#2121
Old 09-14-2009, 09:36 PM
Brewster's Avatar
Brewster Brewster is offline
Well that 73 sd got up to 105,600.00 without making reserve. Wonder if he has a deal going off-line in order to save some big ebay money(good for him) ? seems like something going on without any last minute activity.
  #2122
Old 09-14-2009, 10:02 PM
SD73's Avatar
SD73 SD73 is offline
BUMP ~ Anyone with any ideas on this???
Originally Posted by SD73 View Post
Hey Guys, got an odd one for you. A friends 1973 SD has this valve on his intake. Originally it was screwed into the drivers side of his intake. It was thought to be originally there because it was a low mileage car. Under 40k at time of purchase. What looks like the metal version of the egr thermal valve was on the passenger side of the intake. His restorer reversed them.
I've never seen one of these with that odd looking connector on the bottom (check what I have circled in red in the first pic). Any idea what this is and a definitive answer as to which side it's installed on? My first thoughts were this was for the EGR, but then I thought that connector looking thing may actually be a vent that the valve for the distributor advance control has. Any insight would be appreciated.
The second pic is the type I usually see for EGR. Later ones were made of metal with a reduced sized upper portion.
  #2123
Old 09-15-2009, 07:27 AM
Brewster's Avatar
My automatic car has the metal type which I believe to be factory installed due to the cars low mileage and original motor.
I must say I have never seen the one circled but always thought the plastic ones where the later versions ? it probably came off another series car that had some luxury options.
Interesting to know,
Brew
  #2124
Old 09-15-2009, 09:19 AM
Brewster's Avatar
Here is a 74 SD on epay that is close to EvBoCo but yet never seen?
http://cgi.ebay.com/ebaymotors/Ponti...ht_1293wt_1167
I wonder what she'll bring ?
  #2125
Old 09-15-2009, 11:44 AM
sd455hota's Avatar
sd455hota sd455hota is offline
It's been for sale on the Hemmings site for some time. FYI, as of last saturday $50K would buy it. That amount may have changed by now since he already has one bid of $49K-if it's actually a legit bid.
  #2126
Old 09-15-2009, 12:38 PM
Brewster's Avatar
Here is another 74 SD but this one with such low milage already has a replaced fender on it.
http://cgi.ebay.com/ebaymotors/Ponti...#ht_500wt_1182
If cars could only talk !
  #2127
Old 09-15-2009, 06:40 PM
ramair3formula's Avatar
ramair3formula ramair3formula is offline
Passenger door looks it has a new skin also.
1972 Trans Am white with blue deluxe interior
1974 SD Trans Am white with tuxedo interior, earliest known 74 SD vin#
1976 50th Anniversary Trans Am
1970 Judge ra3 4 speed pepper green
  #2128
Old 09-15-2009, 09:10 PM
bhakola bhakola is offline
Default Firewall Holes
Hi everyone,
Here is my firewall with the holes that I need to fill. I believe #6 is for the ground, #5 is for a resistor. The other holes I am not positive, but I believe that #1 and #2 need to be filled also, 3 and 4 I have no idea. Any help would be greatly appreciated.
Bryan
  #2129
Old 09-15-2009, 09:47 PM
SD73's Avatar
Brew
Thanks Brew. Here's more clarification. He has that metal one too. It was on the Passenger side, where it should be. This oddball plastic one was on the Drivers Side. His restorer switched them presumably because he's never seen anything like that before and thought it was on the wrong side.
My car, which is a very early built SD has the plastic version of the EGR thermal valve, btw. It has an early date code on it that follows suit. I'll have to ask my friend to check the date code on his valve if he can and to see if it has any EGR marking on it too.
I've seen a lot of poncho engines, and have never come across anything like that one in the picture.
  #2130
Old 09-17-2009, 12:44 PM
SD455DJ SD455DJ is offline
SD73 - I have the exact same pieces you show in your photo's, with the EGR/CARB labeled one located on the passeger side of the water crossover. I believe they are original to the car, but I'm not 100% certain. My SD is a 4 spd and built the 3rd week of July. Hopefully that helps.
