Old 08-19-2010, 10:27 PM
ironman ironman is offline
Default rebuilding heads
Just got my heads back from the machinist, one of the things i had done was have the guides machined for positive type seals, is there a recomended way to install the seals on the guides also I have a new heater fitting for the heads what is the easiest/best way to fit this.
thanks
Old 08-19-2010, 11:48 PM
screamingchief's Avatar
thanks
Usually there should be a small plastic "pill" looking piece that came with the VS seals to protect the seal as your installing it over the valve tip where the keeper grooves are.
And I use just a tiny bit of silicone lube as well,but only on the stems,not where the seal pushes over the guides.
There are some VS seal installer tools on the market as well,but the job can be done without them.
I dunno,it's kinda hard to explain,you just sorta develop a feel for something like this.
The heater fitting,that's easy,put some sealant on it (permatex aviation or hylomar) where it presses into the head and use a deep well impact socket & a BFH and smack that sucker in there.
HTH
Bret P.
This space for rent...
Old 08-20-2010, 07:41 AM
Cliff R's Avatar
Cliff R Cliff R is offline
I made a driver for them, with a very precise fit over the top to push them straight down without damaging the molded seal portion, or the metal outer shell.
Those seals are easily damaged driving them in place with a poor fitting driver. I made the driver in my lathe, but I'm sure someone sells an exact part to put them in place without distorting them......Cliff
Old 08-20-2010, 08:41 AM
Mr. P-Body Mr. P-Body is offline
It depends on WHICH "positive" seal is being used. The "Teflon" (white with silver "rings") seals are VERY persnikity, as Cliff alludes to. The "condom" (plastic sheeth) that comes with them must be employed, along with a bit of lube (we use assembly lube in a bottle). There are ready-made installers, usually white plastic. Getting them "started" over the valve tip is the more critical part, as they can be distorted or "scraped" at that time. Once started down the stem, keeping them "in line' is the key.
If the Viton (black, rubberish, rings), they're a bit more "forgiving" as they can stretch without distorting. Using the sheeth is still recommended. Usually, they can be pushed over the top of the guide by "hand". The Teflon-lined version (OEM) must be installed carefully, as the Teflon insert can easily come out, making it no longer "round".
SC's method of installing the heater hose nipple is the simplest way we've found, too.
FWIW
Jim
Old 08-20-2010, 09:50 AM
PONTIAC DUDE's Avatar
FWIW
Jim
X 2 on the Viton teflon seals. Holds up better over longer periods of driving time. I have seen the all teflon seal become enough oblong to allow some seepage down the guide (stiff fit) where the viton/teflon seal gives on the guide.
X 2 on the nipple BFH does it every time. LOL.
Old 08-20-2010, 02:29 PM
GRX's Avatar
GRX GRX is offline
FWIW
Jim
QFT - ^^^
1969 GTO hard top ~ Std bore 400, '70-RA3 block, 670 heads, Bal. & Blue... M22, 12-bolt w/3:55s
Old 08-21-2010, 08:44 AM
"QFT" ??? Forgive my non-computer familiarity. What does QFT "stand for"? Probably something simple... I'm a dummy from time to time...
Jim
Old 08-21-2010, 09:44 PM
Bob Eiler's Avatar
Bob Eiler Bob Eiler is offline
Jim
QFT is an acronym for quoted for truth which means one supports or stands behind an opinion
There is no such thing as too much cam, just not enough engine.
1966 GTO - 11.31@119 (3478 lbs) in 1979
1967 Firebird - 9.73@138 (2940 lbs) in 1986
400 cu in / 295-298 cfm RAIV / Lunati Cam 278/283 - .704 lift/5.13 gears
Old 08-21-2010, 10:39 PM
Qball's Avatar
Qball Qball is offline
You crazy kids with your acronyms!
Let me have a Diablo sandwich and a Dr. Pepper and make it fast---I'm in a goddamn hurry!
- Mike
1967 GTO
