It "should" be 100% if it was an installed SR block. There are "blank" SR blocks still floating around. Those have been and still are being vin stamped and used to restore cars to "numbers matching" status. They are considered "Correct" replacement blocks and the general consensus has been that they are one step ahead of a used replacement block with a different vin as far as valuation is concerned.
Any ideas as to legal recourse, or is this another case where the system is designed to protect the criminal?
I bought this car from Jack Nichols, who has been in this hobby a lot longer than me and he is way more familiar with this car since he restored it. When an honest person sells a car they show a pic of every scratch, dent , bump etc. so that after the sale thay can wash their hands of it and not have to worry about a bunch of drama. None of these issues with the engine and trans were disclosed to me, and believe me, I asked. I think people like to play word games. When they list it, original is synonymous with #'s matching but when you ask a question as to something being original, I guess that can mean a lot of different things! |
Both "very original" and "numbers matching rebuilt engine" were used in the same paragraph. By the reasonable man standard, that clearly leads you to believe it has a factory original engine. Or, you could run a poll here, and use us as expert witnesses: "100% of members who responded agreed that this sale was fraudulent." And, if the seller is indeed an expert in these cars, he would have to be held to a higher standard than, say a less informed seller who claimed ignorance.
Many years ago an auto theft investigator I knew showed me how he used acid to raise VIN's that had been ground off. It was a long time ago so I don't remember exactly how he did it, but I know it can possibly be done.
If they truly used an SR block on your car, and just restamped it at the dealership, it might be hard to prove your case, since all you will have are our opinions. However, if they ground numbers off a used block, and you could prove it, you might have a good case. Have you discussed your findings with the seller yet? If not, I would recommend that first. |
Jack is out of town until tomorrow. I'm going to try and call him this afternoon to discuss how to make this right. He has a 70 TA, 70 Formula and a 67 GTO in his garage now so I'd say he knew the block wasn't the original #'s matching block. Hell, it may have taken me a few months but I never laid eyes under the hood of a Pontiac til this one showed up in my driveway and, I figured it out. The trans is not restamped. It's out of a 70 Grand Prix.
Did every SR block get stamped from the factory as such or could it have been a bare block? Is there a way to have it authenticated...Machine shop maybe? What is the fair market value of this car now? Mind you, it is NOT very original. Wrong block, trans, carb, distributor, starter, alternator, even the air cleaner is a SR; it's not an original 70 air cleaner. I'm thinking $9-10K if it's a restamp, $12-13 if it's a legit YZ SR block. But how do I know it's an SR for a YZ block? Even if it has 4 bolt mains they could have been added during the rebuild When I get back to the house I'll start tearing this thing down. I want to get in there and make sure the VIN on the body is correct as well
The acid trick..Use Muratic acid. Home Depo sells it in their lawn and garden dept(sure Lowes does also) as a concrete ckleaner. Tip.. get a container of whater, mix a bunch os baking soda(remember the yellow box you put in the refrig to keep smells down?) and shape it up. This neutralized the acid. If any gets on your hands,just put your hand in the soda soilution..it will bubble rapidly, but will stop the acid immediately. Actually use this to clean the area after applying the muratic acid using a clean shop towel.. Please post a link to the original Ebay acution.. I want to see it in detail.. |
Guys... if you look closely at the YY Z stamping, to the right of the Z you can see the remenants of a MUN last digit being an 0. Chris sent me directly pictures and when blown up to a full screen, it is there.
