Old 01-31-2011, 10:19 PM
72TAMAN's Avatar
72TAMAN 72TAMAN is offline
SUMMER OF 88
Picture #105.107,108,109,110 Inside shell all painted orange/red ,new GM rocker panels
also installed.
Name:	1972 TRANS AM #110 SUMMER 88 VIEW OF INSIDE  TRANS AM AND COWL AREA AFTER PAINT.jpg
ID:	232981   Click image for larger version
Name:	1972 TRANS AM #109 SUMMER 88 VIEW OF PACKAGE TRAY AFTER PAINT.jpg
ID:	232980   Click image for larger version
Name:	1972 TRANS AM #108 SUMMER 88 VIEW OF INSIDE,UNDER DASH AREA AND NEW GM ROCKER PANELS RIGHT SIDE .jpg
ID:	232979   Click image for larger version
Name:	1972 TRANS AM #107 SUMMER 88 VIEW OF FRONT FIREWALL AND COWL AFTER PAINT.jpg
ID:	232978   Click image for larger version
Name:	1972 TRANS AM #105 SUMMER 88 VIEW OF INSIDE TRANS AM AFTER PAINT FROM RIGHT  SIDE WITH NEW GM RO.jpg
ANDRE
1972 TRANS AM , UNDER RESTORATION
http://forums.maxperformanceinc.com/...d.php?t=656067
1972 FIREBIRD FUTUR PROJECT
http://forums.maxperformanceinc.com/...d.php?t=674551
1978 TRANS AM (PARTS CAR) MAYBE
1971 LEMANS T37 (PARTED OUT)
1976 TRANS AM (PARTED OUT)
1984 6000LE (SOLD)
2003 SILVERADO 1500
Old 01-31-2011, 10:41 PM
72TAMAN's Avatar
SUMMER OF 88
Picture #111 Top view of painted shell
Picture #112 View of inside shell under dash area
Picture #113,114,115 View of rear end installed back in Trans Am, rear end was rebuild
and new set of leaf spring. the whole underneath was painted and
undercoated
Name:	1972 TRANS AM #112 SUMMER 88 VIEW OF INSIDE TRANS AM WITH NEW GM ROCKER PANEL RIGHT SIDE AFTER P.jpg
ID:	232985   Click image for larger version
Name:	1972 TRANS AM #115 SUMMER 88 VIEW OF REAR END  INSTALL WITH NEW LEAF SPRINGS AND ALL REDONE.jpg
ID:	232988   Click image for larger version
Name:	1972 TRANS AM #114 SUMMER 88 VIEW OF INSIDE REAR FENDER RIGHT SIDE.jpg
ID:	232987   Click image for larger version
Name:	1972 TRANS AM #113 SUMMER 88 VIEW OF TRANS AM AFTER REAR END INSTALL WITH NEW LEAF SPRINGS.jpg
ID:	232986   Click image for larger version
Name:	1972 TRANS AM #111 SUMMER 88 VIEW OF INSIDE TRANS AM AND COWL AREA AFTER PAINT.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
Old 01-31-2011, 11:04 PM
72TAMAN's Avatar
SUMMER OF 88
Picture#116 View of rear end installed
Picture#117 View from under Trans Am
Picture#118 View or front leaf spring anchor point
Picture#119 View of rear end with new overloader shock
Picture#120 View of inside left side wheel well
Name:	1972 TRANS AM #116 SUMMER 88 VIEW OF REAR END INSTALL WITH NEW LEAF SPRINGS  AND REDONE.jpg
ID:	232994   Click image for larger version
Name:	1972 TRANS AM #117 SUMMER 88 VIEW OF UNDER TRANS AM FROM THE BACK.jpg
ID:	232995   Click image for larger version
Name:	1972 TRANS AM #118 SUMMER 88 VIEW OF REAR END FROM UNDER TRANS AM.jpg
ID:	232996   Click image for larger version
Name:	1972 TRANS AM #119 SUMMER 88 VIEW OF REAR END INSTALL WITH NEW LEAF SPRINGS AND OVERLOADER SHOCK.jpg
ID:	232997   Click image for larger version
Name:	1972 TRANS AM #120 SUMMER 88 VIEW OF INSIDE LEFT REAR FENDER.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
Old 02-05-2011, 10:36 AM
72TAMAN's Avatar
SUMMER OF 88
More pictures of under the car with the new frame. Yes I know!!! those shocks are not staying on the Trans Am, I bought those in the winter of 85-86 to replace the air shocks because the air shocks were pumped up to the limit ,leaf spring were done so I thought to help the weak leafs all just add overloaders.But after finding out about the damage in the back frame area that all changed. Now with new leaf spring and those shocks I can't even bounce the damn rear end of the car way to stiff, don't want the 4x4 look want the NORWOOD look and this will be more like the monster truck look so the shocks are gone. I may have to even replace those new leaf spring or maybe just remove one leaf out , the leaf spring have 5 leafs on them now.
