Old 10-05-2009, 07:18 PM
gtome's Avatar
gtome gtome is offline
Thats gettin pretty hot. I dont like to see mine go over 200. Thats gettin pretty hot for a stock low compression engine.
Have you checked your jetting?
Also there is a mod the guys are doing with the new water pumps that are giving good results. Do a search for that, it should help alot.
Old 10-05-2009, 10:16 PM
66Mutt 66Mutt is offline
My 1994 Olds has always run about 210 deg. My '66 Pontiac runs around 210 deg, but then I have a 195 deg thermostat.
I would not be worried about it.
Doug
Old 10-06-2009, 07:17 PM
62Lemans
Guest
Posts: n/a
Youve raised my curiosity. What temp would you expect for 11:1 compression? How much higher?
Old 10-06-2009, 10:35 PM
gtome's Avatar
No clue? And that was a generalization. Im sure it has to do with more than just the compression.
Maybe we could get someone to throw some shaved 400 heads on their stock 455 and see if the temps go up?
