Old 02-04-2011, 07:41 AM
steve's Avatar
steve steve is offline
Default Decision time....stereo install cut dash ?
My choices are to cut the dash for a modern stereo or mount it in the glove box. How bad of an idea is it to cut the dash on my 67. It is by no means an original ride. Anyone out there with pics of a glove box mounted cd player ?
Don't talk about getting one of the retro gigs that fit in the old dash slot. That's not an option.
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-3:55 Moser rear-Dougs Headers....
Old 02-04-2011, 07:45 AM
stimpy stimpy is offline
we mounted my freinds on a peice of aluminum plate in the glove box and the cd player went in the trunk , and put a dummy in the factory hole .
Old 02-04-2011, 07:59 AM
The Champ's Avatar
I recommend option #3...
Mount the radio in an underdash mount installed below the dash.
I'll take a picture of the Alpine AM/FM/CD unit installed in my '64 tonight when I get home and post it for you.
The install will be easier without cutting the dash, and functionally much superior to mounting in the glove box where the driver can't control it.
Old 02-04-2011, 08:02 AM
Old Goat 67's Avatar
I like that Champ.
Where do you find that?
Charles
Old 02-04-2011, 08:22 AM
steve's Avatar
i like that option as well. i am really looking for install pics for ideas...post em if ya got em please. i have never had a radio of any kind in the firebird. i am getting kinda stoked. of course the next question is if i should just mount the speakers in the rear package tray in the classic spot ?
Old 02-04-2011, 09:17 AM
The Champ's Avatar
Any good stereo shop will have them. Years ago, I used to work in consumer electronics and was aware of these - before I ever got any old cars.
Google "underdash radio mounts" and you can find several.
I found that pic at: http://www.autotoys.com/x/product.php?productid=8855
Crutchfield also has them: http://www.crutchfield.com/S-B45KavJ...tml?tab=review
I will take a photo later today and post to show how it looks installed in a GTO.
Old 02-04-2011, 09:21 AM
The Champ's Avatar
6x9's in the rear package shelf are a no-brainer. That's what we have in our Camaro.
For the front (and you really need something up front), you can fab a mounting plate for a pair of 4" speakers to replace the factory front dash single speaker. These are also available as a kit already assembled - right from our board sponsor - PY.
Old 02-04-2011, 11:38 AM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
Subscribing... I am in the same boat as steve. except, my dash was already cut by a previous owner, so I may just shove one in there. don't have any speakers in the car either.
I would also like to see pictures of others AFTERMARKET radio/headunits installed. (whether in cut dash or glove box or where-ever)
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
Old 02-04-2011, 11:54 AM
t/a 79 t/a 79 is offline
diferent cars but here is my 79 6x9 in rear 2 4" in dash also have 51/4 componet speakers woofers under front seat tweeters top of window pillars I used a pioneir head unit with auto eq ( uses a microphone to balance the speekers to the car) it realy compensates for less than ideal speaker placement and sounds great
ID:	233444   Click image for larger version
ID:	233445   Click image for larger version
ID:	233446   Click image for larger version
ID:	233447   Click image for larger version
Old 02-04-2011, 11:55 AM
GR8ONE68's Avatar
GR8ONE68 GR8ONE68 is offline
Here is my Sony X-Plod in my '68 GTO. I don't like the Sony, but it is an example.
469 (455 + .060") with the Edelbrock RAIV cam, Ported 6X-8 heads with 1.77" exhaust valves, 100 cc's, "0" decked block for 9.3:1 static CR, Eagle 1.65:1 roller rockers, Edelbrock RPM manifold and Edelbrock 750 carb., 1.75" x 3.0" Hedman Headers, 2.5" flowmaster exhaust system with "H" pipe and Dynamax super turbo mufflers. 200-4R with a Continental converter, 3.07:1 12 Bolt Saf-T-Trac
Old 02-04-2011, 02:24 PM
goatman-68's Avatar
goatman-68 goatman-68 is offline
Default Eclipse
Here's mine, not pretty, but functional........
I have the (large) tweeter crossovers mounted under the plate.
There is a bracket that I made in the back that securely firms up the plate.
Name:	DSC00425 [1600x1200].jpg
Frame off (resto mod) 68 GTO - 406, 0-deck, E-Head home port 87cc, TRW L2279F30, Comp. flat solid .577/.577 - 248/[email protected] 110LS. 700R4, Precision Industries 3 disc 10" lockup 3500rpm, Moser 9" 4.11, Detroit Locker.
Old 02-04-2011, 03:41 PM
1966goat's Avatar
1966goat 1966goat is offline
Send a message via AIM to 1966goat Send a message via Skype™ to 1966goat
I used that underdash unit last year, until I decided to just cut the dash. Here are some pics.
