Pushrod hole on a #76 head.
Pushrod hole on a big valve head.
Intake ports #76 head.
Intake ports #16 head.
The information below reflects the research conducted by Pontiac enthusiast/ author Pete McCarthy, much of which is from his book, Pontiac Musclecar Performance 1955-1977, as well as information gathered from many other Pontiac enthusiasts world-wide. Information about PMD heads is still being gathered. What is apparent is that while Pontiac had policies and specifications, both seemed to fluctuate as need be to build engines and place them in passenger cars.
Chamber size of heads is given as an approximate CC as is static compression. When examining any Pontiac head today it requires an open mind. All chamber sizes should not be assumed but cc'd to confirm the chamber size. I wish to point out that Pontiac manufactured heads with push-in studs and screw-in studs using guide plates. Most if not all performance heads used screw-in studs. Today machinists can easily improve on any stock iron Pontiac head with the inclusion of hardened seats, screw-in studs, longer valves, taller installed height for after market springs working with high lift camshafts. Porting remains a viable means of improving flow for increased power. Most importantly, one must know the overall condition of the heads before attempting any performance modifications. Be sure to have them cleaned and magnufluxed by a competent machine shop. If you have any information that may be useful in improving this head chart, please email me at: [email protected] Year CID Advertised HP Head casting # Valve Sizes intake/exhaust Approx CC or static CR 1959 389 215-345 hp 531395 1.88/1.60 69 1960 389 215-345 hp 536109 1.88/1.60 69 389SD 348-363 hp 535461 1.92/1.60 69 1961 389 all 538177 1.88/1.60 69 421 all 538177 1.88/1.60 69 389SD 368/373 hp 540306 1.92/1.66 68 421SD 368/373 hp 540306 1.92/1.66 68 1962 389 all 538177 1.88/1.60 69 421 all 538177 1.88/1.60 69 389SD 385/405 hp 540306/544127 1.92/1.66;2.02/1.76 68 421SD 385/405 hp 540306/544127 1.92/1.66;2.02/1.76 68 1963 326 250 hP 543797 1.88/1.60 8.6 cr 326 260/280 hp 548232 1.88/1.60 10.25 cr 389 215/230/235 hp 543796 1.88/1.60 8.6 cr 389 267/283/303/313 hp 543797 1.88/1.60 10.25 cr 421 320 hp 543797 1.88/1.60 10.75 cr 421 353/370 hp 9770716 1.92/1.66 72 421SD 390/405/410 hp 544127/9771980 2.02/1.76 64 1964 326 250 hp 9773345 (845) 1.88/1.60 8.6 cr 326 280 hp 9773395 1.88/1.60 10.0 cr 389 215/230/235 hp 5437796 1.88/1.60 8.6 cr 389 267/283/303/306 hp 9773345/(845) 1.92/1.66 10.5 cr 421 320 hp 9773345/(834) 1.92/1.66 10.75 cr 389 325/330/348 hp 9770716 1.92/1.66 72 421 350/370 hp 9770716 1.96/1.66 68 1965 326 250 hp 62 1.88/1.60 8.6 cr 326 285 hp 22 1.88/1.60 10.5 cr. 389 256 hp 75 1.88/1.60 8.6 cr 389 290/325/333 hp 76 1.92/1.66 10.5 cr. 389 335/338/360 hp 77 1.92/1.66 10.5 cr 421 338 hp 76 1.92/1.66 10.75 cr. 421 356/376 hp 77 1.92/1.66 10.75 cr 1966 326 250 hp 094 1.88/1.60 8.6 cr 326 285 hp 095 1.88/1.60 10.5 cr 389 256 hp 091 1.92/1.66 8.6 cr 389 290/325/333 hp 092 1.92/1.66 10.5 cr 389 335/360 hp 093 1.92/1.66 10.5 cr 68cc 421 338/350 hp 092 1.92/1.66 10.75 cr 70 cc 421 356/376 hp 093 1.92/1.66 10.75 cr 68 cc 1967 326 250 HP 140 1.92/1.64 9.2 cr 326 285 HP 141 1.92/1.64 10.5 cr 400 255/260/265 HP 142 1.92/1.64 8.6 cr 400 290 HP 143/061 1.92/1.64 10.5 cr. 400 325/333 HP Big Car 143/061 (closed chamber) 1.92/1.64 10.5 cr 400 350 HP (GP) 670/9787671/187 2.11/1.77 72 cc 400 325/335/360 HP 670 (closed chamber) 2.11/1.77 72 cc 400 325/360 HP RA 670/97 (closed chamber) 2.11/1.77 72 cc 428 360/376HP 670/9787671 (closed) 2.11/1.77 72 cc 1968 350 265 HP 17 