#101
Old 09-16-2009, 12:25 AM
MotorCityTA MotorCityTA is offline
Hands down - letting an R&M paint rep talk me into using water born primer.. on a 72 Maserati. Ever seen paint come off in 8" slabs?
  #102
Old 09-20-2009, 05:42 PM
BigCat4spd's Avatar
BigCat4spd BigCat4spd is offline
Sandblasting inside my shop. OMG! I had no idea how much dust is created. I will never begrudge ones singel dollar paid to anyone who does blasting for me from now on.....if I ever find another good blaster.
My old reliable went out of business, so I decided to do it myself. Results were good but that's pretty hard work. Cleaning up my shop is going to be a monumental task, whenever I get to that point.
  #103
Old 09-22-2009, 12:36 PM
rohrt rohrt is offline
Resto blunders,
I can relate to many that were already listed, but here are a few of my own.
Bending my own SS break lines. Ended up replacing them all. You guy warned me too.
Not test fitting panels because they were used not aftermarket, thinking why wouldn't they be a perfect fit.
Piecing out my suspension vs getting a kit.
Piecing out my breaks vs getting a kit
Not measuring in the front sub frame with the factory manual and just using the allignment holes.
Using Stove Bright paint to paint the engine. Won't burn off the heads but it will rust through in a few months.
Not changing out the fuel sending unit when I had the gas tank out the last three times.
Not bench testing the Ralley Gauges to verify I had all the connections working before installing.
Doing the Guldstrand mod after the front end was together.
Using grease on the speedo cable rather then graphite.
Trying to rebuild my power steering pump. Not sure what went wrong. Ended up buy a AGR pump.
Who said getting Divorced in the middle of it. Yeah I can relate.
Using factory correct battery cables, 660CCA Delco Battery and starter on my 455. I wonder why I have hot starting issues?
I'm sure I could add several more if I thought about it long enough.
Now we need a What did you do right thread. Its a much shorter list for me.
  #104
Old 09-22-2009, 03:26 PM
carcrazy carcrazy is offline
Starting another one!!
  #105
Old 09-22-2009, 03:49 PM
70 Lemans's Avatar
70 Lemans 70 Lemans is offline
Not having a sound plan.
Not having $$$.
Not having time.
Not having proper tools.
All in all things get done sooner or later.
Finish date before I kick the bucket.
69 400 Block, .030 over, KRE eagle stroker kt, KRE,CNC ported e-heads 310 cfm, port match RPM , comp roller 236/[email protected] 586/600 lift 110 LS. 1.5 HS roller rockers, 350 Transmission, Red Neck tight 3500 stall converter, Ford 9” with 3.75’s, Strange center section, Moser 31spline axels, 29”Mt slicks, HRPARTSNSTUff anti roll system, Doug’s Headers 3.5” collectors, 22”Dynomax mufflers w/ H-pipe, Cliffs Q-jet, Fuel cell with sumps, Mallory 140 fuel pump and filter. Denny’s 3.5” drive shaft.
  #106
Old 09-22-2009, 07:52 PM
rememberfireball#22's Avatar
rememberfireball#22 rememberfireball#22 is offline
Default Latest Blunder - Today
Have been repainting my 68 Goat in my one car garage. Have not started car in the 2 1/2 months that I have been working on it. After the spraying of paint I left car where it was for the color sanding,buffing, interior cleanup, and just general cleanup and detail. I have a sissor jack that makes body work much easier. I have had three back surgery's and the jack enables me to work on rockers and lower area of car without having to bend over to bad.When I though I had finished this weekend I wanted to drive car and show it off because it did turn out beautiful. When I started car it is hard to describe the noise. It sounded like someone trying to beat their way out of a barrel with a sledge hammer.I looked and could not find any reason for it. My first cousin has a first class mechanical repair shop about 8 miles from me. I called him and he said he had a drive on rack free if I wanted to bring car down and work on it myself. I went and got his rollback and carried my car to his shop. To make a long story short, when I jacked car up with sissor jack I had placed the rubber foot on the left side of the trans crossmember instead of the frame and bent it up toward the floor. This mashed the driveshaft and front u-joint up against the floor. Evertime the driveshaft turned over, the u-joint cup would impact the floor.My point is, with me anyway, I am an ongoing blunder. Now I have the car on frame machine and will pull crossmember back in place tomorrow morning.
  #107
Old 09-22-2009, 08:28 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
#1 - Starting a restoration on a car that is in pieces already, and alot of those pieces are missing. Most of the missing pieces ar small, expensive items that were not really worried about at the start of the resto.
#2 - Taking only the parts needed to do the work that is to be done (I.E. brought the car from my parents house & left alot of the bigger/akward items there until I needed them), then parents house catches fire & all is lost. Best to take everything at once & just find places to put them.
#3 - not setting a budget in the 1st place.
