Old 03-24-2010, 11:27 PM
1FAST GTO's Avatar
1FAST GTO 1FAST GTO is offline
Unhappy Impala 2005 Problems
Wife decides she wanted a newer car. So she brings a 2005 Impala home. It has a bad case of torque steer when you give it a little throttle. It also seems to wander, always having to correct back and forth. Very annoying. Anyone else have any issues with these newer Impalas?
Old 03-24-2010, 11:30 PM
PMDRACER's Avatar
PMDRACER PMDRACER is offline
Get the front end checked for alignment, and possibly a CarFax. It may due to previous damage. Also look for overspray where the paint may have been touched up after a wreck.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.
-RONALD REAGAN
462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg
Old 03-24-2010, 11:38 PM
1FAST GTO's Avatar
Carfax was clean, I will take a closer look anyways. Thanks
Old 03-25-2010, 12:45 AM
RS72LEMANS's Avatar
RS72LEMANS RS72LEMANS is offline
torque steer is probably from the motor mounts shifting. brake torque it from reverse let off then drive let off then reverse again while someone watches the mounts... Also vertical control arm bushings in front pull thru and can cause it. Have seen cv axle shafts cause a similar issue but not near as often.
Old 03-25-2010, 09:43 AM
IOWA552SLOW IOWA552SLOW is offline
We do a lot of control arm bushings on the newer W-body cars. I would look at those very closely.
Old 03-25-2010, 09:59 AM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
V8 SS?
Old 03-26-2010, 11:02 PM
1FAST GTO's Avatar
Talking
Originally Posted by Mr_GTO View Post
V8 SS?
Wife brings the car home = V6
Husband = V8
Old 03-27-2010, 12:08 PM
V8 SS?
The ss in 05 was a supercharged 3800. little extra grunt but no v8.
Old 03-27-2010, 01:02 PM
1FAST GTO's Avatar
Correct, 06 was the first year. This was a wife decision to bring this piece of crap home!
Old 03-27-2010, 01:07 PM
sleepy's Avatar
sleepy sleepy is offline
240 hp as opposed to the 200 hp of the standard 3800 series II.
FWD will always give a little torque steer but the wandering is cause for some concern.
I would take it to a good alignment shop and tell them to check the car thoroughly for evidence of damage.
Why is he not suspended?
Old 03-28-2010, 12:48 AM
OhMyGoat's Avatar
OhMyGoat OhMyGoat is offline
W-bodies are known for broken sway bars in the front. The end where the link connects can rust and split, eventually breaking off. An easy check.
Alan
Tomorrow is often the busiest day of the week.
Old 03-28-2010, 01:05 AM
RS72LEMANS's Avatar
true but sway bars dont cause torque steer...
Old 03-28-2010, 01:39 AM
OhMyGoat's Avatar
My bad. Any movement of the motor can cause torque steer. The hydraulic motor mount is prone to leak and collapse. I'd check that too. It's an easy fix.
Alan
Old 03-28-2010, 10:06 PM
RS72LEMANS's Avatar
I learned about torque steer real easy when I had my srt-4. Stage 3 moper kit on it with air-shifter would change lanes on me whenever i reached 15-20psi boost. Wholeshots smoked the engine mount bushing twisting the engine in the cradle under acceleration. That change in axle geometry caused a severe pull to the left it would literally "jump" lanes