Secondly... the factory used a stamp holder that could hold up to 10 characters,they would interchange the numbers as needed. Being a July 1969 Dated block, this is not a SR block. The stampings,due to being all in a single stamp(you can still buy these stamps, I have one) all of the numbers will be on the same axis plane,not all over the place. Sorry guys.. the dealers never did,and still do not, care about numbers as much as we all do. Not at all. I recall my alternator on my 2001 truck went out under warranty with in 6 months of purchase( I got the car in October 2000, so we were still in the middle of the 2001 model year), it was replaced. I had written down the number on the alternator, the new one was a complete new number. Asked them what the deal was... they looked at me like I had 4 ears... "numbers"... it is the same model alternator, works ...what is your concern now Mr. Oxley?? I was told.. Felt sort of stupid,considering it was a 2001 Truck.. But still... the same response would have been given back then. Dealerships sent warranty requests in for an engine, if it did recieve a VIN stamp, it was done in the engine shop who approved the warranty replacement. Plus, July 69 is the 1st run of 70 model 400 engines.. Seriously doubt that was a SR block. Also, I may be wrong on this, but I thought the SR stamop was ground down near the block's 9799914 casting number and hand stamped,sort of like the "5" was on RAIV engines. I could be wrong on this one, but still don;t think I am.. Thirdly.. the concentric lines on the timeing cover pad.They are way too close and almost look straight. The ones I have seen have as much as 1-3mm spacing, not right next to each other and are in a large swirling pattern. The entire front face was cut with a single grinding stone, so the lines would be enough apart to include both sides of the timing cover. I bet the opposite side is higher off the face of the block and have different lines. . This was an attempt to make the stampings look original. This idiot knew what he had. There is a reason it did not have the correct alternator, distributor,carb and a Grand Prix TH400. What are the odds the alternator, carb and distributor all were bad also?? Ibet if Chris will list the numbers of the alternator, distributor and carb that come with teh engine...we will find they were assigned originally to a GP..I be tthe engine came from a GP.. I am sure this comment will make some enemies,but who on earth believes the dealers took the time to stamp an engine from a warranty relacement?? No, they sent the request in, when the new one was delivered...they installed the short blaock that GM sent them and that was it. I have said this before, GM wasn't building watches,and still don't. Numbers are important at time of production,and to distinguish varying spec's inside a componant, but the line guys and dealers could care less about the numbers. THIS IS A POORLY DONE RESTAMP.. The PQ TH400 tags have been floating around for some time. Actually I think Parts place had some made,they come with mounting tabs and all. So the tranny could have been done better, the stampings are still available. The stamp is expensive(>$500) but they are available. The font on the numbers are exact same size, shape etc.. I have never restamped an engine,and don;t plan on it...but I know I could have done a better job than this idiot.. Chris needs to look at the hidden vin number on this car. Somuch is wrong, i susoect it never was a true RAlll Formula car.. |
Did you request pictures of the engine #'s before you bought it?
Plus I'm active duty Army. I was shot through the knee during a firefight in Baghdad back in 2003 and subsequently had my leg amputated just above the knee. Yes, I'm still active duty. I've jumped out of a plane with my prosthesis and everything else. No big deal. Anyway, I qualified for a one time $11K auto grant from the VA, which I used to buy this car. The VA sent him a check directly for the $11K and I sent the rest after that. I never imagined he could be ripping me off knowing the circumstances. I wonder if that makes this a federal offense? |
I never knew this story of yours. The check you sent me for restoring the carb and distributor...I am refunding 100% of that. I WILL NOT accept your money,. guys like you bring tears to my eyes. I wish I was brave enough to do what you have done, truth be told.. when I was 20 something I was so damn self absorbed...just don't think I would have given of myself as you have. It is guys like you who allow us our freedoms.. If this jacka$$ trys and stick you with this car, I think there will be a small army of pontiac guys after his a$$.. Of all people to rip off a brave american hero.. And yes, that is what you are.. I know... most guys like you don't want to be called heros, just doing your job... but damn'it you are a hero.. Oh how mad I am now that i read your bagdad story... SOB in Florida... |
'68 GTO 4-spd Hardtop (11) '68 GTO Convertible AT (1) '70 LeMans Sport Land of Lakes Muscle Car Classic Facebook Event Facebook Wall (Kurt Smith,Minneapolis) |