Even though these were my biggest blunders, the resto worked out great & all the aggravation was worth it in the end. I actually ended up spending twice what I originally planned on. I'm still into it pretty good, considering I got the car for nothing.
I'm mentally ready for my next resto project, just not financially ready.
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
  #108
Old 09-22-2009, 10:37 PM
eaglesan13 eaglesan13 is online now
Biggest mistake, not starting with a bigger garage. It's hard to do a frame-off nut and bolt resto in a 2 car garage.
  #109
Old 09-29-2009, 10:18 AM
Judas Judas is offline
If it makes you feel any better, I am working in a single car garage (a small one that cannot house a truck) & carport. My parts are stored in a shed and in the basement.
Fun!
-J
"If you can’t fly then run, if you can’t run then walk, if you can’t walk then crawl, but whatever you do you have to keep moving forward."
  #110
Old 10-06-2009, 11:41 PM
Old Bird's Avatar
Old Bird Old Bird is offline
The first pontiac motor I rebuilt when I was about 16 in the parking lot of a apartment. After getting it all back together it ran good but the timing was all over the place. Thats when I found the cam retainer in the bottom of a box. Ran great after the second tear down and retainer installed.
  #111
Old 02-21-2010, 12:57 AM
70&71 TRANSAM OWNER 70&71 TRANSAM OWNER is offline
Paying in advance to have rear Quarters and sale pan installed, Never did get it done
  #112
Old 02-21-2010, 07:20 PM
6t7goat 6t7goat is offline
Welding up some body panels and not covering my vent windows or windshield. Weld spatter makes nice black pitts in glass. Had to replace vent window and windshield.
  #113
Old 02-21-2010, 09:02 PM
wytnyt's Avatar
wytnyt wytnyt is offline
hmmm ive never had a blunder
but if you believe that,,,ive got a bridge for sale
  #114
Old 02-21-2010, 09:05 PM
wytnyt's Avatar
Originally Posted by ctehan View Post
7.) Working all day, falling asleep under the car and waking up startled, only to bash your forehead on an oil pan...
oh,can i identify with this one
  #115
Old 03-01-2010, 05:33 PM
Anselcop Anselcop is offline
I was restoring a 2 door 68 Chevelle that had a bad frame.....Found a new frame on Craigs List and drove 2 hours to pick it up. The owner of the frame said that it was a from a 1971 Chevelle coupe and had the old rusted body/shell sitting along side of the frame. I took the frame home, sandblasted it, painted it, bolted on all of the new suspension, installed the re-built rear-end and stood back and admired my work. My pride came to an end when I tried to install the new brake lines and they were 4-inches too short.....I found out that I restored a 4-door Chevelle frame, not a 2-door!! Anyway, after spending $500 at the local frame shop to get it shortened and a quick re-paint, I now have a 2dr frame.
PS.....my wife bought me a new tape measure for Christmas!
Dan
1969 Ram Air III 4-speed
1963 Lemans Convert #'s Matching 326 V-8
1949 Pontiac Silver Streak
  #116
Old 03-01-2010, 06:27 PM
Old Goat 67's Avatar
Dan
I applaud you sir!
Most would NEVER tell of such a blunder. Good for you in fixing it.
Charles
  #117
Old 03-01-2010, 09:07 PM
wytnyt's Avatar
im doing a 68 mustang vert for my boss.the old paint only had a couple cracks in the paint but overall very solid.
being picky he had me strip it,,wow a real bondo buggy
spent most of the day pulling and rolling out dents that were just filled in
not my blunders but i did inherit them
  #118
Old 03-14-2010, 08:03 PM
66 LeMans's Avatar
66 LeMans 66 LeMans is offline
Buying a Lemans convertible while living overseas.
getting a 389 engine from Ebay, that "runs and is in perfect condition"
Getting all the parts for the 389 engine.
Getting it overhauled.
Buying a rear axle on ebay and have it shipped to the Netherlands.
Put a th400 longtail in a 66 lemans.
Actually, do all the above without having a garage!!!
engine, trans, rear axle.. all are overhauled and practically better than new, but... never again!!!
Oh, one more... put flex brakelines from Goodrich in the car.. it sure makes em Good.. ans especially RICH!!! Auch!! my wallet!!!!
No fun restoring an american car when living overseas... $$$$$$$$$$$$$$$
But, still love my car... I hope to get it running in about a month
If you don't like the way I drive, get off the sidewalk.
  #119
Old 03-15-2010, 03:30 PM
x-bird2 x-bird2 is offline
buying a car that needed restored ....8 years later buying an even worse rust bucket ....first is not finished, neither is the second )))
  #120
Old 03-27-2010, 04:13 PM
Mark1968 Mark1968 is offline
Poor planning, doing things out of order.
Not taking enough pictures.
Bagging and tagging, can never do this enough.
Most of this comes from never having done this before, not knowing what is right and how something is done.
The next one will go better, right?
