#41
Old 07-31-2009, 09:53 PM
turbo69bird's Avatar
lookin good!
960 HP @ 11 psi, 9.70 at 146.
  #42
Old 08-01-2009, 07:31 PM
John Haley's Avatar
John Haley John Haley is offline
I laid up 4 layers of fiberglass cloth and resin. 2 on the actual frame then 2 more over the whole thing.
Lots of cutting and fitting.
I think I will go in and pull the mold apart tomorrow.
  #43
Old 08-02-2009, 04:15 PM
John Haley's Avatar
I have a hood mold!!
Frame mold!
Hood skin mold!!
  #44
Old 08-02-2009, 04:27 PM
ponjohn's Avatar
ponjohn ponjohn is offline
John-
What's next, start laying CF in molds?
Looks great!
  #45
Old 08-02-2009, 04:55 PM
John Haley's Avatar
I am first laying up a fiberglass hood for practice. then I will do a carbon fiber hood.
  #46
Old 08-06-2009, 09:51 PM
John Haley's Avatar
I made the molds for the hood scoops and the other air extractor.
The drivers side scoop mold. I have some minor things to fix.
I will pull the other parts from the molds tomorrow.
  #47
Old 08-06-2009, 10:18 PM
samsdad samsdad is offline
John
I wrote to you through the pro-touring site. Something happened to my login information and I couldn't get your message. Since I'm a Pontiac guy this is better anyway.
Mark
  #48
Old 08-07-2009, 08:01 PM
John Haley's Avatar
Two extractor molds and two scoop insert molds.
Test fitting some carbon fiber.
  #49
Old 08-08-2009, 07:44 PM
John Haley's Avatar
The first part, a driver side scoop insert. The white on the edges is air pockets from not getting my carbon cloth tucked in far enough and not vacuum bagging the part. I can fix the air pockets and I will sell this part as a part that needs to be painted. I think I have just made the best fitting 69 T/A scoop inserts. Monday I will get the vacuum bagging stuff and I hope by the end of next week I have a bunch of nice looking carbon parts.
  #50
Old 08-08-2009, 10:09 PM
ponjohn's Avatar
Awesome!!
  #51
Old 08-09-2009, 12:19 AM
JLHarper's Avatar
JLHarper JLHarper is offline
Hats off to you for taking this project on. You stuck it out and "got er done"!
It was one of the more interesting threads on here in a long time.
From what I see regarding your quality concerns you strive for, you should do very well marketing these.
Did the original steel hood come out AOK from the layup process? That took some guts based on what they sell for OEM.
Best with sales & marketing.....
Jeff
  #52
Old 08-09-2009, 12:53 PM
blackbird455's Avatar
blackbird455 blackbird455 is offline
Send a message via ICQ to blackbird455
NICE!
Have some fun while ya still can !
  #53
Old 08-11-2009, 02:07 PM
Josh69 Josh69 is offline
Nice work John!!
  #54
Old 08-13-2009, 06:27 PM
John Haley's Avatar
Some fiberglass side air extractors.
I had some problems with the clear gelcoat in these molds so I made them in fiberglass.
I also made the other hood scoop insert, It is nicer than the other one but I still had some air pocket problems. I fixed and preped the first one for paint, all it needs now are studs to mount it and paint. It fits perfect.
I am getting better and as soon as I can get these small parts perfect, I will lay up the hood.
  #55
Old 08-13-2009, 09:02 PM
ponjohn's Avatar
What is your method of attaching the studs?
  #56
Old 08-13-2009, 10:45 PM
very nice work.
Looks like it would really help out some of the FAST guys save some weight off the front end. Maybe get a poncho into the ten second club!
  #57
Old 08-18-2009, 07:03 AM
warriorbob warriorbob is offline
I have a question
I am running twing turbos and with the under hood heat the hood its self gets
very hot, I have insulation under the hood to help keep the heat off the hood.
My question is how is Carbon Fiber with heat? Can it take more heat then Fiberglass?
68 400 Firebird Convertible TH400 Solar Red
69 Firebird Convertible Pro Touring Twin Turbo 5 Spd
70 T/A RA III 4 Spd 3:73 Calif Emissions Lucerne Blue
74 T/A SD-455 TH400 Buccaneer Red 49.600 Mile Survivor
  #58
Old 08-18-2009, 09:42 AM
Originally Posted by warriorbob View Post
I have a question
I haven't used fiberglass in high heat situations, but what I can relate to you is that I've had several motorcycles with carbon fiber exhaust cans (mufflers), and they are cool enough to touch. That has been the big draw for using them, no more burnt legs for your passenger. The end-caps and metal straps that hold them on still get hotter than heck, but you can literally grab the can with your bare hand. I probably wouldn't do it on purpose at full song, but if you bump it you won't get a burn.
Sometimes they discolor, or turn 'white-ish', but usually return to their normal color after they cool off. I've never had one warp or separate. Hope that helps.
On a side note, I also have a PT '69 Firebird, only a coupe. I am pretty much done, but I haven't had the time to post the build up on Lat-g or PT.com yet. Do you have a build thread going anywhere, I'm curious to see what you've done.
Josh
  #59
Old 08-18-2009, 10:11 AM
Josh
Josh
Thanks for the info, looks like i definately want to be on the list for one of the Carbon Fiber hoods
My bird is pretty much done (atleast till i find the next goodie to purchase for her)
I have not posted a build thread or even put up any pics of her yet
Hopefully i will post up some info on her soon, when i do i will let you know
Again thanks for the info
Bob
  #60
Old 08-18-2009, 06:20 PM
John Haley's Avatar
I trimmed, installed studs and primered this pair of fiberglass side air extractors. They will need very little work to be ready for paint. I am going to sell this set.
