All parts are used. Will post close up pictures of parts as requested.
1 Console for automatic(has a hole in vinyl on one side and some scuff marks, all plastic mounting brackets nice, includes lid hinge): $75.00 1 Console for automatic(has scuff marks in vinyl, mounting brackets were fixed with sheet metal, includes hinge which is missing the U shaped clip): $30.00 1 Shifter Bezel (automatic console,missing one clip): $25.00 2 Ash Trays for rear arm rests: $15.00 each 2 Arm Rest Bases L&R(Black, arm rests included with one cgerette burn in each): $50.00 each 1 Headlight Switch for standard headlights: $10.00 2 Door Handles L&R: $15.00 each 4 Window Cranks(where clear knobs): $1.00 each 1 Parking Light Lens Bracket Right side: $15.00 1 Parking Light Housing(needs the studs repaired): $25.00 1 Parking Light Housing(needs the studs repaired, no wire harness connecter): $10.00 2 Parking light Lenses(one crack in each): $10.00 each 2 Parking Light Bezels(chrome chipped by screw holes,few pits): $15.00 each 1 Side Marker Lens(has some cracks): $5.00 2 Headlight Bezels(GTO standard headlights, some pitting): $100.00 pair 1 Hood Latch: $20.00 1 Hood Spring: $10.00 6 Vinyl Top pieces(2 quarter window, 2 rear corners, 2 that connect rear corners): $75.00 for all
Eric 1969 GTO - 461, turbo 400, Continental 13", 3.08 gears. - 12.59 e.t. @ 108.43 mph, 1.898 60' 1978 Oldsmobile Cutlass Supreme- 461, turbo 350, PTC 3500 converter, 9" 3:50 gears. = 11.39 e.t. @ 117.55 mph, 1.599 60' on E85 |
pm sent
PM sent on Headlight Bezels
Hood spring; do you mean the popup spring that pushes the hood when released?
I'm interested in the door handles if they're reasonably nice. Don't need show quality, rather driver quality, better than the pitted ones I have. Could you post a pic?
Yes, it's in the middle picture at the bottom between the window cranks and the ash trays.
Jeff, here are the door handle pictures.
Headlight bezels
Thanks Eric. I will take them. Let me know shipping and how to pay. No rush on my end enjoy the weekend. Thanks, John
PS Do you have the backing plates also? If so, I'm interested. |
PM Sent
$30.00 Console , Shifter Bezel and Headlight Bezels are sold.
Ah, my mistake, thought you meant exterior door handles, thanks for the followup,
Jeff |
All parts are used. Will post close up pictures of parts as requested. Added few parts.
Will take offers. 1 Console for automatic(has a hole in vinyl on one side and some scuff marks, all plastic mounting brackets nice, includes lid hinge): $75.00 2 Ash Trays for rear arm rests: $15.00 each 2 Arm Rest Bases L&R(Black, arm rests included with one cgerette burn in each): $50.00 each 1 Headlight Switch for standard headlights: $10.00 2 Inner Door Handles L&R: $15.00 each 4 Window Cranks(where clear knobs): $1.00 each 1 Parking Light Lens Bracket Right side: $15.00 1 Parking Light Housing(needs the studs repaired): $25.00 1 Parking Light Housing(needs the studs repaired, no wire harness connecter): $10.00 2 Parking light Lenses(one crack in each): $10.00 each 2 Parking Light Bezels(chrome chipped by screw holes,few pits): $15.00 each 1 Side Marker Lens(has some cracks): $5.00 1 Hood Latch: $20.00 1 Hood Spring: $10.00 6 Vinyl Top pieces(2 quarter window, 2 rear corners, 2 that connect rear corners): $75.00 for all 1 Steering Column (for floor shifter, no tilt, black, steering wheel included): $50.00 1 Brake Pedal Assembly (for automatic, includes pedal and bracket that mounts to the firewall): $20.00
Eric, I received the headlight bezels today. I was expecting decent parts, but these were better than anticipated. Thanks for the great parts and service! John.
Will take offers. 2 Ash Trays for rear arm rests: $15.00 each 2 Arm Rest Bases L&R(Dark Green painted black, arm rests included with one cigarette burn in each): $50.00 each 1 Headlight Switch for standard headlights: $10.00 2 Inner Door Handles L&R: $15.00 each 4 Window Cranks(where clear knobs): $1.00 each 1 Parking Light Lens Bracket Right side: $15.00 1 Parking Light Housing(needs the studs repaired): $25.00 1 Parking Light Housing(needs the studs repaired, no wire harness connecter): $10.00 2 Parking light Lenses(one crack in each): $10.00 each 2 Parking Light Bezels(chrome chipped by screw holes,few pits): $15.00 each 1 Side Marker Lens(has some cracks): $5.00 1 Hood Latch: $20.00 1 Hood Spring: $10.00 1 Steering Column (for floor shifter, no tilt, black, steering wheel included): $50.00 1 Brake Pedal Assembly (for automatic, includes pedal and bracket that mounts to the firewall): $20.00 Deleted items sold.
pm sent on column/wheel.
