Old 10-17-2010, 11:06 AM
bad69bird's Avatar
bad69bird bad69bird is offline
Originally Posted by BruceWilkie View Post
A std as cast CV1 head should be able to support 950 -1000 hp at 10 psi and about 1120hp at 15 psi non intercooled.(turbo'd)
Choosing the right turbo(s) is the key to make these numbers happen.
If belt driven centrifugal knock another 10-15% off for belt drive losses.
Bruce,
I made 1274HP on the dyno and with some more tuning at the track, the speed calculator says 1326HP. So, I'd say your numbers are on the conservative side.
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs)
Old 10-17-2010, 12:34 PM
Tazzz2's Avatar
Tazzz2 Tazzz2 is offline
A little know fact is that you can call Rolando at RP Motor sports in Vaughan, Ontario, Canada for a Jesel setup......
As the exclusive VAR (we paid to develop the setup with Jesel) he'll will put together a price for a complete "Jesel setup and have it drop shipped,, give him a call at 905-851-2033.....
Old 10-17-2010, 01:23 PM
Originally Posted by bad69bird View Post
Bruce,
I would rather show it that way to avoid someone being disappointed. I remember how disappointed a friend was when he built a complete Performer RPM head/cam/intake/carb combo and gained nothing at the track over his previous D-port combo. He did eventually pick up after other changes but same money could have got him better results still using his D ports.
I'd love to see what Calvins Quest or Fusion ports would do for your car.
Old 10-17-2010, 01:53 PM
goquick's Avatar
goquick goquick is offline
Right now, there are 9 different port versions of CV1 heads you can buy. From a 235cc port up to 326cc. Rocker arms are cheap and easy to find at any drastrip if a guy thinks new is out of the budget, or if a rocker arm breaks. But the thing is the geometry of the valvetrain has proven to be right on without any alinement issues, even on a 9000 rpm engine. And if there was rocker arm issues, you know at 9000rpm a non shaft rocker arm set up would show it!!!
Old 10-17-2010, 02:00 PM
slowbird's Avatar
slowbird slowbird is offline
Who is turning there Pontiac 9,000rpm with stud mount rockers?
Old 10-17-2010, 02:40 PM
goquick's Avatar
he doesn't post online, in fact he don't have a computer! Does things the "old way".
as he puts it unless it breaks. It hasn't broke.
Old 10-17-2010, 03:25 PM
bad69bird's Avatar
ME TOO!!!
Old 10-17-2010, 06:07 PM
Targa Targa is offline
Lots of good info there guys, thanks.
One other question about the rockers is, not running a rocker stud but going with a shaft system.
Not the T&D money though.
Didnt I see a different brand name that others were saying would fit but would take some work?
Phobes? Or something like that... cant recall.
Bad69bird, had a all day/all night party I was at yesterday.... sorry I didnt notice you called till about 5am.
Shoot me a PM when you want to have me call you back.
Old 10-17-2010, 06:15 PM
goquick's Avatar
Right now Yella Terra "independant" shaft rockers and the T&D shaft asystem is all that actually fits unless Jesel finally did make them in the last couple weeks.
Old 10-17-2010, 08:31 PM
OK, so the YT is in fact a shaft system? Like Doc's T/A? (aka Bankbook)
I have not been able to find any pictures on the net of the YT's so I could not tell if it was a shaft system
That was what I wanted to run but didnt want the T&D price tag is all.
Old 10-17-2010, 10:19 PM
bad69bird's Avatar
Joe,
Good talking to you. Sorry for the abrupt ending on the phone...gotta love kids! I'll give you a call later this week.
Old 10-17-2010, 11:34 PM
bankbook's Avatar
bankbook bankbook is offline
Mine are the T&D's as in the picture.
The Yella Terra's are half of the price.
I do believe that Jessel is now available for the CV1 as well.
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
Old 10-18-2010, 03:08 AM
Doc, my question here is... are the YT rockers a 'shaft system' like yours or not?
Like I was saying, out of the whole net, I can not find a damn picture of this rocker set anywhere.
Every place has 'no image'.
Thanks.
Old 10-18-2010, 03:35 AM
goquick's Avatar
a picture of the yella terra rockers;
Old 10-18-2010, 08:05 AM
ahhhh, so NOT a shaft system.
So what rocker ratio is used on this head? What works? Any that do NOT work?
Anyone used the Scorpion rockers for this head?
And finally....does anyone make a lower cost shaft system than T&D?
Sorry for all the questions. Just want to know all the options is all.
Old 10-18-2010, 08:31 AM
bankbook's Avatar
Actually they are a shaft mount, just different than others.
I think at this point you should call Jim at Roland Racing (417)209-7395. He will have all of that information. I dont think he would mind the call even if you are "kicking tires" at this point.
DOC'S TA
Both 4 speeds!
Old 10-18-2010, 08:35 AM
BADDTA's Avatar
BADDTA BADDTA is offline
Targa,
Look closely at that pic. Those are shafts. The pushrod cup is where you set lash. There is no rocker stud, it's a bolt just like the T&D. Also no pushrod guide plates.
Brian
  #38
Old 10-18-2010, 08:51 AM
I guess I was looking for the same type of shaft system.
Yes, I know they have a shaft as do my other roller rockers from way back when.
I was just looking for the same system as what Doc has. Like when you have the two rockers next to each other, they shared a shaft.
Thats seems more stable than 1 rocker stud to each rocker.
Anyway.. now that we have that cleared up...lol.
Has anyone used or heard of Scorpion rockers used on this head?
A member here offered a set to me at a very reasonable price and was wondering if this was a set to use or just go with the YT rockers.
My cam profile will be about .750 minus lash.
Thanks.
  #39
Old 10-18-2010, 09:35 AM
Scorpion rockers themselves are a very good rocker. Lots of spring/stud clearance strength etc.. Will they fit I guess is your question. Probably if they are a BBC rocker they will fit. The set I used on the 528 Ford I built didnt seem overly large. Less square than Harland Sharps. I think a call to Scorpion and a call to Jim you should be able to find out dimensions and determine if possible clearance issues. I doubt any but checking first is a good thing.
BTW the Ford was .767 NET lift and I saw no difference from checking springs vs Manley Nextecs. That combo ended up in a 3000 lb stang 8.97 first pass.
  #40
Old 10-18-2010, 11:48 PM
Well, trigger has been pulled.
Bought a set from Calvin today.
'Checks in the mail' (tomorrow)...as the saying goes.
Thanks for that heads up for contacting him Tom, I really appreciate that.
Thanks to all the others who chimed in as well.
Joe
