Old 11-11-2009, 12:42 PM
69 redbird's Avatar
69 redbird 69 redbird is offline
Default blower keeps trippin?
I have a 69 FB convert. and my A/C works fine as long as i don't switch it to high? If i put it on high it will work for a little while, then blows the fuse under the hood by the alt.? I went from a 10amp to a 30amp and the 30amp lasted a while, but then also blew that one too?
any idea's on what to check? and how?
Old 11-11-2009, 12:46 PM
george kujanski's Avatar
Possibly the blower motor siezes up after a while or there is a bare spot in the wiring that grounds while driving.
george
Old 11-11-2009, 01:02 PM
69 redbird's Avatar
Default blower
Being that it will run all day on the other two speeds? I don't think the blower motor?
I will keep checking the wires???
Old 11-11-2009, 01:33 PM
johnsma22's Avatar
johnsma22 johnsma22 is offline
If I'm not mistaken, when the blower motor is on any speed other than high, the current flows through some resistors to slow the motor speed down. When on high, the full current is going through the motor windings. Am I correct? The increased heat and speed could cause the bearings to get tight and increase the amp draw above the fuses current rating.
One thing you NEVER want to do to try and correct a motor blowing its fuses is to up-size the fuses above the motor's current rating. That's a good way to melt wires and start a fire!
John
"There are no stupid questions, but there are a LOT of inquisitive idiots!"
Old 11-11-2009, 02:01 PM
I agree with the description of operation from John. Just something to check...
I had a blower where the outside ring of the plastic squirrel cage fractured and when on high, would expand and rub against the blower housing to the point where it wore a groove thru it. At lower speeds, it was normal.
george
Old 11-11-2009, 02:51 PM
spyder spyder is offline
alt fuse for that circuit is 30 amp, not 10amp.
Old 11-11-2009, 09:21 PM
wheelspin's Avatar
Arrow A/c high blow fuse.........
I would replace the 30A fuse on the alternator (only used for the high blower speed) with approximately 6" of 16ga. fusible link wire (soldered, of course). The fusible link section will simply heat up when the alternator surges, instead of a fuse which will continue to blow each time the amperage spikes.
I was fighting the same problem until Mick (lust 4 speed) explained the advantages of the fusible link setup.
Les
Les Iden
Old 11-20-2009, 02:42 PM
69 redbird's Avatar
Default 30A
I didn't know that was supposed to be a 30amp? I guess the guy who owned it before me, had the wrong fuse? I will try the fusable link and see how that works.
Thanks,
