Old 01-17-2010, 05:12 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Default Frame:chop-chop
To put some larger headers on my car Jon Gunter is cutting out the frame and going to install a removable tube in between the frame and also put a mid plate in it.
I will be going to 2-1/8"th to 2-1/4" headers and a 4" collector.
[email protected]. 3460#s
Old 01-17-2010, 05:13 PM
LiL Jack's Avatar
One more!
And that is an All Pontiac front plate in the car.
Old 01-17-2010, 05:25 PM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
LJ how big were your old headers?
Old 01-17-2010, 05:37 PM
TOP 452's Avatar
TOP 452 TOP 452 is offline
Send a message via Yahoo to TOP 452
Taken some wt out Jack
Old 01-17-2010, 05:43 PM
Gach's Avatar
Gach Gach is offline
Holy $h.it you where racing that with out a mid plate! Good deal, now you'll be able
to drop the pan with out taking the motor out.
Old 01-17-2010, 05:46 PM
LiL Jack's Avatar
2" Headman headers for 67-68 fireterd.
Don, after we put everything back I lost about 8#'S.
Old 01-17-2010, 05:49 PM
LiL Jack's Avatar
I just put a front plate in it half way through 2009.
Old 01-17-2010, 05:51 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Jack are you running Tigers?
Old 01-17-2010, 06:13 PM
Superchief455's Avatar
Superchief455 Superchief455 is offline
Jack,
have any pics of the removable tube and mid plate installed? Thinking i'm going to have to do something similar to get the big tube stepped headers to fit in my chassis.
Old 01-17-2010, 06:56 PM
LiL Jack's Avatar
Nah, just those junk E-head wide port.
I should have some pics of the removable center tube, mid-plate and rack soon.
Old 01-17-2010, 07:15 PM
If you could post them when you have them i would appreciate it... thanks
Old 01-17-2010, 07:22 PM
John Langer's Avatar
John Langer John Langer is offline
Why put a removable center back in if you have a front and mid plate?
Old 01-17-2010, 07:43 PM
PONTIAC DUDE's Avatar
Post
Jack. When I did my 65 Pro Street GTO. I cut from frame rail to frame rail and just installed a bent bolt in U shaped tube in moly to connect one side to the other plus the motor plate. Then a piece of straight steel for the lower control arm mount. Took over 25/35 lbs out if i remember correctly. But measure everything before you cut the center out with the lower control arm mount so you can get your lower arm geometry right. I also installed a rack and 70 Chevelle disc brakes.
I'll see if i have pics I know I took back then.
Old 01-17-2010, 07:56 PM
LiL Jack's Avatar
I was over there a few days ago and we could not get the pan out without making a removable center bar. My oil pan is a 7 quart Moroso.
Even with a small "dip" in the center bar.
Old 01-17-2010, 08:06 PM
So dont put one in, you don't need it. Read between the lines ya jacka$$.
Old 01-17-2010, 08:15 PM
With the center of the cross-member cut out, you don't have a lot of support to keep the side rails from twisting on impact with the ground. Putting in the removable center bar will keep that from happening. The camaros and firebirds have additional support at the front of their frames (another cross-member) to help in this situation. People still install the removable support on those cars in most cases. The tube doesn't have to be very large, just stiff enough so that it doesn't bend from the forces pushing towards the center of the car. There is a lot of leverage on that lower arm trying to go inward and upward, diaper boy.
Tom Vaught
Old 01-17-2010, 08:23 PM
Tom Vaught
OK, I have dropped my car more times then lil jack has kids and i dont have a removable x-member. You dont need it. I have a rigid engine limiter welded to what ever is remaining of my stock x member that bolts up to the stock engine mount on my block. It is not adjustible and slides in and out every time like a glove. If you look at his picture, he reinforced the stock x member with steel, that is what is done to mine. No theory here, just practical experience. I dont have a removable x member, i have dropped my car numerous times, you dont need it.
Old 01-17-2010, 08:24 PM
The motor and mid plate are what will prevent the frame from twisting as well as the strut bars form the roll cage. The radiator support will offer additional support as well.
Old 01-17-2010, 08:46 PM
So does your f-bird still have the "second cross-member" in front of the normal crossmember, still or did they cut both of them out john?
Link is to show example of location of second crossmember for f-bird only.
http://www.speedtechperformance.com/...158/prd158.htm
Tom Vaught
Old 01-17-2010, 09:05 PM
The front x member was completely removed and a piece of moly tube was put back in its place to mount the rack. There is an integrated "crash bar" mounted on this bar that triangulates back to the lower control arm mounting point for reinforcement. The "crash bar" is the lowest point on the front of my car and what hits the gound and absorbs the impact.
