Old 11-16-2010, 06:55 PM
taff2's Avatar
taff2 taff2 is offline
Default Ring gap for a high boost engine
I've posted this here as well , in case some of you don't frequent the boost section.
I've been advised that I MAY need to run a bigger ring gap than I intended on my turbo combo so I'd like some info or advice from pro engine builders,or what others with similar turbo/blown combos are using.
My combo is a 4.090" bore,3/4 filled,reverse cooled iron block,forged pistons with .006" clearance, C16 type fuel,boost will be 25psi,projected HP around 1200.
I've always followed the ring manufacturers advice on this,in this case for a blown,gas engine, .0055" x bore size of 4.090" = .0224", I then added an extra .002" because the block is filled, I rounded this off to .025". The manufacturers recommendations for a big hit nitrous engine is .008" x bore,which would make it .03272" ring gap,plus the extra .002" for a filled block gives me .035" rounded off,and this is what I've been advised to use. Any advise appreciated,Taff.
Old 11-16-2010, 07:38 PM
PONTIAC DUDE's Avatar
Thumbs up
I run .032 to .035. Even on motor never had blowby issues. Second ring at .024
Old 11-16-2010, 08:53 PM
Steve Barcak's Avatar
Yeah, it is wiser to run a wider gap than a tighter one. Later, you can experiment by closing the gaps if you wish.
Only running .006" piston to wall? That is tight IMO. What does the manufacturer say to do? I would be worried about the skirts that tight. Run over double that number on my nitro motor. Normally run .010"-.012" on a blown gas marine set up. I've run .005" on N/A street motors with forged pistons. many think that is way too much but, the 455 lived for 181,000 miles and did not overheat.
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 11-16-2010, 10:24 PM
Travis Q Travis Q is offline
You don't have to run as much gap on a turbo motor as a nitrous motor. Not as much heat into the top ring. Also, I like a little more gap on the second ring, but that's just me. If it were mine, I would put the top ring at 0.026", second at 0.028". Keeps pressure from building between the rings. Some engine builders don't use this strategy, but its worked well for me.
TQ
Old 11-16-2010, 10:48 PM
bad69bird's Avatar
bad69bird bad69bird is offline
TQ
I concur with Travis. I run mine .030 and .032.
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs)
Old 11-16-2010, 11:02 PM
Torment's Avatar
Torment Torment is offline
.028 top, .022 2nd on my blown roots, E85, 4.31" bore. As above nitrous motors spec more gap.
The secret to happiness is not getting what you want but rather, wanting what you have.
Old 11-17-2010, 05:44 PM
taff2's Avatar
Thanks guys. I know some ring manufacturers,but not all of them, are now recommending a bigger second ring gap,but I'm not sure on that ,I've always done it the old way and never had a problem(that I knew of). Even though I think the smaller ring gaps would be more efficient I might err on the side of caution and go for a slightly bigger top gap,just in case the engine gets really hot some time.
Steve, I normally run .004"-.0045" piston to bore clearance but BRC recommended to add .002" extra. I have previously run TRW forged pistons at .0085" without a problem, my machinist took some convincing to bore for these clearances though,he said 'the piston will be like a dick in a shirt sleeve'.
Old 11-17-2010, 06:29 PM
cgeise's Avatar
cgeise cgeise is offline
Was he talking your dick ??????
Old 11-18-2010, 06:36 PM
taff2's Avatar
No,my shirt sleeve.
Old 11-18-2010, 07:47 PM
bad69bird's Avatar
Originally Posted by taff2 View Post
...my machinist took some convincing to bore for these clearances though,he said 'the piston will be like a dick in a shirt sleeve'.
LMFAOROTF!!!!
Old 11-18-2010, 09:35 PM
440GP69's Avatar
440GP69 440GP69 is offline
LOL come on Thats not that loose for a Real 25lb boost race engine!
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
