Ta eric has it. exhaust side has definitely been gasket matched. Intakes are pretty much on the money for stock. On the intakes you might see a bit of core shift offset and or a bit of a gap at that point in the divider between the ports, otherwise they're a nice casting. are these a match set of heads? the one image of the intake does actually look like it has been worked, the second pic looks stock. they may have been gasket matched as well. the SD heads respond nicely to shallowing out the radius on the short turn going down to the chamber.
73 Trans Am Red/White #'s match 4spd...... sold 69 Firebird 400 conv #'s match AT Blue wht/wht 06 Vette conv Red/Red/Blk |
No physical differences in the castings for all of the SD heads, no matter the date code. I take it these are a pair you picked up along the way, not with an original SD car? (I remember you were selling SD engine/parts awhile back) It's kind of hard to tell from the pics you've posted, but if you look at the exhaust ports, you can see definite porting/grinding marks on the outer portion, deeper inside you can see the original as-cast surface which is a bit "pebbly" appearing. I wouldn't worry about there being much difference porting wise between this pair
