Old 04-09-2010, 12:07 AM
AZHARLEY AZHARLEY is offline
Default 77 t/a
I have a 77 TA 4-spd, cam, 750 holley, flowmasters, polished snowflakes.....Question...the heads have a YB code....I assume this is 72' 455. Did alot of searching and getting different codes from everyone. Also, would this increase the value of the 77'?
Old 04-09-2010, 08:26 AM
se428bandit's Avatar
se428bandit se428bandit is offline
Where are you getting this YB code from?The # on the heads are on the center exhaust ports.
Old 04-09-2010, 11:02 AM
Default azharley
the yb code is on passenger side front of the block
Old 04-18-2010, 07:43 PM
rhino33's Avatar
rhino33 rhino33 is offline
http://www.hotrodders.com/kb/
this is a great site for running numbers
Old 04-22-2010, 01:31 AM
lester's Avatar
lester lester is offline
you really need the year to, and the casting #'s on the back right side of the block. the YB was used for several motors
but being a 77 you really hope for a W72 400 with the Y6 or WA code .
from 77 - 79 the W72 400 was the icing on the cake. other then finding a SE
really look at your block code, make sure it's not a Y6 , some times it will look like YG
if its a 455, 455 will be cast into the left side of the block, beside the fuel pump
