Old 05-03-2010, 10:02 PM
c5farmer's Avatar
c5farmer c5farmer is offline
Default What tempest projects are you working on
Here is one of my Pontiac projects. It is a Montana car that is faded, but virtually rust free. It came from a Craigslist ad and we traveled 1800 miles round trip to get it. Being from Iowa, there is no such thing as a rust free car over 10 years of age! Plans are to convert it to a solid rear axle (already have an A body Mopar 8 3/4 rear end), put in a 400 ci engine, 400 turbo trans and leave the body as is and redo the interior to near stock. Going for the nostalgic drag car look. Not restored to new, but new "barn find" condition. Plan is to rebuild the front end and add disk brakes.
What is everyone else working on this summer?
Name:	tempest and tail light parts 007.jpg
ID:	205141   Click image for larger version
Name:	tempest and tail light parts 008.jpg
ID:	205142   Click image for larger version
Name:	tempest and tail light parts 011.jpg
ID:	205143   Click image for larger version
Name:	tempest and tail light parts 010.jpg
Old 05-04-2010, 09:04 AM
c5farmer's Avatar
I would like to hear from others who have converted a tempest to a solid rear axle. I know it has been on this forum many times about how to do it and what parts to use, but the question is: "for a street car, what conversion gives the best/safest ride?"
Thanks for any input.
Old 05-04-2010, 09:26 AM
tom s tom s is offline
you should be able to do a search,it has been covered many times.I have done 3 of them and found coilovers and ladder bars to be easy and has a good ride.Tom
Old 05-04-2010, 09:50 AM
beemergary's Avatar
I 've did two. A 63 coupe and a 61 wagon. Coil overs and ladder bars. Both cars ride as good as my 67 GTO. Doing the rear end in a 63 is not bad. I could unbolt it and put the transaxle back in it. I made my own brackets and have the wilwood brakes. Little Pricey but easily done. The only real work was enlarging the bellhousing area. But I am a sheetmetal worker so just did it at work. Enlarging and centering the drive shaft tunnel is also an easy job. If its a v8 car that helps. Hooker 68 gto headers fit great. Need help give my a hollar.
Old 05-04-2010, 10:01 AM
spartazoo's Avatar
spartazoo spartazoo is offline
I did my '63 Tempest myself and I had never done anything like it before. It is actually easier than you might think. The rear uni-body frame rails are setup well to convert to ladder bars and coil overs. My 63 rides as well as my 66 GTO and while racing it is smooth enough to drive with one hand and eat a cheeseburger with the other.
I have a spreadsheet of everything that went into my build. If you would like a copy email me at [email protected].
Good luck and have fun, I know I did and am.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
1966 GTO Hardtop - PS 14.84 @ 97mph
Old 05-04-2010, 01:12 PM
grparen grparen is offline
I'm restoring an old '63 Tempest race car built probably 30 years ago into a Super Duty reproduction. Got the car out of Arizona. Has homemade ladder bars and big Pontiac posi rear (4.10 or maybe 4.30). Putting a rebuilt '65 421 in it with solid lifter cam with dual 400 CFM carters on an offenhauser intake. Running 3 tube headers with a turbo 400. Will be painted Cameo Ivory.
Name:	Lemans 63 Engine.jpg
Old 05-04-2010, 02:01 PM
do you have pics of the old suspension?Might be my old race car.Lemans or tempest?Tom
Old 05-04-2010, 03:10 PM
It is a Lemans. I am keeping the old suspension. just detailing it. It is bulletproof. See pictures. Added picture of car when I bought it. Previous owner must have gotten sideways and car got away from him and hit pole.
Name:	West_63 Lemans_Harley Boots 011.jpg
ID:	205264   Click image for larger version
Name:	West_63 Lemans_Harley Boots 012.jpg
ID:	205265   Click image for larger version
Name:	West_63 Lemans_Harley Boots 010.jpg
ID:	205266   Click image for larger version
Name:	West_63 Lemans_Harley Boots 006.jpg
mechanickeith's Avatar
mechanickeith mechanickeith is offline
Still working on one of my 62's. Its about ready to go to paint. Starting to collect parts for my 61 wagon's resto project & getting the body work done on the backend of my 61 that got rearended a couple of weeks ago! Other than that, not a thing going on!!!
