Old 09-06-2009, 06:04 PM
les74 les74 is offline
Default Identify Clip - 62 Rear Pillar Trim
Hello,
I am very close to finishing up my 62 Tempest Lemans restoration (5 years in the making) and cannot determine what kind of clip/fastener is used to affix the trim that wraps from the rear passenger windows around to the back window. I've attached a picture of the rusted remains of the only clip I found.
Part II: Other than clipsandfasteners.com and restorationspecialties.com, are there better sources for this?
Thanks in Advance ...
MLB
p.s. I will be at Billetproof in Antioch, CA in 2 weeks ... maybe I will see some of you there.
ID:	180371   Click image for larger version
Old 09-06-2009, 10:37 PM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
Les, GM part number is 4657731, clip, back window reveal moulding. section 11.209 in the parts book. Dont know if that helps, but thats the number.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 09-07-2009, 02:09 AM
Keith,
Thanks for getting back so quickly. I think that P/N is for the clips that retain the back windshield itself, not the piece of trim that wraps from the back window to the back windshield. However, your info help put me on the trail to spec'n the right part. The fastener I am looking for has a top width of 7/16" and can slide freely in a 1/2" channel. It appears to be some sort of press fit.
I think I am closing in on it.
Thanks again ...
Les
Old 09-07-2009, 02:51 PM
Les, my parts book shows that number as the clip that holds the reveal molding on. I have a couple of cars with no back window. I will look see if I have any of the clips.
Keith Collier
Tech advisor
POCI.org
Old 09-07-2009, 10:16 PM
Les, couldnt find any clips!! I ran the number through several nos parts site's with no luck yet.
Keith Collier
Tech advisor
POCI.org
Old 09-07-2009, 10:31 PM
Hi Keith,
Thanks for taking a look, I appreciate it. I've posted another picture(s) of what I am looking for. I think I need threaded clips and have to affix them from inside the trunk, but I could be wrong.
Les
ID:	180493   Click image for larger version
Old 09-07-2009, 10:38 PM
AhhhHaaa!!!! Thats different!! I thought you were looking for the clips that hold on the stainless around the back window!!! I think I have some of those!!! Will let ya know!!
I'm back!! I found one set of stainless with one clip!! It does not screw on from the inside. It is a push to connect clip. The way it fits in the trim, it looks like you can use a plastic push pin & trim off the sides of the push pin to make it fit in the trim slot. I have 3 parts cars with that stainless on them. I have no idea if I can get them off without damaging them.
PS!!!!!! I think ya need a bigger set of speakers in the back window!!
Keith Collier
Tech advisor
POCI.org
Old 09-08-2009, 07:31 AM
SDStanley SDStanley is offline
I used some clips from Restoration Specialties- this was the closest I could find in their bins at the Charlotte Auto Fair several years ago.
This photo shows an original clip and one from RS which I trimmed to fit my LeMans trim. Now for the bad news- I don't have the part number for these. Maybe you could send this picture to RS and see if they can match it.
Name:	63 CPillar Trim Clips.jpg
Old 09-10-2009, 05:03 PM
You find anything yet?? If ya want, I can try & pull a set of stainless off & see if they are reusable.
Keith Collier
Tech advisor
POCI.org
Old 09-10-2009, 05:34 PM
Hi Keith,
Thanks for the offer! I am waiting for some nylon moulding fasteners and I am going to cut the round head to fit the slot (the SDStanley technique). If the 5/16" ribbed shaft is maleable enough to fit in the 1/4" hole, then I am done. I should get them this weekend (I hope) and I'll let you know how it goes. I have a short term fix (for Billetproof) which is use some trim adhesive at the show when the car is not moving, but that only has a lifetime of 8 hours.
Thanks,
MLB
Old 09-11-2009, 06:03 PM
John in Minnesota's Avatar
John in Minnesota John in Minnesota is offline
Went to my parts car. They were so rusted they fell apart when I pryed on them. Good Luck. John
