Old 02-08-2011, 11:14 AM
t/a 79 t/a 79 is offline
Default dip stick to short?
I have a 71 455 block w/ windege tray and a morroso 8qt pan have the lower tube installed throug w tray and the lower upper tube 9" non a/c type I have a 17.5" non a/c dip stick(193/4" w/ handel) I bought from py. with 8 qt oil in pan oil hardly touches the end of the dip stick. has anyone else run into this? do I need a aftermarket generic longer dip stick? Any other solutions?
Old 02-08-2011, 12:32 PM
Kenth's Avatar
Kenth Kenth is offline
You may need to add 1qt for the oil filter?
Old 02-08-2011, 01:16 PM
takkes more than 1qt extra tobring it up on the dip stick
Old 02-08-2011, 08:26 PM
East East is offline
Does the top dip stick tube reach above your exhaust? I have an A/C dipstick and without the upper tube, the lower section is between #2 and #4 exhaust ports. My point is that I used a different dipstick and remarked it after the oil settled after an oil change. I was wondering how much longer the dipstick is on your engine that will allow you to shorten it so that the dipstick reads the way that you want. I couldn't shorten mine because it was already too short to begin with without the upper half installed. It's just an idea to give you a piece of mind knowing what the oil level was at any given time.
Old 02-08-2011, 10:47 PM
4dblnkldude's Avatar
How would the length of the stick matter? If everything is in the right place tube wise? The oil need to be where it is on the stick even if you have 20 qt pan.
Old 02-08-2011, 11:35 PM
Probird's Avatar
Probird Probird is offline
Hmmmmm............sounds like a personal problem. LOL
Yes, sounds like the wrong dipstick or the wrong tubes being used.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
2024 Chief of the Pontiacs
Old 02-08-2011, 11:42 PM
Default I left out one word and meant to say dipstick tube
I was wondering how much longer the dipstick ----TUBE----- is on your engine that will allow you to shorten it so that the dipstick reads the way that you want.
Old 02-09-2011, 04:10 AM
Kenth's Avatar
It also would be nice to know the length of tube coming out of block, measured at underside of tube from block to end?
Got this from "QUICK-SILVER" in another post:
But looks like 7 & 5/8ths inch.
Checked 7 virgins by hooking measuring tape on head gasket behind tube.
From top of block to end of tube got measurements from 2" to 2 1/4".
Old 02-09-2011, 10:04 AM
My tub also ends between exhaust ports
Old 02-09-2011, 10:07 AM
stick does not seem to be long enough to reach oil when propper amount of oil is in the pan. ie the stick needs to be long enough to extend into the pan far enough to register the oil level
Old 02-09-2011, 11:03 AM
Kenth's Avatar
Do you have the original windage tray with the inner dipstick tube retained by the windage tray?
If no inner dipstick tube, the dipstick ends up under the crank, instead of in the oil, waiting to be reduced in lenght by the crank counterweights....
Old 02-09-2011, 11:13 AM
Try this post:
Dipstick tube
You need either the GME157A or GME157B to get an accurate reading.
Both go in block tube. (on inside of oil pan)
Old 02-09-2011, 12:00 PM
Default That is a very good bit of information
Johnta1,
Thanks for linking to the information. It has everything I wanted to know without having to remove the engine to look inside.
-----Kevin
Old 02-09-2011, 12:31 PM
yes it has the windage tray and inner tube
Old 02-09-2011, 03:39 PM
PONTIAC DUDE's Avatar
Post Something to check.
I have seen the angle off with replacement oil tube related parts. The bottom tube goes in at an angle thru the tray and if the angle is too flat the reading will be off.
Old 02-09-2011, 04:00 PM
may be my problem I used a lower tube from py (mine was missing) would a slightly longer dipstick hurt anything (if it will reach oil when 8qts are in pan takes 91/2qt to show up on stick now)