1.96/1.66 8.6 cr 350 320 HP 18 1.96/1.66 10.5 cr 400 265 HP 14 1.96/1.66 8.6 cr 400 290/340 HP Big Car 15/215 1.96/1.66 10.5 cr 400 350 HP (GP) 16/ 216/ 62 2.11/1.77 72-75 ccs 400 330 HP (FB) 16/ 216/ 62 2.11/1.77 72-75 ccs 400 335/350/360 HP 16/ 62 2.11/1.77 72-75 ccs 400 335/360 HP RA I 31/ (37) 2.11/1.77 72 cc 400 340 (FB) /366 (GTO) R/96/ A (RA II) (rd port) 2.11/1.77 72 cc 428 375 HP 16/ 216 2.11/1.77 72 cc 428 390 HP 16/ 216 2.11/1.77 72 cc 1969 350 265 HP 47 1.96/1.66 8.6 cr 350 325 HP 48 2.11/1.77 10.5 cr. 400 265 HP 45 1.96/1.66 8.6 cr 400 290 HP 46 1.96/1.66 10 cr 400 340 HP (GP) 16/ 62 2.11/1.77 72 cc 400 330,335,350/ 366 HP 16/ 62/ 48 (MT) 2.11/1.77 72cc 400 345(FB) /370 (GTO) 722 (RA-IV) 2.11/1.77 71 cc 428 360 HP 16 (small-valve ) 46 1.96/1.66 10 cr 428 370 HP (GP) 62 2.11/1.77 72 cc 428 390 HP 16/ 62 2.11/1.77 72 cc 400 375 HP(RA-V) 44 Tunnel Port 2.11/1.77 67 cc 303 RA=V Tunnel Port 546184 2.11/1.77 56 cc 1970 350 255 HP 11 1.96/1.66 8.8 cr 400 265 HP 11 1.96/1.66 8.6 cr 400 290 HP 16 (small valve) 1.96/1.66 10 cr 400 330 HP Big Car 16 1.96/1.66 10 cr 400 330 HP 12 (MT) 2.11/1.77 72 cc 400 330 HP 13 (AT) 2.11/1.77 72 cc 400 345 HP(FB/RAIII) 12 2.11/1.77 72 cc 400 350 HP (GP) 13 2.11/1.77 72 cc 400 350 HP (GTO) 12 (MT) 2.11/1.77 72 cc 400 350 HP (GTO) 13 (AT) 2.11/1.77 72 cc 400 366 HP (GTO) 12 (RA III) 2.11/1.77 72 cc 400 370 HP (RA IV) 614 (Round Ports) 2.11/1.77 71 cc 455 360 HP Big Car 15 1.96/1.66 87 cc 455 360/370 HP (GTO/GP) 64 2.11/1.77 87 cc 1971 350 250 net HP 94 1.96/1.66 96 cc 400 265 net HP 99 1.96/1.66 98 cc 400 300 net HP 96 2.11/1.77 96 cc 455 280 net HP 98 1.96/1.66 114 cc 455 325 net HP 66 2.11/1.77 114 cc 455 335 net HP (455HO) 197(191) (Round Ports) 2.11/1.77 111 cc 1972 350 175 net HP 7H1 1.96/1.66 7.6 cr 400 200 net HP 7J2 1.96/1.77 8.4 cr 400 250 net HP 7K3 2.11/1.77 96 cc 455 200 net HP 7L4 2.11/1.77 114 cc 455 250 net HP 7M4 2.11/1.77 114 cc 455 250 net HP 7M5 2.11/1.77 114 cc 455 300 net HP(455HO) 7F6 (Round Ports) 2.11/1.77 111 cc 1973 350 150/175 net HP 46/4C 1.96/1.66 96 cc 400 170/185 net HP 46/4C 1.96/1.66 98 cc 400 200 net HP 4x/4C 2.11/1.66 98 cc 400 230 net HP (AT) 4X-7H screw-in studs likely 2.11/1.66 98 cc 455 215/250 net HP 4X-1H screw-in studs likely 2.11/1.66 114 cc 455 290 net HP (455SD) 16 (Round Ports) 2.11/1.77 111 cc 1974 350 155/170 net HP 46/4C 1.96/1.66 7.6 cr 350 200 net HP (GTO) 46 (screw-in studs) 1.96/1.66 7.6 cr 400 175/190 net HP 46/4C 1.96/1.66 8.1 cr 400 200 net HP 4X-4H/4C 1.96/1.66 99 cc 400 225 net HP (AT) 4X screw-in studs likely 2.11/1.66 98 cc 400 225 net HP (AT) 4C 2.11/1.66 98 cc 400 225 net HP (MT) 4X-3H screw-in studs 2.11/1.66 98 cc 455 215/250 het hp 4X-1H screw-in studs likely 2.11/1.66 114 cc 455 215/250 net hp 4C 2.11/1.66 114 cc 455 290 net HP (455SD) 16 (Round Ports) 2.11/1.77 111 cc 1975 350 ALL 5c/ 6X 2.11/1.66 7.6 cr 400 ALL 5c/ 6X 2.11/1.66 7.6 cr 455 AIR 6S 2.11/1.66 7.6 cr 350 HO non-air 6H 2.11/1.66 7.6 cr 1976 350 ALL 6X-4/ 6S 2.11/1.66 7.6 cr 400 ALL 6X-8/ 6S 2.11/1.66 7.6 cr 455 AIR 6S 2.11/1.66 7.6 cr 455 HO non-air 6H 2.11/1.66 7.6 cr 1977 301 ALL 01 1.72/1.50 8.2 cr 350 ALL 6X-4/ 6S 2.11/1.66 7.6 cr 400 180 hp 6X-8 2.11/1.66 7.6 cr 400 200 hp 6X-4 2.11/1.66 8.0 cr 1978 301 ALL 01/02 1.72/1.50 8.2 cr 350 ALL 6X-4/ 6S 2.11/1.66 7.6 cr 400 180 hp 6X-8 2.11/1.66 7.6 cr 400 220 hp 6X-4 2.11/1.66 8.1 cr 1979 301 ALL 01 1.72/1.50 8. 2 cr 400 220 hp (MT only) 6X-4 2.11/1.66 8.1 cr |
source ..... previous post is from Wallace race web site
How do these heads differ. 092, as I understand,were put on big cars and 093's on GTO's. If I exchanged 093's for 092's would I gain horsepower?
