray paint). o Offering port match to stock intake flange. o improved water jacket cooling o stock exhaust flange location o reverse water flow will be future offering o stock piston valve relieves (depending on cam and swapping hole for RA-V valve order) o 2 inch to 2 1/4 headers in the works o streetable single plane intake for single 4 or dual 4 o Intake with centrifugal blower/turbo capability i am extremely excited at the possibility of having a "Ram Air V" powered car that i can drive and enjoy. thank you, for bringing this high quality head to market and i wish you great success with your endeavors. Matt thanks Matt Lynn McCarty CMI Motorsports [email protected] 317-839-8378 Last edited by NHRASuperStock455SD; 08-17-2009 at 02:23 PM. |
#45
I think the only better time to be a Pontiac fan may have been 1970. And thats only if i had 30k burning a hole in my pocket.
This is great news for the Pontiac crowd. Heck Im only 36 so I easily remember how difficult it was to get aftermarket Pontiac pieces. Im glad to say Im no tripping over the amount of vendors that devise and manufacture high quality true Pontiac pieces. Thanks!!!
. Mark S . Who needs nice and pretty, when you can have mean and nasty? KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs . So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....and 2023....and 2024.....and 2025.....who am I kidding? there will be no 9s with this engine! >>My 73 Build thread |
#46
Sorry Lynn.....meant comb chamber.
#47
Does stock appearing mean no logo's on the outside of heads. While not trying to fool anyone a logo in the valve train area would make most happier well me anyways. How many pairs are you figuring to do on the first run. Guess the header question was answered is it any company
#48
you going to charge extra to mill or machine for the cc a person wants?
you call yourself HARDCORE but are you truely hardcore
#49
Oh, no problem,
This is the new style comb chamber heart shaped. It is simply killer in %CE. Lynn |
#50
Lynn McCarty CMI Motorsports [email protected] 317-839-8378 |
#51
Lynn |
#52
Perhaps a roots blower intake is on the shelf somewhere...be slow my heart....
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 |
#53
#54
i would be looking for 90-95cc would like to put on a turbo motor.
#55
lynn what size comb chamber as cast or available?
#56
I read #44 thanks.
#57
I will have to get back to you on the bigger cc sizes. Lynn |
#58
By doing this we gain combustion efficiency. Lynn |
#59
I know not all will want to buy new pistons, but it is something to think about if you have that option. Lynn |
#60
Check out what happens behind your side view mirror of a car or truck. If still want some more info, take a look at the new Dart Platinum heads. Or give me a call back. Thanks. |
