How important are billet caps for the front and rear cap?
Most sets are sold w/ the three middle caps together and front and rear sold individually. The front caps aren't too bad, but as you guys know, the rear large main cap/billet is $$$. Looking at the proform caps. Reason why I ask is that the cost for align bore and hone doesnt' really change w/ the number of caps you add - price is fixed. There is a drill/tap cost for the splayed outer bolts/fasteners for the middle three. Sooo, would say adding the three splayed caps AND JUST the front cap offer and advantage over just the three in the middle and keeping the cast front/rear? hope this makes sense - and I've got an IAII block in my strip car (I know that is best option for a 4.5 stroke motor). This is for a 4.5 stroker project that I'd "like" to build - mainly in a street car....kinda a sleeper if you will. |
Where do you run your strip car? Greer, Ware Shoals?
70 Formula Old engine: 467 HO headed 6.79 1/8th mile @ 101.87 no N20. 1.44 60ft 6.23 1/8th @ 111.83 w/nitrous 1.37 60ft New Engine IAII 535 Calvin Hill Eheads Few test passes made. Tore it up. Just got it fixed. |
Used to race Ware Shoals several times/year. Haven't been in over a year.
Last couple of trips were at Commerce, GA. Nothing serious. Got a buddy who races a blown mustang GT - we grudge race... |
Cool. Building a new 535 and will be heading out soon after its done.
The new track in Union will probably become home base for me. Need to come down sometime.
IMO billit front and rear isn't worth it the billit rear cap is almost 300$ and just hope you can get the rear main seal to seal :-) Spend the extra coin on the very best Machine work!
I believe 2-3-4 are the important caps, Plus the whole main reason your going billit is because they are splayed and thats where the strength comes from, not much room for splayed front and rear main caps anyhow In fact id personally use a splayed nodular cap if there was an offering over a billit but don't get me started LOL fwiw
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines! 2006 silvy Z71 4X4,383 LS 600+hp NA Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-} |
I got the front cap when I put my splayed center caps in only because I'm running a blower. NA I probably wouldn't bother with the front one. I see no need for a rear cap at all.
" Darksiders Rule "
Thanks all - the proform fronts are like 85 bucks. Not too much, has to be bored/honed anyway because of the center three - but I won't bother it is doesn't help much.
I've got a seemingly good machine shop (HO428 told me about em). Besides new dowel pins, any OTHER tips. Are there issues w/ the proforms and the thrust cap/main bearing?? |
Milodon (nodular steel iirc) Ford 460 4 bolt splayed for 2 bolt block ALMOST could fit with mods but bolt spread off just a tid. (When I first checked I thought I'd get lucky but correcting bolt locations anyway you do it would get labor intensive $$ plus cap would need step shaved off before line bore,(or step Pontiac block $$$) more $$ plus price of cap too.) Billet steel at fair price looks better at that point even if not as good as nodular could be. Still quite an improvement overall. Early 389 caps are taller at bolt shoulder and center outer height(@1/4") 1-4, and considerably beefier than 400 caps. Dont know if all 389's but sure on 59's and 60's both 2 and straight 4 bolt caps are pretty beefy and fit a 400 block. #1 caps on these early 389's is same size as #2 caps vs 400's with smaller front cap than #2. My #1 and #5 stay for sure! If I was going NA the 2 bolt caps on my 59 would stay as well, just get studded. Hmmm what else has 3" or 3.25" (or close dimension) mains?? Derek glad to see you are alive, its been awhile since I've seen you post. You must be busy! |
