Old 05-17-2010, 07:01 PM
1971455HO's Avatar
1971455HO 1971455HO is offline
Default Five basic questions about correctness. Please
I have just about purchased everything known to man for my car to restore it, I have a few questions about stuff I don't know please.
1. Did the 1970 & early 1971 TA's have the bird emblem on the dash engine turned bezel?
2. Is there any difference between the basic '70-'73 Firebird, Espirit, Formula & TA battery trays?
2a. If no, does one fit all? The one I bought says: all, exc. TA.
3. Did '70-'73 TA's come with a Core Support Filler Panel. If it did, mine was missing when I got it years ago.
4. The GM reproduction fan shroud I bought is identical except for a cutout / relief at the bottom of fan area of the shroud and also it has a square hole punched out for a small carriage bolt on the upper passenger side of the shroud. it matches except for the cutout on bottom and the hole. Mine has a little hunk missing from the left side bracing molding and also where I was crazy and cut out the bottom bolt holes for easy removal 30 years ago. I may just use mine and send theirs back
4a. Did They sell me one for a non-AC car? I don't think my old shroud was ever swapped.
5. Did the lid that holds the air filter in place in the lower breather assembly, on '71TA shakers, come with a 455HO decal? I know the Formulas' do. What about the TA's?
Thanks Eddie
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
Old 05-17-2010, 07:27 PM
Yes.
I believe the trays are the same. The hold down bolt/bracket changed post-'70, though.
I know there's been some discussion about this - I don't think any of them came that way from the factory. More likely released as a service part for cars that ran hot -- mostly A/C equipped cars, I suspect. There'd be no difference between an A/C and non-A/C version of that part, though.
No Decal on a T/A.
Old 05-17-2010, 07:52 PM
Transamric's Avatar
Good answers Keith.
On #3, I've found only Van Nuys built & A/C optioned cars got the filler panel. And only part of production at that.
Old 05-17-2010, 09:01 PM
Sorry... I missed this question when I quoted to respond before...
The differences you're seeing are just the differences between a later service replacement and an original '71 assembly line part. Not related to A/C vs. Non-A/C. You can fill the hole at the top to make it look correct at a glance. The chop-out at the bottom is not so easy...
Old 05-17-2010, 09:07 PM
Originally Posted by Transamric View Post
Good answers Keith.
Ric,
Yep... that seems consistent with what I've seen/heard.
Old 05-17-2010, 09:19 PM
1971455HO's Avatar
Thanks very much guys for all the information.This helps a lot.
I'm not sure where the bird emblem goes on the dash. I don't remember a hole for the emblem, but I'm sure there is one. Is it between the tach and the speedo? I hate to sound so stupid...but my car has been gone for 3 damn years. it's now only 70 miles from me. I'll be checking though. Thanks again.
Eddie
Ol' man Smith
Son video'd this...
Old 05-17-2010, 09:28 PM
Norwood's Avatar
Norwood Norwood is offline
Be careful where you put that bird on the dash Pontiac changed its location in mid run on the 70's.
RIGHT BOB?
Old 05-17-2010, 10:15 PM
68bird400HO's Avatar
68bird400HO 68bird400HO is online now
On #1, all firebirds and TAs had the little bird emblem on the dash bezel UNLESS your car had A/C. The bird emblem goes in the open area on the right side of the bezel. If you car has A/C, then that area is occupied by the A/C vents instead. The exact location of the bird did change sometime around June 1970.
Old 05-18-2010, 07:23 AM
superdutybob's Avatar
superdutybob superdutybob is offline
RIGHT BOB?
Yep! Don't use Norwoods car as your example! LOL
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
Old 05-18-2010, 05:48 PM
1971455HO's Avatar
Thanks 68bird400HO,
My car is an AC car. Does this mean it didn't come with the bird on the dash?
Ol' man Smith
Son video'd this...
Old 05-18-2010, 07:20 PM
Thanks 68bird400HO,
Correct
Old 05-18-2010, 09:35 PM
1971455HO's Avatar
Thank you,
That would account for why I thought, thirty years ago, when I saw early TA's with that emblem on the dash I thought they had put later model (75,76,77) dash bezels in their cars. Turns out I didn't realize I was only seeing non-air cars with them. It's nice to learn something. Thanks very much. I really appreciate all the help guys.
Ol' man Smith
Son video'd this...
Old 05-19-2010, 01:44 AM
giles's Avatar
giles giles is offline
The open area at the right hand side, where the air vents would be on an A/C car is where you want to be. The early '70 cars placed the bird approx where the right hand of the two vents would be. Late '70 and all later years had the bird in the left hand location. I can post pictures if you need them. Just not accessible from here.
Old 05-19-2010, 07:25 PM
Transamric's Avatar
Eddie, FWIW, here's a pic of where the dash Bird was located on my unrestored 05D Van Nuys TA.
Name:	70 TA VN dash bird #1.jpg
Old 05-19-2010, 09:14 PM
1971455HO's Avatar
Thanks for the pic. Very instructive, you can't beat a picture. I'm sure a lot of other guys are happy to see this. I am still of understanding this is how it should look (without air). Thanks for the education gentlemen, and thanks for going to the trouble of posting the picture. By the way, your car was in very good shape when you got it.
Ol' man Smith
Son video'd this...
Old 05-19-2010, 09:26 PM
1971455HO's Avatar
I have another question please!
Have any of you purchased a detail tag kit from inline tube or any other vendor who sells them and been satisfied. I ordered one from Ames, however, I'm afraid to open it for fear that it doesn't have the proper YE code engine block decal on the second sheet in the kit. The one I've ordered shows a WC code through the plastic cover. I figure if I open it, I can't return it. I didn't get a chance to call Ames today to ask them if they knew for sure if it included it or not. They may not know.
Is their another source I can be sure to get the right detail tags from?
Ol' man Smith
Son video'd this...
Old 05-20-2010, 01:50 AM
giles's Avatar
Eddie, just to be clear Ric's picture is for a 70. Your car is a 71 and the bird goes to the left side of the open area. I'll post a picture tomorrow...
Old 05-20-2010, 11:41 AM
I think Eddie said his car had AC... so he doesn't have to worry about where to put the bird (other than perhaps intellectual curiousity).
Old 05-20-2010, 03:58 PM
giles's Avatar
For a non-A/C TA built after June '70 the bird should be located as in this picture...
Old 05-20-2010, 04:12 PM
Transamric's Avatar
Yes, I could have been more clear. That's 05D of '70, not '71. FWIW, here is a pic of a 07E non A/C '70 TA that shows the bird biased to the left side, just like Giles '71.
Name:	70 TA restored dash 2.jpg
