The HD radiator is a 4 row,and TT is correct.But,in 65,the tri-power rads had the upper hose on the passenger side,4 barrel on the driver's side.
I was under the impression that the standard fan on GTO(basic one) was all black,with five blades.(Interestingly,that blade was on 67 RA cars.) and 18" The HD fan-19-1/2" diameter and seven blades, Larry B.
Mr. President, you can't say Dallas doesn't love you " |
The rad is a h/d rad it cam on the 3/2 cars standard. But was option on 4v cars. The bent tip fan was standard on GTO option.
fans
you may have to resize to view
Note fans on both eagines alum bent tip -GTO . Lemans blk. steel
I think the p/s part is secondary to the point that the notched fan is a larger dia. In that pontiac put the notch in it as a fix. The fan was used in h/d applcation. The part that the car had p/s was coincidental.
not my car.....there is plenty wrong with that car though.
dld-- the picture is this your car? what line is that with the hump in it beside the front carb?
I posted a chart of radiator use please look at the use of the TT radiator. I think you will concur that the TT radiator was used with both engines IF equipped with h/d cooling . Thanks for your example of the fan on your car. the info. that I have obtained is from Pontiac literature by Pontiac or a collection of many cars that I have seen. I have owned a body shop for 35 years and have worked on many of these cars over the years. Now I'm restoring a 65 post car. I'm trying to put it back correct, as Built. I also I'm 60 years old and share the same passion for cars. I have owned a new 67 HO car and many other Pontiac's sense including a new 70 R/A iv car. Although I may be new to this Forum I'm not new at cars. Don |
this is from Zazarine and Roberts Restoration Guide. This should clear it all ,fans radiator ect.
I stumbled onto this 65 Post Coupe Lemans today that is still with the Original family and is a daily driver. It is Cameo Ivory with Turquoise interior, 326 with column automatic and factory air w/power steering built here in Fremont, Ca. The gentleman was kind enough to let me take some pics.
Note - The fan Caution Decal and Nice original hood pad! |
