Old 12-21-2009, 06:27 AM
Marcel's Avatar
Marcel Marcel is offline
1981 Lemans, full interior including back seat, functional power
windows,door locks,tilt wheel and console with full dash.Car is certified to
8.50.
3920 lbs race weight.
Rear: Non tubbed, Ford 9" 3.73 gears, ladder bars, 28x10.50 Hoosier slicks
on Weld rims, 12 way shocks.
Front: Tubular arms, factory springs meant for the weight of a 6 cylinder
engine, drag shocks. Full inner wheel wells, 4 whl disc brakes.
Turbo 400. 3800 stall. trans brake.
1-7/8" headers that go into a 3-1/2" full length exhaust(including rear tail
pipes) with mufflers.
SD Performance built(thanks Dave!)541 c.u. in. IA II block. N/A. 10.90-1
compression, SD Performance wideport E-heads.
PUMP GAS.
I finally got the engine installed in late September of 2009 or in the words
of my business partner and builder of the motor, Dave Bisschop; We finally
completed Marcel's 541 wideport E-headed engine, or should I say I finally
let him have it after using it for 2 years of R&D testing!! LOL. We got it
to the track on a cold Friday October 9 which was the last test and tune
before the track shut down for the season/winter. We only had time for a few
shake down runs.Track prep was poor, but we did manage to run 6.22 @
110.5mph in 1/8th and close to a full pass laid down a 9.93 @ 136mph
spinning off the line(we got booted off at this point as none of has a Comp
licence and we had been warned after our 1/8th mile pass) The engine dynoed
at 815hp on pump gas @ 6700rpm, 9.70's or quicker won't be a problem in 2010
with a bit of tuning and seat time.
Once we have the car dialed in on the motor, then we are going to try a
little 250- 400 shot of spray(Dave built this as a nitrous motor for me)
I do drive the car on the street(and not just to the corner store and back)
as my kids love going for rides and have had zero problems doing this.
I have attached copies of the time slips(car # J673) and some photo's of the
car. Hopefully, I did the attachment(s) correctly.
Marcel
ID:	191498   Click image for larger version
Name:	interior shot from drivers side.jpg
ID:	191501   Click image for larger version
Name:	full car shot.jpg
ID:	191502   Click image for larger version
Name:	time slips.jpg
Old 12-22-2009, 01:24 AM
badassgoat's Avatar
badassgoat badassgoat is offline
Hey Marcel, on the SD web site I TOLD you Dave would get you bounced from your local drag strip for going faster than your tech. He did it to me last season at Englishtown...several times when I was still racing my 69 goat. That car was almost the same exact weight as your LeMans and I eventually went a 9.80 @ 139 after you guys did my WP's, Victor, and specced a new cam. If I could have left harder on the brake, I'm pretty sure it had a tenth or two left in it. Anyway, congrats on getting your ride to the track finally and laying down some 9 second passes. Happy holidays to you and please pass those wishes on to Dave and Lisa as well.
PS: did Dave get his hands on a set of the new Victors yet?
69 'Blackbird'
535 CID IA II SD Wide Port E-head Pro Systems Dominator
