#1041
Old 03-14-2010, 09:04 PM
njsteve's Avatar
njsteve njsteve is offline
3M Strip-Caulk is the official name of the stuff. It is 3/8 thick by 1 foot long strands of black rubbery, non-hardening caulking that is designed for auto body seams and a million other uses.
http://www.autobodytoolmart.com/3m-s...8-p-10395.aspx
The center section did not have much of any adjustment. The main adjustment was in the end caps both outward to the sides, and twisting to fit the quarter line. Adding the strip caulking around the stud mounting bosses is what really helps the fit. It squashes down flat but that 1/64 of an inch may be all that it takes to get the spoiler end caps to align properly and create the right gap. It also waterproofs the large mounting holes.
Also, do not crank down on the mounting nuts too tightly. It is very easy to break/crack the spoiler mounting bosses on these old fiberglass pieces.
  #1042
Old 03-16-2010, 07:11 PM
njsteve's Avatar
Started her up and drove her around the driveway this evening. Looks almost finished from this angle.
  #1043
Old 03-16-2010, 09:37 PM
Brewster's Avatar
Brewster Brewster is offline
Steve, Looks like a great evening to bring that car outside and enjoy it.
Hope I get the chance to see it in person sometime ?
Cheers,
Brew
  #1044
Old 03-18-2010, 08:18 PM
72TAMAN's Avatar
72TAMAN 72TAMAN is offline
HI Steve
I'm new just register yesterday .NICE CAR !!!! . Follow this thread for the last few months now. I will be starting to restore the same car 1972 trans am white blue stripe vin# 2V87X2N506632 in he near futur .Thanks for all info
  #1045
Old 03-18-2010, 08:53 PM
superdutybob's Avatar
superdutybob superdutybob is offline
Steve
The car looks fantastic. I hope to see it in person some day. TA Nationals this summer or maybe the POCI in Charleston WV?
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
  #1046
Old 03-18-2010, 09:06 PM
thefirebirdm@n's Avatar
thefirebirdm@n thefirebirdm@n is offline
Send a message via MSN to thefirebirdm@n
Steve, thanks for the info. I don't think there's anything under my end caps now and I did not realize there was that much adjustability with them. I always assumed the end caps sit where they sit and you have to play with the trunk lid adjustment to get the center to match the ends. I'll pick some of this stuff up and give it a shot.
Jimmy
www.firebirdgallery.com
2002 WS6 M6 Trans Am - original owner
1973 Trans Am 455/4-speed
1971 Formula 400/400
1969 GTO 400/400 - 3rd owner
1968 Firebird Convertible 350/200R4
POCI - AAC
  #1047
Old 03-18-2010, 10:31 PM
bossbirdta's Avatar
bossbirdta bossbirdta is offline
72TAMAN,
im guessing that with a vin# like you posted your car was built 09D????
Originally Posted by 72TAMAN View Post
HI Steve
  #1048
Old 03-18-2010, 11:15 PM
72TAMAN's Avatar
check body tag you,re right O9D is the build date
  #1049
Old 03-18-2010, 11:23 PM
72TAMAN's Avatar
Question? body tag as number 216 stamp for trim . Not able to find that number . found number 261 ( black vinyl deluxe) is it a mistake or what
  #1050
Old 03-18-2010, 11:36 PM
x-bird2 x-bird2 is offline
the 216 is for a 221 custom ivory interior. you have to add a 2 to the front and drop the last digit to get the correct code.
  #1051
Old 03-19-2010, 12:03 AM
72TAMAN's Avatar
custom ivory interior??? interior is totally black
  #1052
Old 03-19-2010, 09:15 AM
Brewster's Avatar
Did you get your phs to compare with ?
  #1053
Old 03-19-2010, 09:20 AM
Brewster's Avatar
  #1054
Old 03-19-2010, 11:14 AM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
it's easy to get the 2's and 1's mixed up on the interior codes since Pontiac made it a bit of a puzzle. You drop the "2" at the front and add the "1" to the end. The 216 becomes 161 standard black vinyl.
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #1055
Old 03-19-2010, 02:30 PM
bird72's Avatar
bird72 bird72 is offline
Lookin great Steve
Honeycombs + No Trim Rings= Cool
not that I am biased or have them that way on mine too..... plus 72 honeycomb grilles is icing....
72 Bird
  #1056
Old 03-19-2010, 10:37 PM
72TAMAN's Avatar
No phs yet wil be sending for it soon .Not sure what info. will get with phs order because car was ship to Canada
  #1057
Old 03-20-2010, 05:45 PM
njsteve's Avatar
Celebrating the first day of Spring 2010! I have only been working on this car for 23 seasons.
I just got back from my first actual drive of the car in six years!!! Prior to today the only drive I ever took it on was the original test run around the block when I bought it on 11/11/2004.
I buckled my 9 yr old son in the passenger seat and we snuck the car out and drove it around the neighborhood for about 4 miles, through all 4 gears and all 4 barrels.
I dont know what all this hoopla is about the M22 rockcrusher making whining noises. It is relatively silent compared to the industrial, cast iron, A-833 four-speed in my Charger.
The T/A does have a bit of pep, I must say.
As usual, my boy interupted my enjoyable, celebratory test drive with his sarcastic: "That's enough speedy-fast, Dad. Let's go home and throw the baseball around"
Kids. They just don't appreciate good fun!
Here's the offspring about 5 years ago (or as the boy says: "When I was a kid") installing the body on the subframe.
  #1058
Old 03-20-2010, 06:25 PM
Congrats Steve!! I can imagine what a 6-year wait must feel like because I'm working on a few years of resto on my '73 and '69 GTO as well albeit NOT 6 years.
Jimmy
POCI - AAC
  #1059
Old 03-20-2010, 08:20 PM
165th's Avatar
165th 165th is offline
Wow, over 6 years of work. Congratulations... I'm thinking about the drives I took in mine before I started her teardown. I can't imagine what that feeling is like after the journey you took.
Enjoy!
  #1060
Old 03-21-2010, 05:28 PM
njsteve's Avatar
Couldn't wait any longer. After staring at that refinished steering wheel in my clothes closet for years now, I finally installed it this afternoon.
Now the back half of the car is finished, and the middle half of the car is finished. Just need the front half finished and I am finally finished with all three halfs of this Cecil B. Demille production.
(P.S. Fractions was one thing I was never too good at in school)