461ci, Edelbrock 72cc heads, KB 15cc dished pistons, comp xe274, PRW 1.5 roller rockers, Performer RPM intake, Holley 80508 750cfm, RARE oversized manifolds, Pypes X-pipe Exhaust
Old 02-04-2011, 04:25 PM
The Champ's Avatar
Quickie pic from my phone...
Back when I showed my car at judged/bigger shows - I would take this out for shows. Took about 3 minutes and very basic tools - and then stuff the wires up under the dash.
Old 02-04-2011, 06:54 PM
steve's Avatar
thanks for all the pics ! it seems like many have the gauges under the center dash area like i do. thats why i was wondering how it would work. i cant think of a way to make the glove box idea look smooth yet either...
Old 02-04-2011, 09:45 PM
Radman's Avatar
Radman Radman is offline
google hidden radio. They make a remote control radio that can fit anywhere in the car. I have one in my 62 tempest. It has a power antena output that I have driving a relay to switch the speakers between the factory am that is still in the dash and the hidden radio. One small pannel about the size of a cell phone is all you can see. And you must get on your knees outside of the passenger door with the door open to see it. I have seen adds for a newer one that can play an I-pod. That plug fits just inside the glove box.
I forgot to say where I mounted the hidden radio. It is above the glove box, under the dash. There was plenty of room to mount it there, then put the glove box back in.
Old 02-04-2011, 10:00 PM
old66tiger's Avatar
old66tiger old66tiger is offline
I have been a fan of running an MP3 player into an amplifier. This way, there is minimal wiring, the MP3 player drives an amplifier very well and you aren't lugging around tons of Cd's with you and the amp hides well in the trunk, under the seat, etc, etc. In a very short time, CD's will become thing of the past. I have been running my zune into a 2 channel Alpine amp and love it.
Skinned knuckles and empty wallet! Could I be any happier?
66 GTO Convertible. LS3-525 HP. Legend LGT700 5-speed, Wilwood 4-wheel disc brakes, Ridetech coil over front susp, PMT rear susp, Hotchkis bars, Billet Specialties 18" Dagger's (18X9 rear, 18X8 front).
2002 Ram Air WS.6 convertible Trans Am. Wife's car.
Old 02-04-2011, 10:26 PM
guccieng's Avatar
guccieng guccieng is offline
x2. the best radio head is no head at all. put your amp in the trunk and run a cable to the front and hide a single 1/8" stereo jack and a power trigger wire from the ign hot on the fuse box. plug in your ipod/mp3/portable radio and you're good to go. nothing to steal and looks great (because it can't be seen). i run a 4 channel jvc amp (left, right, and bridged for the mono 12" sub) with a pair of infinity reference series 6x9's. love it.
John J.
Old 02-05-2011, 02:00 AM
redbeard redbeard is offline
I put the head unit in the glovebox on my 62 Bonne'. I prefer this over just the cord from mp3 player to amp. I like the audio control offered by the head unit: EQ, fader, sub control, high pass, low pass filters etc, The head unit I bought has AUX 1/8" and USB input too. I will run a 1/8" cable that will come up from under the seat so I can use my mp3 player or Droid. One of the new nano USB thumbdrives will fit in the radio and be able to close glovebox door without removing it. If I leave the glove box door open while driving I can use the remote so I don't have to reach across to make adjustments while driving.
Old 02-05-2011, 10:46 AM
PontGuy's Avatar
PontGuy PontGuy is offline
Steve, is there a reason that using a stock-looking radio that fits the cutout is not an option?
I went around on this myself on my '69 Lemans. I didn't really like the look of the C-A radio and it doesn't fit a 69 without cutting anyway. After a bunch of searching around I found a radio that Ausley's Chevelle was selling pretty cheap that fit the stock opening. The tuner is not that great but I mostly use my IPOD through the Aux-in anyway. Forget about CD's- they are already becoming old tech.
The 67 FB uses the same cutout as the Camaros, right? It seems to me there should be some good alternatives out there.
Walt
1969 Lemans vert, matador red, 462 CI, 3.07 12-bolt posi
1974 455 TA, admiralty blue/red interior HPP "cover car" - sold
"The best way to show a car is to drive it"
Old 02-05-2011, 11:20 AM
quicksilver97ta's Avatar
Walt
Exactly. Thats what I did, and ran the mp3/aux jack into my console. I just plug my phone in since thats the only mp3 player I mess with and I'm good. The radio works fine as well and doubles as a clock. Not perfect but way better than cutting up an uncut dash, and less work.
ID:	233527   Click image for larger version
