Have a good 3 turn power box if needed .
Just remembered this: Guy with a '65 Buick asked me about my close ratio box. Said he'd tried it and didn't like it because it didn't want to return on its own. True enough. The close ratio I installed tends to not return on its own and it is a bit annoying. Anyone else have that experience?
1965 Pontiac Lemans Convertible, 1957 Chevy 3600 dump bed, 1968 Ford backhoe. ![]() http://picasaweb.google.com/orchidsk...vyiKGThcblmQE# |
will the power steering brackets bolt onto Eheads without mods ?
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-3:55 Moser rear-Dougs Headers.... |
ive read over the past couple years on these close ratio/hi-effort box swaps that the pump needs to be matched to it. matched in the sense of the pressure valve in the pump. i dont know if doing that increases or decreases the fluid pressure to the box, logic sorta says the "low effort" boxes are thay way due to high fluid pressure. but who knows.... i also dont know what role, if any, line pressure plays in the steering wheel return of saginaw style boxes. if it does play a role, and IF high effort boxes require higher pressure than low effort, i guess it's possible the pump doesnt have enough oomph to help that along.
costs too much |
Negative caster makes the steering easier to turn. Spec'd for manual steering. Positive caster makes the steering return to center; and makes for more-stable high-speed highway cruising, but Grandma can't turn the wheel to park the car unless it has power steering. |
