#41
Old 11-11-2009, 03:00 AM
68grandprix 68grandprix is offline
The bearings are Clevite. Jim
Sometimes I think about how much more money I'd have if my car got better mileage, but when I hammer the gas and I smell that tire smoke........I remember that I also spend a lot of money on tires.
  #42
Old 11-11-2009, 12:21 PM
wheelspin's Avatar
Question What's up?
Jim,
What's the machinist say?
By the way, the SCCPOCI monthly mtg. is tonight @ 7:30 in Brea, and the SCGG (Southern Cal. gathering of Goats) club mtg. is next Weds. night @ 7:30. You could come to my house and we could drive down to Brea/Paramount together for the dinner mtgs. and you could meet some of the SoCal Pontiac folks. PM me for my phone #, if you are interested in attending one or both of these mtgs..
Les
Les Iden
  #43
Old 11-11-2009, 06:03 PM
vidguy's Avatar
vidguy vidguy is offline
Curious:
What did you torque the Rods to? These have the 7/16 8740 wave-loc bolts correct? I have those rods.
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
  #44
Old 11-11-2009, 06:15 PM
Ken K Ken K is offline
The rods I used did not have wave lock bolts. I can't rember what I torqued them to but I think it was around 63 ft lbs. I used a 10/10 crank. I could not feel much tension turning it over until I had the 5th piston in it. It turned over easy with just 4 pistons in it. I used Clevite bearings.
  #45
Old 11-11-2009, 06:19 PM
webfoot's Avatar
webfoot webfoot is offline
I think the factory torque spec for those bolts is 43 ft lbs.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
  #46
Old 11-11-2009, 07:20 PM
The torque for the PPR rods is 75ft/lbs. It says that on the order sheet. Jim
  #47
Old 11-11-2009, 08:20 PM
I know I didn't torque mine to 75 ft lbs. 63 ft lbs is stuck in my mind. 7/16 inch rod bolts is basicly what a performance BB Chevy uses.
  #48
Old 11-11-2009, 08:27 PM
Been quiet. Could this problem be STD bearings uses on a Crank with -10 on the Rods?
  #49
Old 11-11-2009, 08:40 PM
If he removes the bearing halfs the number will be on the backside.
  #50
Old 11-12-2009, 12:42 AM
67bonnie455 67bonnie455 is offline
Default Solid lifters?
Did you put solid lifters in the motor?
  #51
Old 11-12-2009, 01:32 PM
I took the block, rods/pistons and crank to the machine shop yesterday. The owner(Beaver)measured the crank right there and said the mains had some taper, but were standard. He said it should have been ground(I told the previous builder this, he said it would be fine)and it will now be ground .010".
Beaver thinks the rod damage is most likely from detonation, although he hasn't checked the rods yet. He also said the detonation could have been caused by oil leaking through the valve guides, so I will be taking the heads in today to get checked out. The rings also show signs of washout, like the engine was running too rich, although I checked the plugs after the first day of my trip and they looked perfect.
So, the rods will be checked and resized if necessary, crank turned, mains checked and align bored if necessary, cam bearings checked/replaced, new rod/main bearings, piston rings, bottle brush hone cyls, block cleaned and hot-tanked, valve guides checked, new gasket kit, motor assembled by me(it'll be my first bottom end assembly)and I'm looking at about $1000, and I don't know if it'll run on pump gas. I asked about piston dishing, Beaver says no-go on the Speed-Pros. Jim
  #52
Old 11-12-2009, 01:33 PM
The lifters are Rhoad's. Jim
  #53
Old 11-12-2009, 01:41 PM
If the problem might be detonation, why don't you go to the next bigger size chamber on the heads. You can just as easy get a set of bigger chamber heads rebuilt before you assemble the engine.
  #54
Old 11-12-2009, 01:53 PM
torqhead's Avatar
torqhead torqhead is offline
I wouldn't claim to be an expert here Jim, but something doesn't sound right. First if it was detonation you would have heard it, without a doubt, unless you were running open headers/exhaust. The whole thing about bad valve guides which allows oil leaking past them causing detonation I've never heard of (could be my ignorance). That problem is going to cause foul plugs and smoking when u first start the engine, but I don't think detonation. I would be leary at this point with the machinist, don't know the guy from "adam" but a number of machinist out there are very good about taking peoples money and that's it.... Best of luck.
  #55
Old 11-12-2009, 03:42 PM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
Have it rebuilt by a PONTIAC GUY. Take it as a lesson learned.
  #56
Old 11-12-2009, 05:48 PM
Lightfoot's Avatar
I'm not an expert either, but here are my thoughts of what Beaver said about the valve guides (possibly) leaking & causing detonation:
I think that he is theorizing that the unwanted oil being burned would eventually cause carbon in the CC which would result in 'hot spots'. Then you have pre-ignition.
My own experience with worn valve guides is that it usually only causes smelly exhaust in a closed throttle @ road speed senario.
I had a '66 Chevy with 283 that detonated terribly, but I sold the car without ever finding out the cause. It ran beautifully up until the last couple months that I had it. Under 70K original miles. And I was feeding it leaded gasoline (1979).
Seeking recovery of my stolen 1988 Buick LeSabre T-type. Primary summer driver & Road Trip car.
Garnet Red with 2007 PENDOT inspection stickers on windshield. Had minor damage to left rear quarter & bumper. Last three of VIN: 301
Could be being driven with altered VIN.
Bodywork on left rear quarter (near the tail light) would be a tip-off.
Last seen by a patrol officer doing a routine plate check in Gary, Indiana, August 31, 2009
(The thieves were driving, but my plate was clean.)
  #57
Old 11-12-2009, 07:01 PM
Big Injun's Avatar
Big Injun Big Injun is offline
You have a great local resource in Ken Brewer at Pacific Performance Racing at 310-832-4596.
As for your pistons, you can mill a grove the depth of the valve reliefs. I have done that on another 400 and it works great.
Dave "Big Injun" Anderson
[email protected]
www.4mypontiac.com
For GTO Celebration items click the tile coaster.
  #58
Old 11-13-2009, 11:11 AM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
Excessive oil consumption WILL cause detonation. If those are forged Speed-Pros they CAN be dished. HO racing used to dish them and sell them right out of their catalog. Get a new machinist!
  #59
Old 11-13-2009, 11:54 AM
Default Not so sure
I am not convinced detonation took out the bearings. It certainly would not be from leaking valve guides. Think of how many motors are running with worn out valve guides and no bearing failure. If the mains show scoring I would still be thinking oil pressure. If the mains are perfect, then I would be thinking rods too tight or maybe detonation.
The kind of detonation that can hurt bearings comes from NOx not set up correctly. We sold hundreds of 231v6 motors and they didn't run correcly unless they spark rattled loudly like you were going to break a piston. No bearing damage. I think the kind of compression damage to bearings would have shown other problems like hard to crank or locking up, severe spark nock, etc.. That my experience so I am just not convinced it was detonation.
I asked about the lifters thinking of a problem with the oil pressure to the bearings. (like solids without restricters). Does anyone know if you can put in the wrong cam bearing?
The other thing I thought of is a plugged oil filter. After breaking in a coated cam, you need to change the oil filter or it becomes restricted. The last thing is an exploded oil filter. I have seen this take out a motor. With the oil filter bypass plugged off, if the oil filter is not flowing properly, oil pressure to bearings suffers. The gauge showing pump pressure before the filter.
A few thoughts.