Ken - thanks for the cam information. I feel real fortunate to have a true early HO Racing designed cam for an SD. My brother and I have HO's entire newsletter collection from the mid 70's to teh last issue in 1979(?). They are fun to re-read, especially the classieds where 73/74 SD's were for sale for $4000 for low mileage cars.
Larry - I'm with you. I will install that HC-62 with new lifters (I'm not sure about installing new Rhoades, but maybe another make that aren't so clakky sounding). Your '73 SD clone was sweet looking and quick with that low of compression. I too have the "long" single trough SD replacement pistons from TRW that are pretty heavy compared to todays Ross or JE's. Not sure I'd get down to the 12's, but it's with a try.
Norwood - I probably won't do the big bird decal, even though I like them. The original owner told me that it wasn't orderd for the car. The dealer ordered it without the hood bird because the dealership owner didn't like the fact it as a big decal and could peel off in a car wash (which were pretty brutal back in those days). In fact the original owner doesn't remember the small nose bird on the car when he owned it. Who knows????
takid455 - I really like the idea of an in-progress class. I believe that GTOAA used to have one unofficially. I gravitate to the cars that are original and/or barn finds no matter how rough they are. Patina in good.
Anybody going the the Pure Stock Drags in Stanton, MI this weekend? If you are, I'll be teching in the Pontiacs. Stop by and introduce yourself.
DJ
  #2131
Old 09-17-2009, 03:47 PM
SD73's Avatar
SD455DJ, are you saying you have both those installed on the same intake? Your's has the one with that little vent thing on the bottom? Is that correct, is it a vent?
Thanks a lot for our help!
  #2132
Old 09-17-2009, 09:58 PM
SD73 - Yes, my cars intake had both of the thermactor valves in your pictures. The one you are questioning is on the drivers side and the EGR/CARB valve is on the passenger side. I'm not sure that anything attaches to that port on the bottom that you circled. As you suggest, it may be a vent.
DJ
  #2133
Old 09-17-2009, 10:13 PM
SD73's Avatar
Thanks for the help, DJ! That one was driving me nuts! If you get a chance some time, could you post a pic? I'd love to have another for my reference.
  #2134
Old 09-18-2009, 09:51 PM
SD73 - I'll try to get photo's the next time I get to my brothers where I store the car, so it might be a while. We are busy this weekend with the Pure Stock Drags with close to 150 cars teched in today. Pontiacs are leading the single make count by a large margine with many running in the mid 12's such as Paul Aragona's '74 SD455 TA and Chuck Lumbardi's '73 SD455 Formula. Rick Mahoney's '68 RAII Firebird is the 5th quickest at 11.82. The #1 qualifier is Julie Pennington's L88 Corvette at 11.72. Tomorrows weather is going to be better.
DJ
  #2135
Old 09-18-2009, 09:58 PM
Brewster's Avatar
Got to love those early ram air cars, for a first gen I have to admit they turn me on big! Ricks car was just in last months HPP running the strip.
  #2136
Old 09-18-2009, 10:15 PM
Wareagle's Avatar
Wareagle Wareagle is offline
Smile
DJ
Pulling for Rick's RA II --He's closing in on the L88.
  #2137
DJ
Sweet car. In fact, a lot of nice Pontiacs out there. I thought the SDs were surprisingly scarce...
  #2138
Old 09-19-2009, 12:58 AM
Brewster's Avatar
You have to love that thing pulling out of the hole popping the wheels off the pavement. WOW, how cool is that,
Brew
  #2139
Old 09-19-2009, 08:49 AM
superdutybob's Avatar
superdutybob superdutybob is offline
Brew
Brew:
Your car might do that too. You should drive it sometime and try. LOL Heading to a local car show with Dick and Bill.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
  #2140
Old 09-19-2009, 07:46 PM
rwinkles's Avatar
rwinkles rwinkles is offline
Talking
Originally Posted by superdutybob View Post
Brew:
SUPERDUTYBOB wins again!! First in class at the Bob Sellers show here in town. Congrats SDB!
Dick Winkles
1970 RAIV GTO 4-speed
1974 Original owner Z-28 4-speed
2008 SRT10 Viper Very Orange (was SD TA!)
2015 Challenger Hellcat 6spd (was SD TA!)
