Old 03-14-2010, 09:04 PM
njsteve's Avatar
njsteve njsteve is offline
3M Strip-Caulk is the official name of the stuff. It is 3/8 thick by 1 foot long strands of black rubbery, non-hardening caulking that is designed for auto body seams and a million other uses.
http://www.autobodytoolmart.com/3m-s...8-p-10395.aspx
The center section did not have much of any adjustment. The main adjustment was in the end caps both outward to the sides, and twisting to fit the quarter line. Adding the strip caulking around the stud mounting bosses is what really helps the fit. It squashes down flat but that 1/64 of an inch may be all that it takes to get the spoiler end caps to align properly and create the right gap. It also waterproofs the large mounting holes.
Also, do not crank down on the mounting nuts too tightly. It is very easy to break/crack the spoiler mounting bosses on these old fiberglass pieces.
Old 03-16-2010, 07:11 PM
njsteve's Avatar
Started her up and drove her around the driveway this evening. Looks almost finished from this angle.
Old 03-18-2010, 09:06 PM
thefirebirdm@n's Avatar
thefirebirdm@n thefirebirdm@n is offline
Send a message via MSN to thefirebirdm@n
Steve, thanks for the info. I don't think there's anything under my end caps now and I did not realize there was that much adjustability with them. I always assumed the end caps sit where they sit and you have to play with the trunk lid adjustment to get the center to match the ends. I'll pick some of this stuff up and give it a shot.
Jimmy
www.firebirdgallery.com
2002 WS6 M6 Trans Am - original owner
1973 Trans Am 455/4-speed
1971 Formula 400/400
1969 GTO 400/400 - 3rd owner
1968 Firebird Convertible 350/200R4
POCI - AAC
