Old 11-14-2010, 06:56 PM
oldgoat16's Avatar
oldgoat16 oldgoat16 is offline
Default 66 gto trunk seal
Hi guys, question, who is making the best trunk rubber seal and where is the start/end point for the seal, would it start and finish at the center rear.. (closet to the rear window) or would it start/finish at the center trunk lock location? mine was removed and replaced years ago, and I can't find any info on the installation, Thanks Mike
Old 11-14-2010, 07:19 PM
bigpop bigpop is offline
Center rear by the back window. I heard Soft Seal makes a nice product. Larry B.
Mr. President, you can't say Dallas doesn't love you "
Old 11-14-2010, 08:03 PM
Jeff Hamlin's Avatar
I just re-did mine as it got ripped. I've checked many supplyers and the price ranges from $15 up to $29. I just did a quick check on epay and found Goodmark.
Fit & finish is perfect. Check on epay summit sells them for under $10.
As far as the seam, I respectfully disagree with the seam being at the top. Think about the rear design. The trunk rail/gutter is higher at the back (closest to the glass) the rear edge above the tail panel is lower and rolls downward. Water runs down hill, so why would you put the seam at the top?
This would allow the water to enter into/under the seal. With the seam at the lowest point the water is lead down to the bottom and will run off/out before meeting the seam.
The Fisher body manual even states this.
Old 11-14-2010, 09:17 PM
Old Goat 67's Avatar
Jeff,
Sounds good, BUT pictures of Bloomington Gold Survivor below.
Link for all pictures;
http://s708.photobucket.com/albums/w...426/?start=all
ID:	224619   Click image for larger version
Old 11-14-2010, 09:27 PM
Andre's Avatar
Andre Andre is offline
If you want to try a Metro one, I'll send you one for $12, and that includes the shipping. I have Metro on my cars.
Old 11-15-2010, 12:18 AM
abefromen's Avatar
abefromen abefromen is offline
soft-seal? Akkkk!
Metro has the best aftermarket w-strips IMO.
Old 11-15-2010, 12:28 AM
67 LeMans 326's Avatar
67 LeMans 326 67 LeMans 326 is offline
I recently replaced my original as well (kept it) and my seam was off to the left of the trunk lock. In fact, it looked identical to the pic Charles posted. All of the seals/rubber is original on my car but man are they dry. I too need door, roof rail, quarter glass, U-jamb and inner/outter fuzzies all the way around on my car.
Old 11-15-2010, 06:45 AM
Hmm, may be another factory to factory issue.
Many a parts car have shown the same.
Interesting, I myself have never seen it the way yours is installed.
The 66 Fisher Body manual confirms my statement.
But I for one never say never.
However IMO based on the basic design of the gutter it makes sence to set it at the lowest point.
Old 11-15-2010, 07:00 AM
Makes all the sense in the world Jeff. I just can't tell REALLY good how it was new.
See this other picture.
My original was changed by myself a good 27 years ago and I had the joint on the LH side of the trunk opening siliconed together then. Knew it wasn't correct, but I had not written it down or had pictures of original installation. I have to do it again very soon and I would like to do it right this time.
Joe, are you saying that yours was siliconed together just to the left of the tear in the second picture I posted?
Andre, chime in here again buddy, give us your opinion and/or observations..
Charles
Old 11-15-2010, 07:11 AM
Jeff,
The 67 Fisher Body manual says the same thing as what you said. Butt joint at rear center.
Charles
Old 11-15-2010, 09:33 AM
Andre's Avatar
In 1980, when I removed the original one from my 66GTO, the seam lined up relatively close to the lock cylinder (middle). This was the skinned seal from GM, and I know that it had not ever been out of the car.
Old 11-15-2010, 10:48 AM
Good info Andre.
Old 11-15-2010, 11:22 AM
oldgoat16's Avatar
Default trunk seal
Thanks to all, no matter how much you try, you can't remember everything!, I put down the tube of weatherstrip seal and walked away, Andre, PM sent, Thanks Mike
Old 11-15-2010, 12:55 PM
geeteeohguy's Avatar
My Baltimore- built '67 had the seam in the middle rear above the lock cylinder. It appeared to be original, but may not have been as I bought the car used in 1983. I replaced the seal in 1986 and installed it the same way. The idea of a seam that is not in an area of standing water makes a whole lot of sense to me, too.
Old 11-15-2010, 01:04 PM
valkyrie9901's Avatar
valkyrie9901 valkyrie9901 is offline
Rear at the trunk latch......JB.
Old 11-15-2010, 01:13 PM
Fred's red sled's Avatar
Fred's red sled Fred's red sled is offline
These probably were installed a couple different ways. Mine was rear center lock as far as I know. For water flow it makes to most sense too. So, if there are several "right" ways, I'd follow the Fisher Body Manual.
"Come on baby... Sit back, relax and enjoy the ride!"
Old 11-19-2010, 06:10 PM
ponderopa66's Avatar
ponderopa66 ponderopa66 is offline
Rear left of center as per Old Goat's pic. IMHO, the metro seal was bulkier than original and hard to manage. Bigger isn't always better...
ponderopa66
Old 11-19-2010, 07:51 PM
GT182's Avatar
GT182 GT182 is offline
True but it might seal better with the Metro seal. Mine needs replacing as it has let water into the trunk.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 11-19-2010, 08:26 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Thumbs up Thank You!
Charles (Old Goat 67) - Thank you for posting that above link showing all those great pics of the 67 Conv. Survivor! There are a million restored (most incorrectly) GTO's out there, but not many untouched/slightly touched Factory Original Survivors for all of us to enjoy! Great reference for all! Regards, Chris.
Old 11-19-2010, 08:42 PM
GT182's Avatar
Chris, I look at it this way with info Charles has on 67s..... "If he doesn't have it, you don't need it." Just a finger of speech, but mostly true. I know he doesn't have all the info but he sure is close to having it all. LOL
Gary
