Old 04-08-2010, 07:45 PM
Xelerator Xelerator is offline
Originally Posted by Hotrodizz View Post
These 2 items were screwed to the LH fenderwell, any ideas?
Looks like someone tried to "rig" up something on their own. The item mounted to the fender looks like a breaker, like possibly a 30amp breaker. I can not tell what the other items is but clearly these are not "factory" installs.
73 TA 4spd (in need of restoration)
http://www.aasencamaros.com
Old 04-08-2010, 08:09 PM
Hotrodizz Hotrodizz is offline
Originally Posted by thefirebirdm@n View Post
I did the same thing. Complete disassembled the nose and had it painted bare. I had all the brackets blasted and powdercoated and it came out great:
Looks great, and am looking forward to the point you are at.
1971 Trans Am 455LSX/T56 Clone
1973 Trans Am LS3/T56 in process
1977 Can Am....Sold
1973 Trans Am 455/Auto, White, # matching-Sold
1959 Impala TT LSX
1987 GNX #357
1969 Boss302 Clone w/Supercharged Coyote 5.0-Sold
2010 ZR1
2009 CTSV
www.speedinc.com
Old 04-08-2010, 08:14 PM
CaptCrunch CaptCrunch is offline
I highly recommend powder coating.......did almost everything on my Formula and it provides an outstanding finish......if you do it in large batches it isn't bad $$ wise either.........
Old 04-08-2010, 08:19 PM
My coater quoted me $500 to do the subframe, a-arms, core support, bumper support, fenderwells, and any other misc underhood brackets & supports. I thought my 59 Impala complete x-frame for $700 was a bargain a few years back, but this seems even better.
1977 Can Am....Sold
1959 Impala TT LSX
1987 GNX #357
2010 ZR1
2009 CTSV
www.speedinc.com
Old 04-09-2010, 09:16 AM
It has come down......you cant hardly sandblast and paint for that.........
Old 04-09-2010, 10:48 AM
thefirebirdm@n's Avatar
thefirebirdm@n thefirebirdm@n is offline
Send a message via MSN to thefirebirdm@n
That is a GREAT deal!! I spent $500 just for the sub-frame and a few small parts. Another $200 on a large batch of parts including core support, inner fenders etc... so I prob have $750 in coating front end parts.
Jimmy
www.firebirdgallery.com
2002 WS6 M6 Trans Am - original owner
1973 Trans Am 455/4-speed
1971 Formula 400/400
1969 GTO 400/400 - 3rd owner
1968 Firebird Convertible 350/200R4
POCI - AAC
Old 04-10-2010, 08:03 PM
Finished removal of the glass and front end sheet metal, and the motor came out this afternoon. A productive day making the parts pile larger. Now on to the rear of the car.
Upon removal, I found some damage to the AC box. It appears to have been when the headers were installed on the car 20 years go. Hopefully, we can repair it
We restored the air cleaner a few weeks ago, and I am anxious to get to the "restoring" and be finished with this messy brown tear down.
So far, I know I need a LH upper air duct (not sure what years interchange), rear bumper guard rubber, front spoiler hardware, battery tray (repro), and possibly an AC outer heater box (not sure what years will be correct).
1977 Can Am....Sold
1959 Impala TT LSX
1987 GNX #357
2010 ZR1
2009 CTSV
www.speedinc.com
Old 04-11-2010, 12:22 AM
Could definitely use your help with the bolt guide. I couldn't cross hardly any of the bolts used to mount the alternator & associated brackets or the A/C compressor & associated brackets. Sooo if you get some time
Jimmy
POCI - AAC
Old 04-13-2010, 11:45 AM
Most important tool thus far
1977 Can Am....Sold
1959 Impala TT LSX
1987 GNX #357
2010 ZR1
2009 CTSV
www.speedinc.com
Old 04-13-2010, 11:46 AM
Sorry for the delay, do you still need this info?
1977 Can Am....Sold
1959 Impala TT LSX
1987 GNX #357
2010 ZR1
2009 CTSV
www.speedinc.com
Old 04-13-2010, 04:53 PM
I have some information to work with and need to do an update. I'll get back to you. hopefully your labeling all the bolts as you remove them . Very cool idea on the labeler. Use those alot building datacenters but never thought to use one to restore a car!!
Jimmy
POCI - AAC
Old 04-13-2010, 04:58 PM
ok, feel free to email me, Ill help where I can.
1977 Can Am....Sold
1959 Impala TT LSX
1987 GNX #357
2010 ZR1
2009 CTSV
www.speedinc.com
Old 04-18-2010, 08:57 PM
OVERULD's Avatar
OVERULD OVERULD is offline
Another fun project to follow! Good luck with it!
BJ
Old 04-19-2010, 10:24 AM
parts are back from Coating already. It was a little more expensive than the quoted price, but still very fair. Core support has some pitting from a leaking battery, that is my only disappointment.
I started stripping the firewall, cowl and interior floor boards this weekend.
Is there a particular seam sealer I should use on the cowl and the in interior?
1977 Can Am....Sold
1959 Impala TT LSX
1987 GNX #357
2010 ZR1
2009 CTSV
www.speedinc.com
Old 04-19-2010, 11:40 AM
I used 3M Fast n Firm Sealer and was very happy with it. I bought it in a "caulk gun" style tube and applied it that way. Once I had it applied I went back and tried to smooth it flat to mimic the factory method. Just don't try to do too much at once because it really is fast. Dries fairly quick.
Jimmy
POCI - AAC
Old 04-23-2010, 12:14 AM
71formula455's Avatar
71formula455 71formula455 is offline
Question
I'm using the powder coating approach with my 71.
My question is:
Are you using any sort of clear coat or protective coating on top of your powercoated parts?
My concern is I've heard that powercoating may become "chalky" over time due to UV.
Is this true? Anyone have thoughts on this?
Old 04-23-2010, 10:03 AM
Ive used it a lot, and havent experienced that problem.
1977 Can Am....Sold
1959 Impala TT LSX
1987 GNX #357
2010 ZR1
2009 CTSV
www.speedinc.com
  #38
Old 04-26-2010, 12:25 PM
AFter stripping some areas to bare metal last weekend, I wanted to get something over the bare metal, so I shot some DP74.
Spent time this weekend pressure washing some of the parts, and taking pictures.
Before
After
Measurement from where front of tubing begins
Found this in the trunk, any ideas?
  #39
Old 04-26-2010, 02:40 PM
Brewster's Avatar
Brewster Brewster is offline
There is a tire bar sleeve that goes over the jack and creates a pocket for the tire bar. Hard to tell size of this item from your picture since there is no reference but it could be that ?
  #40
Old 05-03-2010, 11:25 AM
Took the driveshaft down to bare metal, then painted it. I still have to reproduce the factory markings on it.
I still may replace the fuel and brake lines, but I started cleaning them up with a wire wheel, and a coat of clear.
My original faded 73 front mat, with the repro 73+ mat that some of the vendors are selling.
Some of the original interior plastics with a fresh coat of red
Still waiting for the body shop to let me bring the shell to them
