Old 03-20-2010, 10:26 AM
cnc's Avatar
cnc cnc is offline
Default grout removal
Ok whats the best way to remove this stuff any help is greatly appreciated....Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 03-20-2010, 11:10 AM
Bjorn's Avatar
Bjorn Bjorn is offline
from what?
In mortar joints? on used brick? on floors?
or?
all I know is from used bricks , you just knock it off with a hammer holding the brick in one hand...
if on stone/tile floors you can chisel it off, but dep,. on what its on...
you need to describe more.
FireBjorn
http://FirstGenFirebird.org/show/closeup.mv?CarID=221
breathe and enjoy it , life is temporary
69 Firebird convertible
71 Triumph TR6
Old 03-20-2010, 11:23 AM
cnc's Avatar
cnc cnc is offline
Sorry bout that your right its floor tile grout I have a hand held grout tool that u manually cut the grout out just looking for some kind of other source of removal....
Old 03-20-2010, 11:39 AM
69*Goat's Avatar
69*Goat 69*Goat is offline
Go buy yourself a Dremel... If you don't have one. Dremel makes a grout bit for grout removal...
It will save you a lot of time, but I warn you......
You better wear a dust mask
Old 03-20-2010, 11:43 AM
OhMyGoat's Avatar
OhMyGoat OhMyGoat is offline
Try a tool like this. It attaches to a Dremel tool.
http://www.sears.com/shc/s/p_10153_1...0070921x00003a
Or this blade that you can put on your grinder.
http://www.amazon.com/Fein-635021180.../dp/B0000223PL
X2 on the dust mask
Alan
Tomorrow is often the busiest day of the week.
Old 03-20-2010, 05:32 PM
goathead455 goathead455 is offline
X2 on the dust mask
That is not a blade for a grinder,it is for a Fein multitool which vibrates.
Dremel does make a multitool now which is much less expensive than the Fein,the multitool would probably work better than the rotary tool.
If you do go with the rotary tool,get quite a few bits.
Old 03-20-2010, 05:54 PM
OhMyGoat's Avatar
Thanks for the correction. Just trying to help.
Alan
Old 03-20-2010, 05:57 PM
No problem,I just wouldn't want him to get that blade and put it on a grinder.
Old 03-21-2010, 06:44 AM
6t7gto's Avatar
6t7gto 6t7gto is offline
http://www.johnbridge.com/vbulletin/index.php?
Old 03-21-2010, 10:07 AM
cnc's Avatar
cnc cnc is offline
Just went on the link to Johnbridge guys suggested diamond blade on a grinder tried that and its the cats ass it will take out the majority of it then I can fine tune by hand thanks people for the help..Chris
Oh and went and got some masks too
Old 03-21-2010, 11:18 AM
That will work but be carefull that the grinder doesn't get away from you and scar the tile.
If you have someone to help you,get them to hold a vacuum next to the grinder to suck up most of the dust.
If you don't do that,it will get so dusty that you will have trouble seeing.
Make sureyou cover everything.
Old 03-21-2010, 02:51 PM
cnc's Avatar
cnc cnc is offline
I'll be careful slow and easy and thats what the wife is for holding on to the hose....
Old 03-21-2010, 10:28 PM
69gp400's Avatar
69gp400 69gp400 is offline
why are you removing the grout? if its the color you don't like you can dye it.i se a razor knife held at an angle.