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 05-04-2010, 04:46 PM
GaryK's Avatar
GaryK GaryK is offline
Default Summer Projects
Nice Project 63 Tempest you picked up! I am in the process of wrapping up one long project on my 62 Lemans I have had for almost 30 years. Soon to be starting on another I just aquired to use as a daily driver. This one I am keeping all original, for now.
Gary
ID:	205279   Click image for larger version
ID:	205280   Click image for larger version
ID:	205281   Click image for larger version
Old 05-04-2010, 10:16 PM
mjm421's Avatar
mjm421 mjm421 is offline
Default Here is mine
Here is a few pics of my 63 project. Hopefully someday..............Mike
ID:	205326   Click image for larger version
ID:	205328   Click image for larger version
ID:	205330   Click image for larger version
ID:	205332   Click image for larger version
Old 05-05-2010, 09:40 AM
Very nice.
Old 05-05-2010, 10:26 AM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Just trying to get my '63 Tempest race car back on the track in time for the GTOAA race in Wichita July 3rd. Right now I'm pulling the engine and we plan to check it out, probably upgrade to .904 lifter bore and lifter set and install a new cam to replace the one the broken lifter took out at Pontiac Heaven. Sometimes it seems like it's run a few passes....re-do the engine...run a few passes.....re-do the engine.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 05-05-2010, 12:27 PM
mlund12's Avatar
mlund12 mlund12 is offline
Default Project
I have a 63, with QA1 ladder bar coil-overs, 9 inch rear from 70 Cougar fits perfect, 389 .030 over, Ross pistons, Lunati cam, Edlebrock intake with Edlebrock 750cfm, Muncie 4 speed, power steering, disc brakes, Keisler hydraulic MC, Hedman headers.....every one had input at some point along the way....some great people in this forum. Tom S had some great pics of his conversion. Mine is in final stages of block sanding now after epoxy coat etc. will be painted with in the next week or so. All chrome work done at Nu Chrome, interior will be next winter.
Best of luck with your car!!!!
Old 05-06-2010, 11:47 AM
fasteddy's Avatar
fasteddy fasteddy is offline
My 63 Tempest is nearing completion. I am waiting on the package tray from the upholsterer. It is Cameo on blue with a 3 speed manual and the 4 cyl 4 bbl. All original. My 63 Lemans is in progress. Cameo on buckskin, 400 2bbl with AC, PS and PB--stock 2 speed transaxle. This one is going to be my daily. I am going with a different color than Cameo since I do not want two the same.
fasteddy
Old 05-07-2010, 02:51 PM
Hooter's Avatar
Hooter Hooter is offline
My 63 Lemans is nearing completion too. It's painted finally and getting the tin work and lexan done next. Will post up some pics when it's done.
67 Bonneville ragtop
Old 05-07-2010, 05:25 PM
63 tempest's Avatar
63 tempest 63 tempest is offline
hey hooter what did you used for door handles.
Old 05-07-2010, 07:57 PM
'62pest '62pest is offline
I am getting my 1962 4 door tempest back together after not wanting to tear it down as far as I did because I never wanted to go this far. When funds are available I am buying all new rubber for all the windows and I need my interior redone. Pictures to follow once the engine is back in so it sits a little closer to earth. I am keeping the 4 cyl 1 barrel carb set up. My vision for this car is more of a factory custom. I have a new paint job and a set of aftermarket wheels from back in the day. If anyone has a really good '62 grill that they might want to let go of, please let me know. I will trade you mine, which is the best looking one I have ever come accross, and a little cash to sweeten the deal.
Old 05-07-2010, 10:14 PM
Hooter's Avatar
I compared them to the ones on my 65 Lemans and they look identical. Wound up buying a new set for a 65. Haven't tried putting them on yet since the cars back at the chassis shop, but pretty sure they will work just fine.
Old 05-09-2010, 07:57 PM
i finally got to a computer where i can see what i am doing instead of using my phone. so after the long awaited unveiling here is my '62 tempest that i have been working on restoring with a touch of my own personal taste. i still have a lot of putting back together to do as well as blacking out wheelwells and the front grill area and interior is the next big expense.