Name:	1972 TRANS AM #121 SUMMER 88 VIEW OF UNDER TRANS AM WITH NEW  FRAME  LOOKING FROM THE BACK TOWAR.jpg
ID:	233510   Click image for larger version
Name:	1972 TRANS AM #122 SUMMER 88 VIEW OF UNDER TRANS AM NEW FRAME  LOOKING FROM THE FRONT TOWARDS TH.jpg
ID:	233511   Click image for larger version
Name:	1972 TRANS AM #123 SUMMER 88 VIEW OF UNDER THE TRANS AM  TRANSMISSION TUNNEL.jpg
ID:	233512   Click image for larger version
Name:	1972 TRANS AM #124 SUMMER 88 VIEW OF TRUNK AREA.jpg
ID:	233513   Click image for larger version
Name:	1972 TRANS AM #125 SUMMER 88 VIEW FROM UNDER TRANS AM.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
Old 02-05-2011, 11:17 AM
72TAMAN's Avatar
SUMMER OF 88
More pictures of under the Trans Am and of trunk lid. Picture #129 notice where the sticker is on the inside of the trunk lid on my 72 Trans Am. I never even thought of sticker location or any thing like that before I looked at this forum. Man this forum is so freaking going to help me in the restoration of my Trans Am . THANKS A MILLION GUYS
Name:	1972 TRANS AM #126 SUMMER 88 UNDERSIDE VIEW OF TRANS AM  LIFT CAR WITH    12 000 LBS LIFT TRUCK.jpg
ID:	233521   Click image for larger version
Name:	1972 TRANS AM #127SUMMER 88 UNDERSIDE VIEW OF TRANS AM LIFT CAR WITH   12 000 LBS LIFT TRUCK.jpg
ID:	233522   Click image for larger version
Name:	1972 TRANS AM #128 SUMMER 88 VIEW OF TRUNK AREA AFTER  TRUNK LID IS REMOVE.jpg
ID:	233523   Click image for larger version
Name:	1972 TRANS AM #129 SUMMER 88 VIEW OF UNDERSIDE OF TRUNK LID.jpg
ID:	233524   Click image for larger version
Name:	1972 TRANS AM #130 SUMMER 88 VIEW OF TOP OF TRUNK LID AFTER SANDBLASTED AND PRIMED.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
Old 02-05-2011, 11:52 AM
72TAMAN's Avatar
SUMMER OF 88
Pictures of trunk lid and doors after sandblasting and primer. The doors had the old skins remove and shell sandblasted and new GM skins put on
Name:	1972 TRANS AM #131 SUMMER 88 VIEW OF UNDERSIDE OF TRUNK LID AFTER SANDBLASTED AND PRIMED.jpg
ID:	233529   Click image for larger version
Name:	1972 TRANS AM #134 SUMMER 88 DOORS IN PRIMER AFTER BEING SANDBLASTED AND GM DOOR SKIN INSTALL OU.jpg
ID:	233530   Click image for larger version
Name:	1972 TRANS AM #135 SUMMER 88 VIEW OF DOORS IN PRIMER AFTER BEING SANDBLASTED AND NEW GM SKINS IN.jpg
ID:	233531   Click image for larger version
Name:	1972 TRANS AM #136 SUMMER 88 RIGHT DOOR READY FOR PAINT INSIDE VIEW.jpg
ID:	233532   Click image for larger version
Name:	1972 TRANS AM #137 SUMMER 88 LEFT DOOR READY FOR PAINT   INSIDE VIEW.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
Old 02-05-2011, 12:28 PM
72TAMAN's Avatar
SUMMER OF 88
Doors and hinges all painted that orange/red color. Will be doing work in the garage today and will try to find the paint # of that color
Name:	1972 TRANS AM #138 SUMMER 88 DOOR PAINTED WITH THE  HINGE      ALSO PAINTED.jpg
ID:	233537   Click image for larger version
Name:	1972 TRANS AM #139 SUMMER 88 DOORS PAINTED WITH THE HINGES ALSO PAINTED.jpg
ID:	233538   Click image for larger version
Name:	1972 TRANS AM #140 SUMMER 88 DOORS AND HINGES PAINTED.jpg
ANDRE
1984 6000LE (SOLD)
2003 SILVERADO 1500
