Old 07-14-2010, 09:54 PM
Coach's Avatar
Coach Coach is offline
Default Adjusting a regulator
Ok another little issue. The regulator is putting out 18 volts when I accelerate. This is in my 67 GP. The regulator has the little adjustment under the cover, the question is clockwise or counter-clockwise to reduce the voltage?
Thanks, Harry
Sold - 1967 Grand Prix Convertible ( http://forums.performanceyears.com/f...d.php?t=639110 )
2003 Bonneville coupe (hers)
2007 Avalanche LTZ 4x4
Old 07-15-2010, 07:18 AM
2002Z4CSS's Avatar
Just try it buy turning the screw in 1/2 turn increments while looking at a volt meter.
1971 Pontiac GT-37
Old 07-15-2010, 11:37 AM
Coach's Avatar
I was hoping to make sure I was going the right way to avoid any potential damage from over tightening the adjustment. Guess I will just loosen it first to see what happens.
Best, Harry
Old 07-15-2010, 12:08 PM
Make sure the regulator is grounded good, and you have the same voltage on the regulator bat terminal as battery voltage.
Low voltage at the regulator bat terminal makes the regulator spend more time sending power to the rotor....thus causing over charge. All it would take is a poor connection causing resistance.
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
Old 07-15-2010, 12:46 PM
Coach's Avatar
Thanks I will check that out. The entire harness is new so I do not think it will be an issues, still better to check then assume!
Best, Harry
Old 07-16-2010, 09:03 AM
Coach's Avatar
Just to complete the thread, loosening the adjustment screw near the base reduces the voltage, tightening it increases the voltage. My car is now putting out a very happy 14 volts at 2000 rpm.
Best, Harry
Old 07-16-2010, 11:28 AM
2002Z4CSS's Avatar
Best, Harry
Glad to hear it was an easy fix.
1971 Pontiac GT-37
