Old 04-03-2010, 07:40 PM
PonTeaYackChick's Avatar
PonTeaYackChick PonTeaYackChick is offline
It's got 4-10 gears, and has a posi. My Day looked at the flex plate and it just lost a bolt and another of the three was loose. The frame mounts are good too.
~Miranda~
Wish list: 1.) 2002 WS6 Ram Air 6sp. TA Well a 99 will have to do.
Old 04-03-2010, 09:15 PM
So you bought a Camaro CLONE to build a Trans AM CLONE? I'll have to think that one over.
Seriously, leave that 12 bolt under it parts are generally cheaper to buy for them and it's a stronger unit than the BOP diff.Not that you'll beat on it.
Looks like a decent builder for a rust belt car. A little duct tape, some tinfoil and Bondo and you'll be all set! Right Mike [ Region Warrior]? In fact it looks a lot like his when he bought it.
former." --Albert Einstein
- Winston Churchill
Old 04-03-2010, 11:00 PM
MikeNoun's Avatar
MikeNoun MikeNoun is offline
Cool car! Just a few notes....
Yes, all 1969 Firebirds had 160 mph speedos. Looking at your trim tag, looks like Code 72 72, which would be Carousel Red. The 8th digit in your VIN will tell you whether it was a V8 or L6. If the 8th digit is a '1', it's a V8. If it's a "6", then it's an L6.
No 12-bolts in the 67-69 Birds, but the Chevy 12-bolt is worth some money. I have a B-O-P 12-bolt (bolt in axles) in my 69, believed to have come from a 70 Trans Am.
A lot of parts from a 69 Camaro fit, but most are incorrect (visually) for a Firebird. Most of the 1969 Firebird parts are unique to the 69 Bird, so be prepared to start seeing parts catalogs that list a part for "67-68" or "70-up", and the special 1969 parts are usually at a premium.
Old 04-03-2010, 11:28 PM
Pontiaddict1's Avatar
Pontiaddict1 Pontiaddict1 is offline
72 72 also means that it most likely did not come from the factory with a vinyl top as you feared... thats a good thing.
You still plan on pulling the PHS docs so as to know what you purchased? I would.
4.10 gears are not very good behind a Pontiac, but, I sure would not give up the 12 bolt rear end. No matter what. Just have it rebuilt with something more streetable 3.55 or 3.23.
Looks good otherwise MA, I will rummage thru some boxes, I have one of the light buckets...
Old 04-04-2010, 10:06 AM
Her right one is busted up beyond repair, I think the left one is ok or might have a small crack.
~Miranda~
Old 04-04-2010, 10:08 AM
My Mom is a stickler for the correct look, so not sure that 12 bolt will be staying. I came home last night and she was on her back on the trailer, under the car taking the traction bars off. LOL Threw em in a pile next to the trash can LOL.
~Miranda~
Old 04-04-2010, 10:25 AM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
Congrats on the purchase.
I too want to build a '69 T/A clone, but mine will be a few years off in the distance. I need to build a bigger garage 1st before I start adding to my collection. I'm not letting the current toys sit outside while I restore another one
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
Old 04-04-2010, 10:51 AM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
Why is she throwing away money that could be spent on the car? Everything she pulls off should try to be craigslisted.
Old 04-04-2010, 11:33 AM
FireBrdRestorer's Avatar
FireBrdRestorer FireBrdRestorer is offline
We will try and sell them, she just threw them there after taking them off lol. Maybe we'll bolt them on Miranda's KIA
Mike G. (or MaryAnns Boss)
I don't have my own Pontiac yet, but sometimes she lets me drive hers.
Old 04-04-2010, 11:35 AM
Well there's one for sale in Bangor PA we walked away from with a $1800.00 stacked guage cluster in it. To far gone for my Wifes liking to restore. it's in the classifieds here, under 69 Hardtop, MaryAnn posted pictures.
Here is the link.
http://forums.maxperformanceinc.com/...d.php?t=622157
Old 04-04-2010, 11:56 AM
Well just get rid of the aluminum cover and replace with a stock steel piece and it will look much better.
Old 04-04-2010, 07:22 PM
6 Grrrs's Avatar
Here is the link.
Thanks for the heads up, but as I stated, it'll be a few years before I get into another big project. I'm enjoying the GTO and making plans for a nice garage. I currently have a 2 car residential garage that I do all my work in/store my GTO, Truck, & bike in. It is starting to get overrun by my 3.5 yr old's toys.
Tod Hoffmann
2002 Honda VTX1800C
Old 04-04-2010, 08:17 PM
Originally Posted by marxjunk View Post
Its a 68 or 69 Camaro multi leaf 12 bolt...a very expensive rear..especially if it has a good gear set....run the codes..i just sold a bare 69 12 bolt housing for 900 bux and the guy was glad to get it.....ive seen drum to drums with 3.55 posi bring 2 large ( thats 2 grand...2thousand bux...clams...well ya get the idea)..70 12 bolts are wider, and the pads are so far apart ya cant bolt it in the car...
But really..id leave it under there....its a a good start to a high performance build...
So how exactly how would one know what gears are in a rear? The guy who had this car told my Mom that it has 4.10 gears, but where is that number or how do you know this info for sure? Where are "the codes"?
~Miranda~
Old 04-04-2010, 08:20 PM
I like learning this stuff too, as I will be helping with this project.
~Miranda~
Old 04-04-2010, 08:56 PM
abefromen's Avatar
abefromen abefromen is offline
Code may be stamped on the front of the RH axle tube but the gear set could have been changed out so thats not foolproof.
You could jack up the rear and count how may times the driveshaft turns while turning the rear wheel one full revolution.......that'll give you an idea what the ratio is.
Or pull the cover and see whats stamped on the ringgear.
Old 04-04-2010, 09:04 PM
4dblnkldude's Avatar
OUT WITH THAT CHEVY!!!!!
Old 04-04-2010, 10:25 PM
Thanks!
~Miranda~
  #38
Old 04-04-2010, 10:28 PM
yep, but not for awhile nothing will happen with this car for probably 2 years, accept collecting parts for it, as my parents are trying to build a new house and 40' X 80' pole barn for the toys.
~Miranda~
  #39
Old 04-04-2010, 10:47 PM
marxjunk marxjunk is offline
Heres pics, you can see its on the right/pass front side, it has all the info, like gear set code, date code..and that lillte E means Eaton Posi..do some research...a factory 4.10 code BE rear can go for 5 grand PLUS..mabe more its a COPO code
this one is BR which wad originally a 3.08 posi
  #40
Old 04-05-2010, 12:10 AM
Congrats on the new car MA. I have the same dreams but with a vert instead. Enjoy the journey.
